19'' square monitor shows only 16'' diagonal image. Memory recall makes no difference. Connected via DVI port to PC. Shows DVI in top right corner on startup.
Http://www.manualowl.com/m/ViewSonic/VA926/Manual/155192
http://www.viewsoniceurope.com/uk/assets/059/14388.pdf
if any of this helps you please take a moment to rate with coment
SOURCE: VG910s not recognizing DVI input
Graphics card need setting to DVI out put Check your manual
SOURCE: Constant switch between ON/OFF/source
Does the menu controls work on front panel?If so you can try factory reset or Recall as it is called on some monitors.
SOURCE: No sound when using HDMI cable but I do have sound if using DVI
Is your computer configured to send sound through the HDMI cable as its output device? This might be a setting within your sound card properties.
SOURCE: VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
SOURCE: Viewsonic VG2021m monitor no longer showing a picture
Hi!
there are possible reasons why your monitor shows nothing on your screen...
First, you need to check if the power cable of your monitor is well connected to a wall socket or AVR (and that you are sure there is supply output current on the AVR or in the wall outlet)
IF found that power cable is fix and secure... my suggestion is you bring the monitor to a credible technician...Because the possible reason why only black is seen on your screen, is because the backlight inverter could be busted already.. the backlight inverter which is located on the upper and lower back edge of the monitor is the light source responsible for giving image display of your lcd monitor.. Another reason could be is a deffective high voltage ballast transformer which is responsible for generating high votlage supply for the backlight....
It is too risky for you to do the repair by yourself without proper knowledge and right tools to do this.. So don't waste time consult a technician and or possible avail of the warranty if there is any...
Hope it is clear now to you..
Much appreciated if you rate this help.. thanks..
