Question about Lexmark X4270 All-In-One InkJet Printer
Faxes are not coming in but are going out.
I have others faxing information to me but the fax won't come in. The machine is ringing, indicating that a fax is coming, but then the screen is saying "Press Start", and then nothing comes over the fax. I've never seen it say that. What could be wrong?
  • bwmechanical Feb 05, 2009
    Faxes are going out but not coming in. The connection is there for sure and the machine works fine.
  • HEC101 Feb 11, 2009
    I ALSO HAVE THIS PROBLEM, BUT I NEVER SEEN ANYTHING ON HOW WE COULD FIX THIS PROBLEM.. WE HAVE CHECKED OUT COMPUTER AND PHONE CONNECTIONS.. HAS THING WORKED IN THE PAST OR COULD THERE BE ANOTHER PROBLEM WE AREN'T SEEING
  • 64 Answers
That happened to me before, be sure to check if your fax is technically working. also if its connected to your phone connection.
you also might have to check for the ink and paper because all in one printer with fax on it are usually very sensitive when it comes to ink management.
Posted on Feb 05, 2009
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Dec 03, 2010 | HP Officejet J3680 Multifunction Printer...
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Dec 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Why wont faxes come through
you hve to go to the settings and mark the easy incomming fax or duel mode fax box than you will get your faxes
Apr 08, 2010 | Samsung SF-560 Plain Paper Laser Fax
Hello have one line for phone and fax where or how do i set up different ring tone to differentiate call from faxes sent in
You really can't affect the ring sequence because that is controlled by your telephone company and they can'ttell it is a fax.
The first indication of a fax message is when your machine emits its fax tones and the other end responds to it. This all occurs AFTER the ringing.
Jan 19, 2010 | Canon LaserClass 2060P Plain Paper Fax
Will not receive faxes. Line rings when phone was
make sure the mode switch is set to "fax"... not "tel", or "fax/tel". I think the mode indicator is on the top of the fax machine and it's a light that should be on next to "fax"
Oct 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
My fax machine will send faxes but not receive them. I have made sure it is plugged in and connected but no faxes will come through. Please Help!
If you have an answering machine, have it answer at three rings. Have the fax answer at five rings. Let the answer machine go thru it's cycle, and see if the fax picks up.
Apr 27, 2009 | HP 1220 Plain Paper Inkjet Fax
Cannot receive or send faxes
See user manual for setting ring sensitivity. This may be where your problem is. Hope this information was helpful!
Mar 12, 2009 | Brother IntelliFax-2820 Laser Fax
Problem receiving fax from outside source . phone rings acknowledges receive on screen but no fax comes through. other source sends faxes to other sources no problem & i receive faxes from other...
In the last statement you said you RX faxes from other sources? which means you can't RX from one or a certain source??
1- could be area code
2-could be your memory is almost full and their faxes are too long
Jul 31, 2008 | Samsung Office Equipment & Supplies
Incoming Fax Problem
Sounds like phone line issue to me like noise on it at times did your phone provider check it?
Dec 22, 2007 | Brother MFC-8840D All-In-One Laser Printer
Set up
Make sure ECM is turned on. Do not turn on Junk Fax because you will most likely block other faxes.
If you really want the fax machine to work properly, you should connect it to a dedicated line.
You will be disappointed with performance if you try sharing it with other items on the same line.
Reasons, your fax line will be busy when your other functions are being used, and obviously you will miss faxes.
If you are taking a call or message when fax comes in, if the machine is made to give faxes first priority, you will be disconnetcted.
Also, which one do you want to set to pick up first?
The fax machine answers on a certain ammount of rings and so does Voice mail. Which has priority to you. DO you want to miss faxes for messages, or messages for faxes.
Set up vioce mail for 3 rings and fax for 4, then you miss the fax. Reverse it and you miss the message.
Just telling you, I have people call all the time for issues with faxes on the same lines with other items, Answering machines, credit card billers, other phones, etc etc etc.
Good luck. But putting multiple items on the same phone line is setting you up for disappointing performance. And it will not be the problem of the fax machine, It is designed to do what it is supposed to.
Just telling you the truth up front. If your faxes and messages are both important to you. You need a dedicated line for the fax.
Dec 05, 2007 | Brother IntelliFax-2820 Laser Fax
Lexmark X4270 All-In-One InkJet Printer Logo
48 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
