Question about Samsung DVDR120 DVD Recorder
How to finalise dvd recording
I have lost manual to samsung dvd r122 recorder and dont know how to finalise disc. also is it possible to finalise disc i have recorded but ejected before finalising as the recorder does not accept disc when inserted into player. muchly appreciated if anyone can solve these problems
    Champion:
  • 236 Answers
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Posted on Feb 09, 2009
  • Artie Feb 12, 2009
    I omitted one step: After pushing "menu" go to Disc Manager and then to Disc Finalise and follow directions.
Tried to record on a DVD-R disc, but unit said that the disc was full. I then tried to finalize the disc, but the unit got stuck in the finalization process. I unplugged/replugged the unit to make it...
The most likely reason the unit got 'stuck during finalisation' is probably because there was insufficent space left on the disc for it to write the respective lead-out/menu data (or perhaps there was a bad disc sector) - disc full? Because you unplugged the unit from power point before it had finished, the disc is possibly corrupted now. Throw that disc out.
The manual clearly warns: Do not disconnect the AC power supply cord while finalising. This
can render the disc unusable.
In other words, you have lost that particular recording and you are wasting your time with that disc.
There is nothing in the manual to suggest the length of time required for DVD-R recovery - there is a recovery process for the whole unit (such as after a power cut while recording a timer program for example) but not for discs. I may be wrong here...
However, the upshot is you have lost a disc, not a recorder. Another drink coaster for your living room.
Mar 29, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
My camcorder will not give me an option in disc operations to finalise a disc which I recorded on (which I did initialise before starting- I have also tried it on another disc, initialise, record etc) I...
Are you using the AC adapter when trying to finalize? You cannot finalize using battery power only.
Link to your manual:
Canon DC210 Manual
(What format discs are you using?)
Instructions for finalizing begin on page 61.
Hope this helps.
Thanks for using Fixya.
Mar 11, 2011 | Canon DC210 DVD Camcorder
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
Recorded DVD will not play in another player
Hey,
Maybe the format of your recorded movie didnt support your player..check out your manual for the supported formats and check the format of your recorded movie.If any of the format in the manual matches your movie format then it will definitely play..
please rate my suggestion..
Apr 15, 2009 | Televison & Video
How o i finalise discs on my wharfedale DVDR24HDF RECORDER
went into set up menu ,went down to bottom option ,PREFERENCES,went to edit disc where finalise disc is .pressed select and finalized disc.
Nov 12, 2008 | Wharfedale DVD-M3 DVD Player
Digital cam vp-dc161
what ever size disc your using simply dont record the whole disc, example if you are recording on a 30min dvd-r only record 28mins then finalising will not be a problem.
Aug 29, 2008 | Samsung VP-DC161 DVD Camcorder
Samsung DVD recorder R122 spits out discs randomly
Go to Samsung .com aand ask for tech help its free
Jun 12, 2008 | Samsung DVDR120 DVD Recorder
Magnovox Dvd Recorder closing out disk
Put the disc back into the recorder.
Goto the setup menu.
Select Disc Edit. Press OK
Select Finalise. Press OK
Your DVD player is made by Funai (for future reference)
The User manual can be downloaded HERE. You need page 38.
Apr 16, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Samsung DVDR120 DVD Recorder Logo
887 people viewed this question
Jerry Greenberg
Jerry Greenberg
