Question about Linksys Wireless-G WRT54G Router
Configuring WRT54G i have just reformatted my window XP. found out that i cant connect to the internet. i tried using the router disk to install but couldn't. a "thank you for using linksys" show up on the main menu where the "click here to start" icon is supposed to show up according to the manual. also in frustration, i have press the reset button on the back. so i dun know what to do now. BTW i connect my XP to the WRT54G using a ethernet wire(not wireless)
  • 64 Answers
There are many ways to setup/configure a wireless router. the easiest way for me is to plug your modem to the router, (even though unplugged, there should be a wireless network signal on your device that has a wifi but no internet connection) once connected, plug the modem to the wireless router then reset it, wait a few seconds then you'll get an unsecured network with internet access on it. usually, the only use for the cd is to make you configure it easier like putting a password on it etc.
Posted on Feb 05, 2009
I am not able to connect to the internet using my Linksys WRT54G V8. When I connect the cable directly to my laptop, I am able to access the internet, so it is definitely a problem with the wireless...
Title: Setting-Up a Wired Computer to Obtain an IP Address Automatically Article ID: 4033
Configuring a wired computer to get an IP address automatically will enable it to get an IP address from a DHCP server. Instead of manually entering the IP settings which will consume much time, performing this procedure will ensure that the computer will get the correct TCP/IP settings.
Configuring a computer to get an IP address automatically is useful when:
  • Connecting a computer to a network with a DHCP server. Ensuring that the computer is getting the correct TCP/IP settings.
To configure a computer to automatically get an IP address, you have to check the TCP/IP properties of the Ethernet Adapter installed on the computer. Follow the steps below for instructions.
NOTE: Make sure the wired computer is properly connected to a network with a DHCP server.
Checking if the Computer is Set to DHCP
NOTE: The instructions provided below only apply to Windows 98, ME, XP and Mac operating systems. If you are using Windows Vista, click here for instructions. For Windows 7 users, click here for instructions.
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 29, 2010 | Linksys Wireless-G WRT54G Router
Tip
Full details on how to set up your Wireless-G WRT54G Router
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at
the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network.
Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other
end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a
standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical
outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result
in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each
other across a network, such as the Internet.
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router.
The next few pages tell you, step by step, how to configure your network settings based on the type of Windows
operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network
adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/IP line for the applicable Ethernet adapter.9641e30.jpg
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
itself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.a443500.jpg
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart
your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area
Connection listed). Double-click the Local Area Connection. Click the Properties button.ea4fa3a.jpg
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the
Classic interface (where the icons and menus look like previous Windows versions), please follow the
instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon.
Then click the Network Connections icon.
Connection listed). Double-click the Local Area Connection. Click the Properties button.f2e300e.jpg
button. Click the OK button again to complete the PC configuration.
If you would like more information on setting up your connection, please ask me a question.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
on Jun 28, 2008 | Linksys Wireless-G WRT54G Router
I just bought a laptop with Windows 7. I have a
hi,
for you to be able to configure the modem to the router,you will need to set the modem to bridge mode first for you to be able to give way for the router,try to contact verizon and let them bridge the modem then right after that,thats the time you will configure the router
thanks and God Bless
Jun 26, 2010 | Linksys Wireless-G WRT54G Router
Cant setup or connect to internet through router
Different ISPs require different configurations. If you have a Linksys router, such as the WRT54G, there are 2 ways on how you can configure it, either by running the Setup CD or by doing manual configuration. This particular router has its own web utility and you can access it by typing its IP addres on your web browser, ex. http://192.168.1.1. By default, it doesn’t have any username and its password is admin.
Once you’re inside the setup page, you can configure now the router for DHCP, PPPoE or STATIC IP settings. For DSL customers using a PPPoE account, some modem needs to be configured into BRIDGE MODE first and then the router will be set to PPPoE with the correct username and password (given by ISP). If your a DHCP account, modem doesn’t require any configuration. It will work with its default setting and the router would be set to DHCP. Once done, powercycle your devices to establish internet connection.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
About a week ago my HP Pavilion DV4000 couldn't pick up my wireless linsys G router and said that no wireless connections were found. I had to use a wireless B card I had lying around but still having...
You are using a B wireless adater on windows XP computer.
Tere might be adapter utility installed on your computer. You can use that software to connect to the wireless network or you can switch over to windows software to connect.
It will be better if you use the WINDOWS XP to connect to the network.
Check the wireless settings of the router also.
Click here for more information
May 03, 2010 | Linksys Wireless-G WRT54G Router
Lost my disk for Router in the move.What can i do
The really don't need a disk - just plug it in and go. You may need the directions (default IP address) which can be found at the linksys website.
Feb 05, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect my laptop to internet through router wrt54g v8
Make sure you have ipx and spx protocol installed, and a home network setup through windows. Also if the first try don't work make sure you firewall setting is not blocking your router.
Dec 03, 2009 | Linksys Wireless-G WRT54G Router
Signals
Do you have a wireless adapter installed on your win 2000 computer?
Jul 01, 2008 | Linksys Wireless-G WRT54G Router
Cannot connect my wifi laptop to the wireless router
If you use your original Win XP disks, there's a chance you now have XP SP1 (Service Pack 1). Make sure you've made all the necessary Windows Updates as working with WiFi networks was enhanced with XP SP2. Then you can try to find your wireless network and connect to it. If you had a secured network you'll need your previous network key (similar to a password, but without a username, the wireless key is needed to exchange data with the router) If you can't remember the settings on your Linksys you can reset it to factory settings with inserting something into the reset hole to press the hidden buton and holding it for several seconds until lights on the front flash. Then you HAVE to run the initial install procedure (find your CD and Quick Start sheet) because your router will be open and unsecured.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
Linksis wireless computer setup for WRT54G model
in product damage.
Overview
the Router.
Connections icon.
Dec 28, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
102 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
