Question about HP LaserJet 3055 All-In-One Printer
Feeder problem with Fax
Hello - whenever we fax something the feeder has a hard time grasping the paper, do we need a new feeder and if we do how do we go about purchasing one?
    Genius:
  • 2,120 Answers
Open the doc feeder and clean the roller and pad with alcohol.
Posted on Feb 06, 2009
Paper does not feed from top of my hp 7210 printer and can not fax from top feeder. I can not use the top feeder to copy multiple documents. Only bottom feeder works. When I have to fax something, I have...
The rollers on the feeder can go bad and the best way to solve it is to get a new complete assembly. Check the website under your make and model for the assembly. YOu might also want to check for paper jam
Mar 19, 2011 | HP Officejet 7210 All-In-One InkJet...
How to fax multiple papers
Hello t,
Put them all in the feeder at one time... Not too many though and make they're nice and neat. Nothing sticky should be on them like tape or glue.. No paper clips or staples either. Folded or damaged corners are trouble as well.
If your machine is like the one in the picture here, it might be fine with up to 30 pages.
Dial up the fax machine you want to send to and they shoulg all go thru but one at a time. If they don't go in one at a time and get jammed in the feeder part of the machine there is something wrong in the machine and it needs to be serviced.
Hope that helps! Let me know!
RAy
Jun 02, 2010 | HP Officejet J3680 Multifunction Printer...
Witch way does the paper go up or down when you fax
Either way. The tray on the top is the conventional paper feeder for fax (this is where you manually fax single paper) and the tray on the bottom is your "Automatic Document Feeder" in which can hold 20 page unattended fax or copy.
hope this helps. Don't forget to rate.
Jan 06, 2010 | HP J3680 Officejet All In One Printer
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Feeder scanner stop after 1cm scan/fax
You need to clean the rollers inside the feed section, use an alcohol wipe.. or something like methylated spirits and a rag..
Oct 16, 2009 | Panasonic KX-FL611 Plain Paper Laser Fax
Faxing from scanner rather than feeder.. help.
ideadly the scanner needs to scan to get the image to send out in fax form. The feelder paper feeder that is for recieving fax
Jul 31, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Paper in auto feeder face up or down to fax?
up.....same as when you make a copy from the feeder
May 02, 2009 | Office Equipment & Supplies
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Black lines on faxes
Open up the document feeder (where you put paper to send) and look for wite-out on the thin glass.
If it's not dirty, you probably have a bad scanner unit. Uneconomical to repair.
Sep 23, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Document feeder
Its most likely to be the pickup roller and separation pad which will need replacing. as a short term fix try cleaning them with some isopropyl alcohol
Sep 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP LaserJet 3055 All-In-One Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
