Question about Panasonic KV-S2026C Pass-Through Scanner
Scan only in jpg.
My Panasonic is only scanning in jeps. I need to set it to tif's. Can anyone help me with this problem?
Thanks
  • 490 Answers
If you want to scan in TIFF, you need to scan in monochrome only. (B&W). Change SCanner settings.
S. Mohan, Chennai, India
Posted on Feb 06, 2009
There is no option to scan as pdf on my 4625 HP scanner (tif, jpg etc are available), how can I add pdf?
The HP SCANNER SPECS say: Scan file format Bitmap (.bmp), JPEG (.jpg), PNG (.png), TIFF (.tif), PDF (.pdf), Searchable PDF (.pdf), Text (.txt), Rich Text (.rtf).
That means it is supported. What you can try is to try and uninstall ("Programs and Features in Windows) the Adobe PDF program and get the free one to install again from: http://www.adobe.com/products/reader.html
If it still doesn't work (links itself into Windows and the HP software), try reinstalling the HP software or go to HP.COM and you can download the latest full-version file for your 4625 printer.
Dec 02, 2013 | HP DeskJet Office Equipment & Supplies
I need to scan documents in jpg format. I notice there is an option to choose tif/jpg but I don't seem to be able to choose the jpg option it just keeps choosing tif. How can I scan in...
Everyone above has cut and pasted from the Ricoh manual, which as any tech will tell you is worthless. There is some other setting that must be set to force the "TIFF/JPG" to toggle - hence why no one has figured it out.
Jun 17, 2011 | Ricoh Office Equipment & Supplies
I want to save my scan as .pdf , but i dont see this in the list ( jpg, tif...)What do I do
OK well sometimes ya can't scan to PDF as is. What you can do though is scan as say JPEG and convert it to PDF with a PDF converter
Use this..www.dopdf.com/
Of course you can get programs like Adobe Professional that will scan straight to PDF.
Jan 26, 2010 | HP Officejet 5610 All-In-One InkJet...
How to scan a document where it doesn't take so much space? When I scan a contract of 8 pages it is like 13MB. I need it to be smaller like in KB.
One of the main ways to reduce document size is to consider what format you are saving them as.
I just did a sample scan and the following are the results of different formats:
.png - 88 KB
.gif - 108 KB
.bmp - 192 KB
.tif - 196 KB
.jpg - 1.14 MB
As you can see the JPG file is over 10 times larger than the PNG file.
Also make sure that you do not scan as a color scan if it is not needed. The above scans were all scanned in black & white.
I hope this has helped you. Thanks for using Fixya.
Wayne
Jun 27, 2009 | HP Office Equipment & Supplies
Scan in JPG
JPG is possible only with 'Grey' and 'Color' Scanning options. With Black & white it will be only TIFF.
S. Mohan
Apr 06, 2009 | Acer Office Equipment & Supplies
How to scan pictures and put them into the
Are you sure this is your question?
Connect the scanner, power on the comp and install the device driver, when asked for. Install scanning software that comes with the scanner and readu you are.
Depending upon the document, select color/grey/mono settings. B&W is generally TIF and Color/Grey is JPG format, however other formats are possible.
S. Mohan
Mar 22, 2009 | Office Equipment & Supplies
Hi,I have got a Canon,smartbase MPC 400 printer/scanner. My question is: How can I scan a document straight to a PDF file,because it only gives me options for TIF,BMP and JPEG. I have downloaded a TIF to...
I'm using an MP780. Usually when I scan an image to jpeg I press START, CANON, SCANGEAR STARTER. This open a window to ScanGear MP. Since I use the Advance Tab I can set the DPI and whatever outputs. The DPI rsolution will determine the size of the file also. When it is finished scanning it goes to the next window which has Save As Type and Save Scanned Image to. Save As Type is where you can choose JPG or TIFF or BMP. Hope this helps.
Nov 13, 2008 | Canon Office Equipment & Supplies
HP 6210 Scan issue
Hi if u r not getting the jpeg option do one thing
open the cd content, go to setup folder
in which u ll see trayapp folder open that one
there u ll find trayapp.msi right click on it and click on repair ... then reboot the pc and try to scan ... it shud work else get back, i ll give u the other options
May 19, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Scanner problem
Hi BethKay,
What it's telling you is that the "filename" that the scanner/software package is trying to use to save the document being scanned to your hard drive has reached it's limit in the amount of times that it can be incremented by "1". In other words every time you scan a document it is saved to a directory or folder on your PC under a filename which is probably assigned by default. This filename has a "suffix" which is also assigned by the scanner/software eg. filename01.tif (or jpg, etc) filename02.tif filename03.tif and so on. Either I'm way off base or you must have scanned a whole bunch of documents using this naming convention because the scanner/software has run out of numbers that it can affix to each individual file. What you need to do is either 1. Change the folder that you are saving the documents to or 2. Change the pre-suffix filename in order to retain individuality.
Make sense?
Let me know if this helps and good luck.
J
Feb 22, 2008 | Microtek ScanMaker 3800 Flatbed Scanner
Why can't I scan when an ink tank is empty?
look into the options for your printer. you should be able to assign file extensions, i.e. .BMP, .JPG, .TIF, GIF etc to your scanned documents without printing them. No ink effects print functions or copy functions.
Sep 11, 2007 | Brother DCP-110C All-In-One InkJet Printer
Panasonic KV-S2026C Pass-Through Scanner Logo
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
