Question about Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1800 printer,flashing orange light under the green 'on'
Canon iP1800 printer has an orange flashing light under the green 'on' light. Printer won't print. Can't find an instruction manual. Thanks in advance for your help
  • 2 more comments
  • onietx Feb 11, 2009
    flashing orang light under the green 'On' problem.
  • Anonymous Mar 18, 2014
    indicator light is flashing green and orange
  • Anonymous Mar 19, 2014
    Printer wont print and the power and orange light keep flashing.
  • Anonymous Mar 25, 2014
    canon pixma ip3500 wont print orange light flashing
  • 3 Answers
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
Posted on Feb 17, 2009
Orange light is flashing 7 times and I get msgs that say cartridge not installed properly and cartridge cannot be recognized. I have refilled my cartridges more than once it worked fine for awhile. This is what Canon said.
Subject: Re: Response from Canon - SWSS Web Escalation (KMM10132386V40822L0KM)
> Dear Mike M:
> Thank you for your reply.
> We appreciate your response with the information for your iP1800
> printer.
> The ink cartridges are not designed to be refilled, and this would
> indicate the cause for the issue you are having. each cartridge
> maintain track of the amount of ink used in order to provide status
> information on the level of the ink in the cartridge. Wen refilling an
> ink cartridge, the status information is not updated, and will cause an
> issue such as this.
> The refilled ink cartridges should be replaced with new Canon ink
> cartridges and the printer will resume printing and working properly.
Posted on Aug 30, 2009
Canon ip1800 5 orange flashes then goes green,
The FINE cartridge cannot be
recognized.
Possible causes are as follows:
• The FINE Cartridge may not be installed properly.
• The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output
is not satisfactory, carry out the Print Head Alignment.
Mar 03, 2011 | Canon PIXMA iP1800 Printer
Canon Pixma iP1800: amber, green, amber, greeeeen flashing lights
what error message coming from your computer...i think something stuck inside your printer
Feb 24, 2010 | Canon PIXMA iP1800 InkJet Printer
Canon iP1800-alternating flashing lights. 1 long green, 3 short orange. How do i troubleshoot this? It is a ''Service Error 6000''. Which translates to a paper jam, however, there is no paper in the...
1- Please open the cover and inspect the inside of the printer carefully. There might be a little piece of paper or a tiny object jammed in there and is causing this error message. Also get some canned air and clean the inside of the printer. 2- Restart the printer.
Feb 12, 2010 | Canon PIXMA iP1800 Printer
Canon i850 light is green then flashes orange 7 times then goes green and repeats orange flashing. Printer never gets ready
This is a very bad error. It means that the printhead needs servicing and may need to be repaired. There is no easy fix. Sorry.
Jan 21, 2010 | Canon i850 InkJet Photo Printer
My canon ip1880 printer orange light flashing 7 times even after I have installed both my cartridges correctly.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Oct 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
5 orange light flashes and 1 green light flashes ???
Hi There, 5 orange light flashes and 1 green light means that the printer is not recognising the cartridege. Iam having the same problem with mine and Iam currently trying to find out why. I have installed the correct cartridge so I'm not sure why it isn't recognising it. but once i know i will let you know
Jun 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
IP1800 PIXMA printer will not print.
If consumables are all replenished, your printer should work properly.
Apr 15, 2009 | Canon PIXMA iP1800 Printer
I get a message error that ink cartridge is not well installed
Remove all the cartridges then back again installed..if the orange light is always blinking.long press the cancel botton til the green light is steady..ok..
Jan 03, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
4,385 people viewed this question
old marine
old marine
