Question about Insignia 37" LCD Flat-Panel HDTV
TV was playing, then the screen turned black.
For 4 weeks, my Insignia TV was playing great. Then the screen turned black. When I tried to turn it back on again, the blue light came on, but the screen is, still, black. When I pressed the remote again, the red light flashed 5 times but no screenMIne is kind of doing the same thing, we've had it for over 2 years and all of the sudden it just wont turn on. the blue light on the logo is flashing red.
  • 2 more comments
  • emilyjoellef Feb 05, 2009
    A lot of people are reporting that their TV were shocked(by Static)and the same thing happened. Is this fixable.
    no warranty(of course) should I just trash the TV?
    we've had it for 2 years I can't believe there is not a recall on the awful TV's
    how do you get to the top left of the power supply board?
  • 679 Answers
It seems that there is a problem of short circuit in your TV. Better you get a full diagnosis from a repair center…before trash it.
Thanks
Posted on Feb 05, 2009
    Brigadier General:
  • 3,614 Answers
It still repairable. better for you to call for a authorized service engineer for that to avoid any further damaged to the unit and injuries.
    President:
  • 2,559 Answers
Check the fuse and connections on the PCB (Power control board)
  • 15,935 Answers
Replace the three 680uf at 35 volt caps at the top left of the power supply board.
They are about $1 each.
You will see they are swollen and may be popped.
You'll spend $3 to repair your TV.
Good Luck!!
  • 1 more comment
  • blueextc3221
    blueextc3221 Feb 05, 2009
    If you're going to trash it - ship it to me :D
  • blueextc3221
    If the caps appear good - the final check before deep 6-ing it is the transformer. Unfortunately Insignia is for sh1t as far as servicing - so you will need the part # off the transformer to search for a replacement.
    Thanks for using FixYa - a FixYa rating is apprecited!!
  • blueextc3221
    you have to open up the tv.
  • 916 Answers
If your tv has had a static shock any one of the components inside if not all could be malfunctioning. I would call best buy and ask them and if it is still under warranty get a replacement you should not need a receipt if you lost it as best buy is the only one that sells that brand.
  • machadojr_fe Feb 05, 2009
    Your best bet is to get a new one as a repair on this could be expensive and will need to be done by a service technician. You could also call best buy I believe there geek squad would know what the red light blinking 5 times would mean as that usually is an indication of the problem.
    Genius:
  • 1,913 Answers
Ok
first remove all connectin from tv.then reattch all connectin again.check your power suply waltage and earthing ptoprely.try other poweers supply if problem remains your tv chipset has some problem s may be small diode register or trnsistor blown.if u have warrenty then take to the service shop and repair your TV.
    Master:
  • 848 Answers
Hi
hard reset- unplugging tv for about 5-10 minutes and see if that clears up the problem. Because they have microprocessors in them (computer chips) and just as like with any other operating system, they can hang up or crash. Unplugging it for awhile resets the microprocessor .
  • gopinath pasupathy Feb 05, 2009
    check the fuse ....ipower surge can damage power board (inlet power supply unit)circuit ....replace the board.......
I have a insignia ns-lcd37-09 tv.The screen suddenly turned green.I can here sound but no picture.can you help?
Change input device to some other which you know works for sure. If problem persists, try changing the channel. If you notice same problem, this may need attention by a qualified service technician.
Jul 21, 2012 | Insignia NS-LCD37 37 in. LCD TV
Ihave a insignia ns-lcd47hd-09 tv. when i press the power button the light turns blue but no picture comes on only black screen.
I think your insignia is set for SHOP mode instead of HOME mode. I changed mine to HOME and it's working fine now. Press your menu button and then scroll down to setup. You're looking for Plug and PLay which should be the very first choice. If it's greyed out as mine was you'll have to change your imput from HDMI to TV in order to get to the P&P. Once you're in the Plug and Play your first choice is language. The second should be SHOP or HOME. Make sure to select HOME. You can skip scanning for channels. This fixed my problem with the blue light. The store uses SHOP so if someone plays around and changes something, all they have to do is shut off the TV and turn it back on. Please let me know if this works.
Oct 03, 2011 | Insignia NS-LCD47HD-09 47 in. LCD TV
My screen went black, its a insignia 20'' lcd.
Generally, problems like this require repairs to resolve. You may carry the TV in to the place of purchase to pursue service options.
Mar 09, 2010 | Insignia LCDTV26 26 in. Television
I have a 42 in Insignia LCD that I have only had
If a problem like this should develop within the retailer's return period, it is recommended that the TV be returned for an exchange.
Jan 19, 2010 | Insignia LCDTV26 26 in. Television
Insignia ns-lcd42hd screen flutters
This television is having trouble with sync circuits. It probably has some component adding erratic noise voltage to the circuit causing the instability in the sync lock circuits. The solution is to locate the bad component with an oscilloscope by following the signal path with oscilloscope probe until you find the irregular signal and then replace the part. This part could be either capacitors or ringing resistors.It may also be a component in you solid state signal processor. You should have it tested in a service center and see if they can locate the bad components. Then see if it worth replacing with the cost of parts and labor. Hope this helps you with your problem.
May 12, 2009 | Insignia 37" LCD Flat-Panel HDTV
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Feb 01, 2009 | Insignia 37" LCD Flat-Panel HDTV
My 26 inch insignia has sound but black picture
Hi freelingtrapt,
I am happy to help, we need to check the backlight inverter.
  1. Turn tv on and get to a point that you have audio.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely at the screen for a very dark video image.
If you see an image you have a bad inverter, you should be able to replace it yourself. I can walk you through in chat. Let me know your findings. Lone99star
Jan 22, 2009 | Insignia LCDTV26 26 in. Television
Insignia NS-DXA1 APT remote control doesn't work
Set your TV input to match the input your have your Insigna connected to. Then run the Insignia setup. You are getting a distorted screen because you probably have the Insignia connected to channel 3 and the TV on channel 4.
Dec 30, 2008 | Insignia Digital-to-Analog Converter for...
Insignia 37" LCD Flat-Panel HDTV Logo
59 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
