Question about PC Chips M955G Motherboard
When installing windows xp pro it does not pick up the sata drive
When i try install windows xp pro it does not pick up my sata drive, i dont have a stiffy drive in the case im using a external stiffy and all the drivers i get are not working....
  • 1,602 Answers
REVERSE THE CABLE, PUR IT TO THE CLOSIST CONNECTOR ON THE RIBBON CONNECTOR, GO IN BOIS SETTING TAB DOWN TO 1 DRIVE TAB THREW SETTINGS TO USER RETURN , INTER CYC HDS SECT
F10 SAVE CHANGE AND YES
REBOOT
ROD
Posted on Feb 05, 2009
Bios reconizes new hd drive but xp pro does not
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 25, 2012 | Hitachi Ultrastar A7K1000 HUA721010KLA330...
When i try to install windows xp pro , it says press any key to boot from cd . then it says inspecting files.. then it just restarts everytime. do i need sata drivers
Please try going into the BIOS of your computer try to reload the defaults and check if it will happen again.
If it happens again, try going back to the BIOS and try staying there and see if the computer will restart.
If it restarts in BIOS mode that means your computer has a problem with the memory or the motherboard.
If windows xp cannot find a hard drive it will tell you that it cannot find a disk to install windows xp and will not restart by itself.
I think you have a different problem than just the sata drivers.
Hope this helps!
Jun 25, 2011 | Computers & Internet
Hi, I have a msi n1996 865gvm3-v motherboard and it doesn't want to pick up my sata drive, what to do?
If you are trying to install Windows XP and it does not detect the SATA hard drive.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 14, 2011 | MSI 865GVM3-V Motherboard
Cannot install xp pro on wd sata hard drive please help
This may be because the version of Windows XP install disk that you're using doesn't support SATA. You'll need either a driver disc or a newer XP install disc which has SATA support. You could try enabling legacy support in the bios to enable emulation which the operating system may understand.
Nov 26, 2009 | Intel DG31PR Motherboard
Installallation of xp
the xp does not recognize the SATA hard disk of your computer, you must install SATA drivers during the installtion of XP.
Sep 16, 2009 | Microsoft Windows XP Professional With...
I want to install XP Pro on a sata drive
You need to post what Brand/Model of motherboard you are using, or search for yourself on the manufacturers website for the SATA drivers. Then you need to load the SATA drivers onto a floppy disk so that you may press F6 during the beginning of Windows Setup to load the SATA drivers, as Windows XP Setup does not come with SATA drivers.
Jul 19, 2009 | ASUS MB-SK8V Motherboard
Can't install WINDOWS.
Install the XP Pro first, install the necessary drivers etc. Then after that load the other disk for windows XP Home install it choose the drive to install the OS, install the necessary drivers etc. you will see two operating system while going to boot section of the computer.
Mar 11, 2009 | Dell Dimension 8400 PC Desktop
Can't re-install windows xp on LG P1 Pro express dual
1. Power on and press F2 to enter in BIOS stetup Utility.
2. Choose “Advanced”, and change the “SATA to IDE
3. Saved the change.
4. Restart and install XP Operating System.
i dont exactly know your bios setttings but just find the option that changes SATA option to IDE.
Feb 17, 2009 | LG Computers & Internet
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
PC Chips M955G Motherboard Logo
212 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
