Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Posted on Feb 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does the Wireless G Plus MIMO work with a Cable ISP?
I have the Wireless G Plus MIMO Router that worked fine on DSL I moved this past week and I tried hooking up the Router to the Cable ISP Modem but,I'm not connecting. I use this for the use of My iPod Touch. Does this Router even work with Cable Internet? if not whats the best router for Cable?
Anonymous
Level 2:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 53 Answers
  • Posted on Feb 05, 2009
Anonymous
Expert
Level 2:
Teacher:
Answers
53
Questions
0
Helped
49856
Points
126
Sometimes when you unplug the modem for a while it resets all the settings. if you have a login and password for your isp you will need to log into the router and re-enter the login info to access the isp
I was given a Belkin Wireless G plus MIMO router but i have no idea how to install it.
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
How to connect it to a dsl modem
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
then you need to connect the computer to the router and the modem to the router.
Router stopped working, isp had me bypass router and net worked
and network
2helpful
2answers
My Belkin wireless G router does not seem to work any more. If I connect my router to my DSL modem, I am not able to make a connection to the internet via the router to my iMac. However, if I connect the...
So if you connect the computer directly to the modem , it works .
That means your modem is working properly. Your ISP is DSL connection. Now connect the modem to the router and the computer to the router. Open the router xet up page and change the settings of the router according to the type of connection you have.
There are 2 types of connection in DSL.
DHCP and PPPOE .
Click Here for step by step instructions
4helpful
Belkin Wireless G Plus MIMO router - connectivity problem
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Connect router to playstation 3
You need to first plug the DSL modem into the router. log on to the router. Configure the router byusing the user name and password as supplied by your dsl provider. once the router connects to your dsl provider, you should be able to connect your playstation to the wireless network.
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
2answers
I can get my Usb adapter wirelessG MIMO TO GET AN ip ADRESSE ?
To get an ip address from your router you have to setup the router from http://192.168.1.1
You should already have an ip address setup though.
You need to contact your DSL/cable provider and get access to their website to setup your account information to access the internet. Then you have to setup your wireless connection if you are needing to do so, let me know.
Belkin Mimo Router
If you're connected to the router with excellent stregth then the problem most likly lies in the routers connection to the internet. Check your DSL, Cable modem and make sure the connection to the "Internet" port on your router is good. Try switching out the Ethernet cable if nessciary.
Video chat room
Well, any type of streaming video will need a good amount of bandwith to transfer without interuption. If you were, for instance, plugged directly into a cable or DSL modem and it worked fine, and now youve set up a wireless router and moved your computer across the house... it's possibl;e your computer is not getting a good connection. If multiple computers share the same connection through this router then they are all sharing the limited bandwith you get from your ISP. Try (if possible) moving the router (and or cable/dsl modem) closer to your PC and make sure other aren't online when you are.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
