Question about Hotpoint RLA21W Compact Refrigerator
Replacement lamp for hotpoint RLAV21 fridge
I replaced the old lamp with a 15w lamp which blew straightaway.
Q. Does the replacement lamp have to be 10w to work?
    Problem Solver:
  • 14 Answers
Hello, it is preffered to put a 10w or a 15w in anything less will blow as soon as u put it on.
Posted on Feb 05, 2009
  • nakisanir Feb 05, 2009
    hello, it is preffered to put a 10w or a 15w in anything less will blow as soon as u put it on.
Problem with fridge light on Hotpoint FFA70
Did you check the new lamp when you put it in? Did you keep the old lamp? It may well be the switch rather than the lamp itself. Check the lamp has continuity from the middle pin to the outer and the filament isn't broken
May 10, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Conia CF 360 Hi my Conia Fridge light bulb has blown and I gave it to a friend to find me a replacement - He has now lost the original bulb and I am having trouble getting a replacement that fits...
Most electrical suppliers will have a bulb to fit, they are normally a screw fitting, you will probably need, write this exactly
15w SES lamp
It means 15 watt (lamp power) Small Edison Screw, odd times they have used a
15w MES means the same except Mini Edison Screw
Apr 20, 2011 | Refrigerators
How do change the ref bulb on sharp ref model sj p43n - sl
Unplug the refrigerator. Remove the lamp cover by lifting up at the bottom of the cover. Then unscrew the old bulb and replace with an identical appliance bulb (Base E12, 240V, MAX 15W, T-20). This bulb is at the top center of the fridge.
The manual is available here: . You will need to review the fridge or enter a code to download the PDF. The light replacement instructions are on page 6.
I hope this helps.
Feb 25, 2011 | Refrigerators
Fridge keeps freezing
Can't solve your problem, but just to report we have exactly the same issue, a huge block of ice forms on the upper rear panel. The compressor seems to be running 24h, not matter where the 'thermostat' is set.
I suspect that there was/are a faulty batch of thermostats. Or (since there is no metal cooling plate to bolt it to) that the T/Stat probe has somehow come adrift from its correct sensing area and is not correctly sensing the temperature inside the fridge.
If I get to the bottom of the problem, I will re-post here.
Dec 06, 2009 | Refrigerators
Hot motor
Replace the start relay and overload. Sea Breeze
Aug 03, 2009 | Magic Chef MCBR440 Compact Refrigerator
The audio/clock fuse blew and every time I replace the 15w fuse it blows
i would try to unplug the clock and the radio change the fuse and see if the fuse blows.
Apr 28, 2009 | Toyota RAV4 Cars & Trucks
Faulty Hotpoint Fridge Freezer
past rulings under the sale of goods act is that if product has lasted a year, then it is of merchantable quality - you are unlikely to get a full refund or free replacement even if you went to arbitration.
but what was wrong with it that your engineer deemed it to be uneconomic to repair?
remember that finding a good refrigeration technician is not easy
Nov 26, 2008 | Hotpoint HTM17BBSSA Top Freezer...
I don't know how to set the temperature setting on my Hotpoint RLAV21 fridge. The dial goes from 0 to 4. For fridges I have had in the past the higher the number the colder the fridge but I've got my...
You should have 2 dials one is the thermostat when you set it all the way one direction it will shut you refrigerator off. Turn it back to about the middle if there are no numbers. The other dial is the air damper between the freezer and the refrigerator. The fan circulates the air through refrigerator by this damper. If you open this open to much your food in the refrigeration section will freeze. Close it back to about 2 that will give you a colder freezer and should be about right for the refrigeration section.
May 17, 2008 | Hotpoint Refrigerators
Replaced ignitor burned up after 10 seconds
ok you might have just got a defective part take it back and get another one it should have a warrenty on it not enough power to blow it like that try another one and let me know
Feb 15, 2008 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RLA21W Compact Refrigerator Logo
291 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
