I have a 2003 chev tracker that will not start. I have replaced the fuel pump and filter, it tries to start, sputters and after many tries will start and run great. Shut it off and try to start it again and no go.
    Master:
  • 848 Answers
What happened you have disconnected the chat ...
Posted on Feb 05, 2009
  • gopinath pasupathy Feb 05, 2009
    second time too disconnected are you facing any problem .....
Why wont my 2003 ford fairmount ghia start?
go to the website www.autoelectronico.com translate the web with your browser and get the topic and fix it.
God bless you
Nov 25, 2013 | Audio Players & Recorders
I have a Pioneer VSX-305 receiver. I blew channel A speaker outputs by allowing speaker wires to touch. Everything else works. Can anyone tell me what it takes to fix this. (I am an electrical engineer...
Without a Sams Photofact or a service manual I would go directly to the Power IC which is the largest Integrated Circuit mounted to a large heat sink. If you see any fuses they are probably for the power supply since any fused circuit on the speaker output would be ineffective because the IC would be damaged before the fuse would blow, but you need to check them anyway. Since the short was at the speaker output your problem should be at the final stage of amplification, which is the Power Amp IC. Prior to the early 70's you would have transistors mounted to a heat sink which could be individually checked and replaced. Then manufactures started to use the Power Amp IC which are more costly but eliminate having to find matched pair transistors. All you can check on the Power Amp IC is if you have an input using an oscilloscope or signal tracer and the power to the IC. If you have an input signal and power to the device with no output, I would replace the IC. Unless you have a test circuit for the IC you cannot test it completely unless you have a device like a Huntron Tracker or build a test circuit using a signal generator and a power supply to measure the gain of the IC with an oscilloscope. Short of ordering a service manual this is a good place to start.
Aug 15, 2011 | Audio Players & Recorders
My beaitiful Knight KG 250 amp has a loudly humming 6 lead filter cap. Can I ever find a replacement? This amp had a wonderful, rich tone. Thanks, Floydian
Try to search for "filter capacitor" at www.ebay.com
I did a search and found some. Look for the value of your current filter caps and find capacitors with the same value.
Apr 30, 2010 | Audio Players & Recorders
Cant get the fuel filter off
you will need to go to the auto parts store. you need the tool its cheap. not sure what its called  they should know.
Apr 29, 2009 | Audio Players & Recorders
Vintage pioneer SX550 "sputters" when first turned on
Hi...
I own a few Pioneer SXseries recievers..I repair these and others like them in my own business.
What it needs is new power supply capacitors. Parts are cheap. Labor is a couple hours
Jan 29, 2009 | Audio Players & Recorders
I have a 2003 jeep liberty limited edition. My battery died and i replaced it and when i started up my jeep again i went to listen to a cd and it wont go to the cd menu anymore. what could be the problem?
Your Jeep has a security feature.When you replaced battery it caused the cd player to lock up. You need to contact your local Jeep dealership to obtain the security codes to unlock cd player. They usually have that information available. Good Luck
Oct 16, 2008 | Audio Players & Recorders
CANT START
Most bikes (and gasoline feed engines for that matter) would require two crucial elements to start/run: 1) fuel and 2) ignition. A hard starting engine then could be caused by:
1. fuel starvation - there is no fuel in the carbs (or high pressure fuel pump for injected). This could be brought about by the fuel tank's valve which will only allow fuel to flow through if there is a vacuum, the engine is already running. In some models, there is a setting on the fuel valve ON, RES and PRI. On is just that one but requires the vacuum from the intake manifold, RES is for reserve, same as ON except that it the inlet sits lower inside the tank but also requires vacuum. PRI is ON and will allow fuel to flow even without vacuum. Before starting the bike, moved the fuel valve control to PRI if the Yamaha has one. Additional on cold start, putting on CHOKE to about 3/4 up would also enrich the fuel/air mixture making an easier start.
2. Ignition - At every engine start, the battery supplies power to the starter motor and to the ignition system. In some instances when the battery is going weak, the starter motor will gobble up most if not all of the power output of the battery leaving nothing for the ignition system to use. This is especially evident if the bike was used at night with the lights open and the bike did not have a chance to re-charge its battery before switched off. Starting on the next morning would be on a bike with its battery partially depleted. In some instances, the charging system may be at fault if and when it fails to deliver sufficient charging to the battery. Often causes are corroded or loose connection or even a a partially defective voltage regulator.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 30, 2008 | Yamaha RX-V661 Receiver
52 people viewed this question
 Grubhead
Grubhead
