Question about Jandy AQUALINK RS TELELINK KIT
Aqualink is running in freeze protect, however pump is not. 20 de
Degrees out. What can I do to keep pool pipes from freezing? Is it simply the pump died overnight. It's 8 years old.
  • texasscuba Mar 30, 2009
    My pool pump keeps running even when my aqualink rs says its off
  • 125 Answers
Freeze protect drops to -20 degrees
need new air temp sensor trade on board with water temp see if it reads different if not need new PCB board
Feb 06, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Aqualink freeze protection
go into system set up find freeze protection highlight what pumps and accessories you want to protect and what temp to activate
Jan 17, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
How do i remove freeze protect from my hand held device
go to system set up find freeze protect any aux that is checked un check and that will un freeze protect it
Dec 10, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
The inside control display on my Aqualink RS4 is red instead of green on the filter pump button. What does this mean?
either the temp is below 38 degrees if so it is in freeze protect if not 38 degrees or lower bad temp sensor go to system set up and go to program go to freeze protect and un check the filter pump
Feb 16, 2013 | Jandy Aqualink Rs4 One Touch Control...
I've got a Jandy PDA, PS4. How can I set the Freeze Protect below 34 degrees?
It doesn't set below the freezing point. That is exactly the point of the minimum setting of 34 degrees - just above the freeze point. If it would set below that temperature it would freeze.
Rod
www.uspartscenter.com
Jan 25, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Freeze protection interrupts spa operation in cold weather
the filter pump is used for other features during spa use disable the freeze protection but turn back on after using spa
Jan 01, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
What is the freeze protection temp on a jacuzzi pump set at?
Pumps don't usually have freeze controls they will usually be in another control. Most are set at 38-40 degrees. All are different by brand but I think any run below 36. Be sure that your air temp sensor is OK if your having trouble, This will show on your control pad, and your temp sensor should be located below your control box by your equiptment. Hope this helps, good luck.
Dec 06, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Understanding how to use spa with freeze protection on
freeze protection will always be on. when you're done using the spa just push the heater/spa button. it will turn off. when ever the air temp drops below 37-39 degrees the air sensor will tell the system the it's getting cold and it will kick on the pump. you can change the it under settings menu if you want other pumps to come besides the filter pump
Nov 22, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy AQUALINK RS TELELINK KIT  Logo
208 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
