Question about Brother MFC-7820N Laser Printer
Printer catridge How to remove the cartridge for refilling
  • Brother Expert
  • 159 Answers
If you just want to REPLACE the toner cartridge, open the front door and jiggle the combined toner & drum units out. push down on a blue tab on the side to release the TN-350 toner cartridge and lift it out of the DR-350 drum cartridge. If you have the toner cartridge out and want to refill it you7rself, DON'T. You can buy toner with about the right size grains, but Brother uses toner with grains that are much smoother and rounder than that aftermarket stuff. The toner is constantly stirred during the print process, and the rough-grained aftermarket toner puts up so much resistance that it often breaks a gear in the body of your MFC. Brother usually doesn't cover that one in their warranty.
Posted on Jun 11, 2009
Canon mp470 can't accept refilled cartridge
Canon mp470 is an excellent printer.I will always recommend using original catridges in your printer.Refilled catridges are not accepted by the manufacturers.Let me tell you i used to work for HP in the beginning of my carreer. I have seen that HP refused to accept refilled catriges. hence i would reccommend you take a cotton cloth ,remove the catridges from the printer.Clean the print heads using that cotton cloth n then reinstall the catridges back .......
Lets see if this resolves the issue
With Regards,
AsitRoutRocks
Dec 17, 2013 | Canon PIXMA MP470 All-in-One Printer
Hi I bought a lexmark S405 and when my ink finished, i decided to refill the black catridge but the print wont print unless i buy a new catridge which is expensive than buying a new printer. I wanna...
The Lexmark S405 printer requires all cartridges to have ink in them to continue printing.
The 100/100XL cartridges are not licensed to be refilled. You can, however, refill the 100A or 100XLA cartridges available on the Lexmark website at http://www.lexmark.com. You should be aware that a refilled cartridge will not be able to report its ink level, and you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
Sep 20, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Have got error 1203 how do i solve ?
This means your catridges overflow, even from new catridges after several prints or right after you refilled the catridges. Follow the steps below
1) open the printer
2)remove the cartridge.
Now look - the problem is not in cartridge, the problem is in scheme from printer that touches the cartridge from behind.
You must clean this scheme from ink with a peace of soft paper ( use the kleanex for example ).
When you'll do this - let the scheme to dry for a while and after insert the cartridge. The Solution:
Use a klennex with a few drops of water to dampen and clean off the contact on the holder.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Jan 10, 2010 | Lexmark P915 Photo Printer with LCD...
Reset ink level on hp 6310 #98 cartridge I have been using refilled cartridges and the in level is ''empty'' even when the cartridge is new and just filled. how can I reset the ink level?
if you are using a refilled catridge you would not get ink levels right.
if you want right ink level use genuine ink catridges.
you can try taking out the catridges turning off the printer and turning it back on and then reinstalling the catridges.it might not help so if possible buy hp ink catridges.
Aug 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
I have refilled my black ink catridge in HP PSC 1410 . now my printer does not print any pages . i have cleaned my printer catridges, still it's not printing any pages . plz tell me the detailed steps to...
Sounds like the printer thinks the cartridge is empty. Old PSC units had a 3 cartridge memory - you kept 3 cartridges and cycled them to trick the printer into thinking it had just received a brand new cartridge, rather than a refilled one.
Jun 16, 2009 | HP PSC 1410 All-In-One InkJet Printer
Cartridge error
In this case make sure that the catridges are inserted in the right slot...... The Colour Catridge should go in the right side and the black Catridges should go on the left side.... Make sure the catridge which u are using on this printer is the right one.......... It should not be a refilled cartridge if it is it will not work because Lexmark printers are not designed to work with Refilled catridges it may damage ur Printer......... If everything here is fine just take out both the catridges...... Take a Dry Paper Towel........ Clean the copper contacts on the printer as well as the Catridges....... Unplug the Power Supply from the Printer............ Replug it in and if still it says catridge is missing then may be a problem with the catridges.............. Hope it Works..... Good Luck........
Jan 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
Hp psc 2210 remove and check catridge DISPLAY MESSAGE. I REFILLED CATRIDGE.
If you refilled your cartridges.]
Make sure they are not overfilled.
Check by removing the cartridge and see that they do not
have a large amount of ink on the printhead area
Dec 20, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Brother MFC-7420: Toner low - massege. But catridge is full.
The magic word is "refilled." Not all refilled cartridges work correctly. Try another cartridge (a new one to be absolutely sure) to verify the printer is working properly. But my money would be on "defective refill."
Dec 05, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7820N Laser Printer Logo
123 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
