Question about ASUS A8N-VM CSM (00610839133826) Motherboard
Asus A8N-VM CSM wont boot, no fans come on or anything, green light comes on the motherboard, is the CPU dead? tried different ram still the same. any help would be great!
  • harrison1969 Feb 05, 2009
    Hi, have tried all these solutions but still nothing, the cpu was bought 2nd hand a while ago and untested for £5 on ebay, so thats why I think thats the problem?
  • 2,404 Answers
If your motherboard has the P4 connector on it then make sure the main connector from the power supply and the P4 connector is hooked up to the motherboard. If this doesn't work then try a different Power Supply if you can. Make sure only the motherboard connectors are hooked up and no drives. Last thing, try a different CPU and if no luck then the motherboard is bad.
Posted on Feb 05, 2009
  • 1,602 Answers
CHECK ALL JUMPER ON THE BOARD AND MAKE SURE THE BOIS RESET JUMPER IS ON JUMPER 1-2, SOUND LIKE A POWER SUPPLY PROBLEM NOT ENOUGH WATT TO RUN THE SYSTEM
2ND OPTION, REMOVE ALL WIRE AND ADDTIONAL CARDS, MIN. MEMORY, LEAVING 1 STICK OF RAM, VEDOI CONNECTION , AND THE POWER TO THE BOARD, CONNECT ONE WIRE AT A TIME AND RESTARTING THE MACHINE EVERY TIME UNTIL YOU FIND THE PROBLEM.
CANDYMANGANDY
A8N-VM CSM motherboard drivers for LAN where to get them?
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Jan 31, 2011 | ASUS A8N-VM CSM (00610839133826)...
No video after replacing chip fan
Try a different video-card -- a "no-spin" fan and "no-video" implies a dead video-card (or at least a video-card that is not "seated' properly).
Check that the PC-speaker leads are connected to the motherboard, so that you could hear any "beep" codes. There should be one "beep" to indicate 'OK', or multiple "beeps" (bad RAM, no video-card detected).
Apr 09, 2010 | ASUS A8N-SLI Deluxe Motherboard
ACPI on ASUS A8N-VM CSM Motherboard not working.
Can you please indicate how you turn the motherboard on if the on/ off switch is not operating?
I take it that because of the keyboard problem at boot up you are unable to get into BIOS> If this is the case then it might be very difficult to diagnose what is going on. YOu need to be in BIOS setup to check the state of the hardware.
What setup have you used to program automatic sheduling of TV program recording. Is the computer active all the time?
Not sure why you think ACPI or cmos battery might be causing the problem.
Please post a few answers that might help me understand the problem a bit better.
Jan 17, 2010 | ASUS A8N-VM CSM (00610839133826)...
Muy Mother Board A8N-VM CSM Driver Lan
follow the link below to download any driver you need
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=A8N-VM%20CSM
You have a Gigbit Lan on the motherboard
you can enable or disable this in bios setup.
If it is enabled and not working you'll need to purchase an eithernet card they run about $10-20.
Mar 23, 2009 | ASUS A8N-VM Motherboard
ASUS P5GD1-VM motherboard not booting when powered on
First are you sure it is the CPU fan and not the Power Supply fan? Open up the case and make sure the power supply cable is snug into the slot. Make sure that Pin 1 is lined up with Pin 1 on the motherboard. There should be a notch or red dot or different looking Pin to show you where pin 1 is...sounds like it may be a connection problem from power supply to motherboard...try that and let me know what happens we have other options but have to start somewhere..
Mar 06, 2009 | ASUS P5RD1-VM Motherboard
Give me my motherborda direvers
Justo go to this link:
Drivers for ASUS A8N-VM CSM
And select the correct Operating system.
Then download the drivers you need.
Good luck
Jan 30, 2009 | ASUS A8N-VM CSM (00610839133826)...
I Want Driver for Asus A8N-VM
Manufacturer drivers for the Asus A8N-VM board can be found here:
http://support.asus.com/download/download_item.aspx?product=1&model=A8N-VM
Jan 19, 2009 | ASUS A8N-VM CSM (00610839133826)...
I am trying to find a lan driver for my Asus A8N-VM CSM rev 1.01 I dont know why this board is proving so difficult to find but it is.
The NIC (LAN) driver IS on the ASUS support page. IT is just not labeled as the NIC LAN driver.
It is labeled as the "NVIDIA nForce 430/410 Chipset SATA/RAID Driver Disk" under the "Utilities" folder.
I just installed this myself and it works great now.
Enjoy... And pay the favor forward some day.
Cheers.
Jan 17, 2009 | ASUS A8N-VM CSM (00610839133826)...
ASUS A8N-VM CSM (00610839133826) Motherboard Logo
343 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
