Remotecontrol will not work the receiver
The remote has atouch screen. when you touch a function it shows that a signal is being sent.however the receiver doesnot respond. i noticed the little red light on the front of the receiver that an incoming ir signal is being received no longer flash''s
  • 3 more comments
  • dixiesdandie Feb 06, 2009
    the remotecontrol kenwood model rc-r1008 came with the receiver model vr-3090 and also operates kenwood 200 disc cd changer model #cd-328om thru communication cables and system control cables
    I removed the batteries and held the power button for 30 seconds and tried again. It did not work. could it be the ir sensors in the receiver or the remote.
    did you get last message
    the remote seems to work on tv^s cd player anda vcr it will not work the receiver functions at all including surround settings volume and tone. this remote has a [selecting the model type] feature witch i did along time ago. the book says the model type information is stored permanently ; even after resetting powertouch you will never have to reselect the type. however it doesnot seem to recognise the receiver and it wont let me reselect the model type . so it is either that or the ir input on the receiver one more question . on a parts page i found an optic receiving module ov part no#wo2-2591-05 for this receiver is this the ir receiver in terminal . there was no description available
    thankyou manojro . resetting the receiver did the trick i found a couple of other things also that probably caused this mess apparently while cleaning someone pulled sl16 system control cable and a text cable loose i lost all my text from my 200 cd changer. oh well/ at least i have tunes now.
    Master:
  • 848 Answers
Hi
The sensor in receiver is not working ........perform reset in receiver unplug receiver for 10 minutes and plug back .....check sensor works ....if sensor in receiver still not working ..... you need to replace sensor board in receiver.....
Posted on Feb 06, 2009
  • 495 Answers
"First try replacing the batteries if you haven't already. If that doesn't help, try resetting the receiver. Simply unplug the receiver, then press and hold the power button on the receiver while you plug it back in. Turn the unit on, and the display should say 87.50 to confirm the reset. If the remote still does not work, use a digital camera as an eye, face it towards the IR of the remote control. Depress any of the remotes buttons; you should see IR flash each time a button is pressed. If not then the problem is with the remote. If the remote works fine, then the problem is with the receiver. In order to determine the cause of the problem, I suggest you take the defective unit to a Kenwood authorized service center for evaluation.
The second fix involves some very simple soldering, and has been endorsed by many as the solution:
http://www.remotecentral.com/cgi-bin/mboard/rc-theater/thread.cgi?3016%2C3
I hope this helps. Good luck and please let me know if this solves your problem!
  • 139 Answers
Remove the batteries and press the power button for 30 sec and then plug in the batteries and try now.
  • 13,433 Answers
Hi
What is the model and brand of the remote controller and also the brands and models of devices your using it with. Is this a universal remote controller or did it come with a spesific device?
  • Ekse Feb 06, 2009
    And the remote works with other devices but this one receiver has stoped showing the led when ir signal is incoming, do other devices that run on ir work with the remote?
    If the spesific receiver doesn't work with the remote but others do, the issue is most likely in the receiver, try reseting it or unpluging it for a few minutes and try again, if the ir light doesn't light up. It would sound like a problem with the ir receiver.
Dont have remote stuck on v-chip rated G
I had a remote problem and finally sent off to www.remotecontrol.com and bought a new remote for my t. v. Hope this helps in some way.
Apr 15, 2016 | Televison & Video
Remote control stopped working changed batteries and still not working
Here are a few suggestions to help you with this problem:
It is possible that the battery contacts are corroded so you might try expecting the contacts and cleaning them. Since you cannot see if the IR signal is being sent, you can use another IR remote that you know works and see if you can Jam the signal of the working remote with your Hql-260wr remote. To do this, push the volume up button on the TV remote and hold it down while at the same time using the known working remote to control its companion product. If the working unit stops responding correctly when the volume button is pressed, it is transmitting an IR signal.
In this case, since you confirmed that the remote is transmitting, you can make sure that you are on the correct device settings for the remote. If you select the TV setting for instance, see if the remote now can control the TV. The main functions to try first are volume and channel buttons.
If this does not work, you will need to find out where the IR receiver is on the TV and make sure that the receiver lens is not blocked by something such as another device like a video console, etc.
Apr 03, 2015 | Televison & Video
Dual control noted on Dish tv screen but cannot change stations separately on both tvs
Each TV receiver has to be fed with a separate cable from the lnb. They can not be bridges or split.
Mar 09, 2015 | Dish Network/Pansat Dish Network Dish 500...
I have a Sony CDP-CX350. I recently discovered the remote will not control anything on the player. The remote has fresh batteries and displays that a signal is sent out. The same display usually shows...
If you have turned it back on then this would indicate the receiving module that picks up the infrared signal is not working and has become defective, but I would double check your manual so nothing was over looked.
Jan 30, 2011 | Sony MegaStorage CDP-CX355 300-Disc CD...
Panasonic AC Model CS-A28BKP5 remote not working. Remote does not work....Replaced with a new remote however still no joy. Checked remote and is functioning correctly ....unit can be turned on and off...
If receiving signal in unit and calling signal in remote should be functioned properly. If any one of these, defective you can't operate by remote.
In your case, it's receiving signal in PCB is weak or defective. You can repair/replace only that portion. Call repairman to arrange for it. Thanks. Helpful?
Jan 20, 2011 | Heating & Cooling
The remote does not work
Hello my Marantz dv4100, didnt respond to my remotecontroll, Remote was working. remote from my philips dvd722 works fine with this Marantz-dvd too.
i found 2 solderings at the back of the front circuitboard in remotecontroll receiver optounit at the left side of dvd-display, pins 1 & 2 needed resoldering, had cracks in solderings. after that it was working fine again.
hope this helps u too.. good luck!
Dec 23, 2010 | Marantz DV4100P DVD Player
I have a kelvinator kwh35hra room a/c I habe fault code e0
Code E0 Error detail Remotecontrol transmission error (signal receiving error)
Inspected unit Remote control
Dec 08, 2010 | Heating & Cooling
All of a sudden my "Touch screen" does not work!
My older garmin came with a remote and my touch screen went bad. So in order for me to use it at all, I have to use the remote control.
Aug 02, 2009 | Garmin Nuvi 660 GPS Receiver
Remote control vs tv led
On the little PC board which has the pushbuttons on it, mounted right behind the buttons on the front of the TV, is the remote (IR) receiver. It is a little black box with 3 leads soldered to that board. One pin is grounded, one pin is +5 volts and the third is signal. The signal pin should be a little less than 5 volts, and when you use ANY remote the signal pin should have inverted digital data (about 4.5 to 0). If you measure the signal pin and it is near zero volts, replace the receiver. If the signal pin is around 4.5 volts, replace the remote.
Dec 03, 2006 | Zenith C27A24T 27" TV
 Grubhead
Grubhead
