Question about Kenmore Elite HE3 Steam 8674 Dryer
Dryer turns on, but does not run
Our Kenmore Elite HE3 turns on fine. However, after pressing Start it does not run, rotate or heat. There is a click heard after pressing Start, just like normal, but the motor never starts.
  • leslie_sande Feb 05, 2009
    Thank you for your quick response. You were right on the money- our thermal fuse was bad. FixYa saved us an expensive repair call and a lot of time and frustration.
    We will definitely come to FixYa first the next time we have a repair question.
    The Sanders Family
    Middletown, Indiana
    The Sanders Family
    Middletown, Indiana
  • 1,031 Answers
Try to turn the drum inside with no clothes in it, does it turn freely both ways?
Then as someone is holding the start button, hold the door switch button, then try to turn the drum counter-clock wise, and see if it will start turning on its own.
If it does start turning, then the motor is more than likely the problem.
If it dosen't then the timer is more than likely the problem.
Posted on Feb 05, 2009
  • Starnley Johnwells
    Starnley Johnwells Feb 05, 2009
    another possibilty When you tried to restart it and when you turned the drum to try to
    start it, did it make any motor sounds, like a buzz, hum, or grind
    noise?
    If no sounds at all, its possible your thermal fuse is bad.
HE3 Dryer not heating
check the thermal fuse and also check to make sure you have 220v at the outlet.
Jul 23, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he3 turns on but shuts off after 3 to 4 min.
it sounds like the relay on the board clicking off the board mybe faulty
Nov 05, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Wont run
Kenmore Dryer will not start.......hear a clicking noise when start button is pressed...HELP
Aug 20, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
My kenmore elite he3 is not turning on. the timer is working correctly, but when you press the start button it sounds like an overload trips
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
6ter
Jul 11, 2009 | Kenmore Elite HE3 Steam 8676 Dryer
Drum turns...no heat
change the heating elament this is not hard to do it goes back the same way you take it out thank you for useing fixya
please rate me
Apr 19, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
We are new to the Kenmore Elite HE3 8674 dryer and it won't run
Our daugther in law came over, and she forcefully shut the door, and the dryer started working. We are going to have the Sears people to come out and make certain that this dryer is not damaged.
Feb 07, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite He3 electrical dryer runs but it does not heat up
odd but it worked for me!! Try resetting the circuit breaker. It will not appear to have blown, this is because only 1/2 the breaker needs resetting, This is much cheaper to try before calling for service or parts. My 2002 E3t has only had this problem once and the resetting worked without further issues for 2 years now. Good luck
Dec 12, 2008 | Kenmore 82822 Electric Dryer
Kenmore Elite HE3 Steam 8674 Dryer Logo
402 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
