Question about Sony DSR-1500 Mini DV VCR
Sony DSR-1500P does not load tape
Ive checked cassette compartment sensors in the service menu and they are all working fine. ive also checked the cassette loading motor in the menu and its workingfine. Please advise
  • Luwangula Feb 11, 2009
    The DSR-1500P starts up normally and all front indications are normal. however i carried ot the following experiment: I switched off the machine, loaded the tape in the cassette compartment manually (up to cassette compartment load end position). when i switched on the machine the tape guides took up the tape normally and I could play the tape normally. however when I eject the tape, it will not load it again(acts the same way as if the sensors are dead) except that i know that the sensors are ok!
  • 4,234 Answers
There should be smoe indication on the front of a problem. If not, then the load sequence is not completing and the unit should be sent in for service. These are pro decks that should only be serviced by trained personnel. There are a number of reasons why a taoe would not load. Without seeing the unit, it is extremely dificult to determine the cause. Are there any other details you can provide that might help me to determine possible causes? Can you observe the loading to see how far it gets?
Thanks,
Dan
Posted on Feb 06, 2009
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
I change the belt and now, I have a new problem. The cassette won't go inside the vcr. When I push the cassette, the motor won't start. If I shutdown and shuton the vcr, the cassette goes in and come...
It is possible that there is a fault in the INDETECT section of the cassette detection.
Normally this is triggered when the cassette is pushed into and if there is no detection the loading motor does not work nor the lock is moved to let the tray move on into the loading tray.
So when you put the VCR ON/OFF the detection motor works for a small period of time as a pre check which in the process allows the motor the load the cassette into the section but while it is inside the processor does not get the INDETECT or the IR END sensors to work thereby allows the rejection to be ejected out.
You will need to check the loading detect sensors and the IR sensors for the fault described.
Mar 10, 2011 | Toshiba M784 VCR
DSR 1500P problems loading tape
Are there any indications on the front panel at all? There should be an error code of some sort there. If not, I'll need to research this a bit. Please update this with any codes.
Thanks,
Dan
Feb 09, 2009 | Sony DSR-1500 Mini DV VCR
Fuji FinePix S7000 Digital Camera ''CARD ERROR''
Hi there
Try using the format options in the camera's menu.
Hope this works for you.
Thanks for using Fixya!!
Feb 06, 2009 | Fuji FinePix S7000 Digital Camera
URGENT HELP cassette player problem, please reply
I HAD EXACTLY THE SAME PROBLEM ALL I DID WAS TAKE APART MOVED ALL WHEELS AND COGS IN SIDE AND JUST BLEW OUT ANY DUST CLIPPED BACK TOGETHER AND WORKED FINE PLAYS GREAT HENCE WHY IM LISTING IT ON EBAY.HOPE YOU HAVE SUCCESS
May 18, 2008 | Audio Players & Recorders
Tape stuck in uvw1800 beta cam sp
Use menu system to access "manual eject". Hold left arrow key and press menu to access menu. Follow from there.
Feb 22, 2008 | Sony Betacam SP Small Videocassette 30...
My panasonic palmcorder is having video problems
First of all, try using a head cleaning cassette. Secondly, it is now 24 years old - I am surprised it is still working at all (or maybe you are having it serviced annually ?)
Apr 19, 2017 | Panasonic PV-D308 VHS-C Analog Camcorder
Sony DSR-1500 Mini DV VCR Logo
256 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
