Question about Indesit W 123 Front Load Washer
How to put on new handle on indesit washing machine w133s
I have the new handle but am unsure of how to attach it to the round plastic part it goes on. It's which way the sping goes is what is confussing me.
  • Anonymous Feb 21, 2009
    i have the same problem...do i need to tak the whole door off to rplace the door handle? i cant work out how to replace the handle...
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
The spring will go so that it pushes the latch part in towards the outside edge of the door. the pin goes through the door frame, then through the spring's 'holes', through the latch, and back into the frame of the door. the spring ends should sit in a couple of grooves in the door part which may be marked/scratched by the previous one.
Posted on Feb 17, 2009
Plastic things inside the drum have all come off,
If they have come off, it is because they are worn or broken.You need to fit 3 new ones
They are referred to as drum or clothes lifters, thier purpose being to move the clothes around.
Do not use the washer until you have got them fitted.
They usually slide and click into the slots in the drum.
Mar 01, 2010 | Indesit Washing Machines
Ive got a indesit 1000 wil103....it seems like the filter is blocked but im unsure of where it is, as i put clothes in the machine but they come out dirty! please help!
Filter if this model has one down Bottom left hand side of machine , remove bottom plastic cover to see this, put down an old towel to save flooring ..good luck
Nov 19, 2009 | Indesit W 123 Front Load Washer
The rubber has come of the washingmachine door and their is a round wire with spring attached and i am not sure where this goes i know it holds rubber onto door but not sure how.
toput it back on you thred it round the door and you put the wire with a spring insine the rubber there should be a notch all the way round you thred it round the door to hold it so it dosent come off the wire is a restaining clip to hold it on when you done this make sure the rubber dosent move hope this helped
Aug 31, 2009 | Indesit W 123 Front Load Washer
Indesit W 103 waste water catcher attachment & hooks
Hi .
The plastic lug goes on the top frame of the washer, you should see where as the other will probably be still in place,
Then it is a case of pulling up on the springs and hooking into place.
If you cannot get the clip fastened, then use a large jubilee clip.
Good luck.
Nov 23, 2008 | Washing Machines
Hi, the handle has broken off my Indesit WA 125 Front Load Washer. I cannot open the door to get my clothes out, any suggestions? Also, would it be possible to buy a door (part of the plastic on the door...
I don't know where you live but in St. Paul and most other cities, there are appliace parts distributers, adn they sell to the public. If you can figure out how to get what is left of the handle off of the machine, you can probably put a new one on.
Sep 05, 2008 | Indesit Washing Machines
Fitting a drive belt to an indesit WG1130TGT washing machine. how do I release the tension to fit the belt round the motor and pulley?
I don't have the exact same model as yours, but on my WE16 I just place the belt over the motor pulley and partly round the big wheell attached to the drum, and then turning the big wheel by hand the belt gradually goes on completely. No adjustment to the spacing is necessary, unlike, say, the alternator belt on a car.
Hope this helps ya :-) D
Remember to have the machine disconnected from the power supply when working inside it!
Jul 05, 2008 | Washing Machines
Indesit w123
not really worth replacing timer as many problems can cause this
May 19, 2008 | Indesit W 123 Front Load Washer
Indesit W133S front loader
hi there the filter is at the bottom of the machine behind the kickplate but if you are getting a bad smell it is more likely your machine needs a service wash ie. run some old towles through on a 90 degree cycle with some soda crystals.
hope this is of some help
Dec 07, 2007 | Washing Machines
We have a indesit wil 143s faulty
the pressure switch should be easy to replace. it will be a round unit with wires going into it and also a small clear plastic tube attached. it is usually mounted around the top edge of the case. i would also check that the pressure system is not blocked (the other end of that clear plastic tube) as blockages may keep pressure at the switch leaving it in the "full position" pop the pressure tube off of the switch and force some air down the tube to check.tony.
Jun 03, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
212 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
