Question about Samsung SCX-6320F All-In-One Laser Printer
Samsung 6320 has varying registration from the top tray only the bottom tray and bypass work perfect.
  • 77 Answers
Pick roller may worn out. please check.
Posted on Feb 06, 2009
  • 104 Answers
Remove the noise reducing foams on all the feed solenoids. They will be turning into sticky tacky glue which throws out the clamp and release timing of them out and the registration position of the prints.
Posted on Feb 16, 2013
Paper jam when print from tray 2
There is Registration Sensor located near the bypass tray.Please clean the sensor or else replace the sensor or DC board.Orelse please check the pick up roller solenied switch( spounge in solenied may be torn out replace with another spounge)
Apr 05, 2014 | Genuine Konica Minolta Konica Minolta...
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
Paper jams when it leave the tray
This printer is new model so probably there is a problem with paper sensor at registration roller or next one paper sensor in fusing unit(it depends where the sheet stops). To be sure please first clean as you can the paper feed roller in tray and also check the manual feeding. If you can feed on bypass tray, then the paper sensors are OK. Look for problem in tray or rubber roller
pifonski
Feb 24, 2011 | Samsung SCX4623F Laser All-in-One Printer
How do you access bypass tray?
The bypass tray is refered to as the multi-purpose (MP) tray. It is located vertically on top at the back of the fax machine. The fax needs to be programmed (told what size of paper is loaded) by opening the One-Touch Speed Dialing panel, press the 'Data Registration' button, press 'Set' button, then using up or down arrows to select " 5.PRINTER SETTINGS ". Press 'Set' button, then press down arrow to display " 2.PAPER SIZE ". Press 'Set', use arrow s to select CASSETTE or MP TRAY. Use arrows to select appropriate size of paper loaded. Press 'Set'. Press 'Stop' button to return to standby mode. Reference pages 15-11 and 15-12 in LC 2050 Users Guide.
Dec 17, 2009 | Canon LaserClass 2050 Plain Paper Fax
MP Tray Paper Empty
"MP" tray is refering to the top fold down tray on the front of printer (bypass tray) You might load paper in the bypass and see what it does?
Aug 18, 2009 | Samsung CLP-610ND + Demo Laser Printer
I am getting an error on my Samsung SCX 6320 saying that there is a paper jam when there is no visible paper in the machine. It had jammed, I removed the paper with no tears or rips, but it still has the...
its may be the problem related to Two causes....
pls. check the Main Frame paper feeding gear was brokned or not ?
check the paper exit Pully in the exit area....
Jul 09, 2009 | Samsung SCX-6320F All-In-One Laser Printer
RiCoh 1075 MisFeeding...
The problem you are having is that developer has fallen down into that area good luck once this has happened the box must be taken apart and blown out...  good luck
Apr 22, 2009 | Ricoh Aficio 450 Copier
Duplexing jams
Some of the rollers inside the printer have becomes slick with paper dust on the surfaces of the rollers. There is a printer cleaner paper available at most office supply stores and online. It is sticky on both sides. You run a sheet through the printer a couple of times and it removes the dust from the rollers. In your case, run the paper through the duplex unit too.
Mar 16, 2017 | HP LJ-8000DN Laser Printer
How to print envelopes
Put envelope in bypass tray. Print on it.
Jul 23, 2008 | Brother Office Equipment & Supplies
Vertical colored lines on top and bottom of screen
Definately a video processing problem and it may need a logic board it is called. Does the set work fine if you feed component into set to bypass all that? Let me know. GURU JAY
Sep 11, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung SCX-6320F All-In-One Laser Printer Logo
51 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
