Question about Compaq Presario Notebook
TASKBAR BECOMES COMPLETELY NON FUNCTIONAL
TASKBAR REMAINS COMPLETELY NON FUNCTIONAL UPTO ABOUT 5 MINUTES AFTER THE START UP.WHEN I TRY TO STANDBY THE SYSTEM BY PRESSING fn+f5,ON LOGGING IN TASKBAR DISAPPEARS AFTER WHICH I HAVE TO TURN OFF USING HARDWARE POWER BUTTON .I HAVE SPYBOT,ADAWARE,SPYWARE DOCTOR,SUPER ANTI SPYWARE,AVG,THREATFIRE INSTALLED.WHAT TO DO?PLEASE HELP.THANKS IN ADVANCE.
  • 58 Answers
Maybe you should collect all important information, and make a clear install of Windows!
Posted on Feb 05, 2009
How do Transfer data from my old tracfone?
Here is the information from the Tracfone website.
Transfer Number > Phone Upgrades
  • What is a phone transfer?A transfer is when you wish to transfer your phone number and minutes from one TracFone to another.
  • I just bought a new TracFone. How do I transfer my phone?
    In order to transfer your phone, go to the "Activate/Reactivate Phone" button on our website and then select the option that you need. You can also contact our Customer Care Center at 1-800-867-7183 so that a representative can transfer that information for you. Please note that when you complete a phone upgrade from a smartphone to a non-smartphone, you will not be able to transfer any remaining minutes in your account, so you will lose those minutes.
  • If I buy a new TracFone, can I transfer my remaining minutes and phone number to the new phone?
    Yes, you can transfer the minutes and phone number into your new TracFone by going to the TracFone main page and clicking on the "Activate/Reactivate Phone" button. Then, select the option that you need (phone, SIM, or Bring Your Own Phone CDMA). You can also contact our Customer Care Center at 1-800-867-7183 so that a representative can transfer that information for you. Please note that when you complete a phone upgrade from a smartphone to a non-smartphone, you will not be able to transfer any remaining minutes in your account, so you will lose those minutes.
  • If I currently have a TracFone smartphone and want to transfer to a non-smartphone, will I be able to transfer my remaining minutes to my new phone?
    No. When you complete a phone transfer from a smartphone to a non-smartphone, you will not be able to transfer any remaining minutes from your old phone (so you will have to forfeit those minutes), but you do get to keep your service days.
Apr 30, 2016 | Motorola Mobility TracFone w175 PayAsYouGo...
I need to find how to program a transponder key on a 2007 Chevrolet Equinox , VIN starts with a 2
This 30-minute learn procedure should be used when all vehicle keys are desired to be replaced or reprogrammed. This procedure will erase all previously learned vehicle keys from the TDM. Once the 30-minute learn procedure has been completed, any remaining vehicle keys may be programmed using the Adding Keys procedure to ensure their continued functionality.
  1. With an unlearned master vehicle key, turn ON the ignition, with the engine OFF.
  2. Observe the security indicator, after approximately 10 minutes the telltale will turn off.
  3. Turn OFF the ignition, and wait 5 seconds.
  4. Repeat steps 1-3 two more times for a total of 3 cycles or 30 minutes.
  5. Important: The TDM learns the key transponder information upon the ignition switch transition from OFF to ON. You must turn the ignition OFF before attempting to start the vehicle.
  6. With a master vehicle key, start the vehicle. The vehicle has now learned the key transponder information.
  7. If additional keys are required to be learned, refer to Adding Keys.
  8. With a scan tool, clear any DTCs.
Mar 13, 2016 | 2007 Chevrolet Chevrolet Equinox LT
My 88 Chevy s10 blazer won't start did complet Service on change fuel jets mapsencer.still nothing
1. try to remove positive power cable from your battery and wait for 5 minutes.
2.while waiting for 5 minutes,Drain all remaining power by switching your ignition to ON,switch on your headlights,step on your brake pedals
3.switch off your ignition ,including your headlights
4.install back your positive power cable to your battery
5. try to start your engine
Sep 04, 2015 | Cars & Trucks
Listening to radio and it just went off, standby light not on, completely dead, changed the fuse in the plug, that wasnt the problem - help
If the standby light is not ON but there is power to the circuit, check the +5 to the processor section. If this is present you need to check the processor for oscillation ( Only if equipped) If not the fault relates to non functioning of the processor controller.
Jan 31, 2013 | Audio Players & Recorders
I have a sony 32 inch lcd tv and if i leave it in standby overnight it sticks in standby no keys work, if i turn it off at the socket then back on its fine,any ideas?
There are two possibilities for that symptoms,
Either standby power supply becomes low (less then +5 volts) so system control chip lose its function OR system control itself stops its function.
Unplugging TV resets system control and it starts work again.
First confirm standby supply is OK, if found good and correct +5 volts, then replace main board that has system control chip.
Let me know exact model number of your Sony TV written at back to find out boards and prices.
Thanks.
Nov 03, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
VCR dead
Go to local Thif stores or Pawn shops you can buy a working VCR for$ 5.00-$20.00 ,you have a power supply problem.
Jun 23, 2009 | LG Televison & Video
All i get is the welcome screen and no light by the standby button. it has power
If normal operation has the welcome screen dissapear after a few seconds followed by working properly, it appears the internal software is corrupt or buggy.  Try a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If this doesn't resolve it, the Toshiba will require service for defective software.
Mar 26, 2009 | Toshiba SD-H400
I need a service/repair manual for a Pioneer SD-643HD5.
you dont need a service manual. the problem is the convergence chips and it has been plaguing these pioneers for years it is either the bad solder joints on the chip itself or the chip is trash anyway go to tvrepairkits.com and they will help you get everything u need
Mar 26, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Power on problem
Many of the later model Sony TV?s have a built in self-diagnosis function. AKB circuit (automatic kine bias), the timer/standby indicator blinks 5 times for about 30 seconds then goes to the self-diagnosis function. In other words, the IC chips on the Cboard are burned out. This repair is not one that should be attempted by the end user. This repair will need special test equipment. You will need to take it in for repair. It shouldn't cost more than $170-$200. This is cheaper than a new TV set.
Jun 23, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
Compaq Presario Notebook Logo
57 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
