Question about BenQ PB8220 Multimedia Projector
Benq pb 8220 Blue screen, no picture and will not show menu
O switching on, the fans run, the lamp lights and shows the Benq Logo, then it shows a blue screen, it will display the lamp life icon and that can be reset. But it will now show the menu, source or picture. I have tried different inputs, i.e. a pc, camcorder and game console but still no image.
Hope someone can help, Thanks
  • 23 more comments
  • ecoulton Feb 06, 2009
    Thanks, but it will not show anything other than the lamp life monitor, it will not display menu or source icon or input images.
    Will gladly accept anything else you could come up with!
    sorry but i need more advice
    Thanks but that was the first thing I did, and have reset counter to zero. But the problem is still the same, blue screen, no picture, no menu, no source icons.
    Thanks
    I have e-mailed benq, but still waiting on a reply.
    It was working fine, turned off then this. Have found out that lamp has not been changed, at all, so before I buy a new lamp, how do I know.
    Thanks
    Am an electrician, have done that thanks
    Thanks for the idea, will check tomorrow. But unit had been fixed to a ceiling so no knocks or bangs!
    Why would lamp life meter show and not menu?
    Thanks for the idea though
    Thanks for that was looking for a usb lead myself at the time.
    Good idea, found a lead to suit, need firmware now. Would you need the projector switched on or off to reset?
    Sorry but unit does not switch off nor are the led's flashing or staying on!
    Thanks
    thanks looking at pres myself on the web. I have no cd , would be grateful If you managed to locate one.
    Thanks Will let you know
    The projector does not state that the lamp needs replacing, it did state that there was 750hrs used before I reset it. I have just tried to connect it to an x-box and I now have audio, but still no picture.
    Thanks
    I get the benq logo, so the default screen has not been changed, it is after that, the screen goes blue.
    Thanks
    Hi thanks.
    Have an X-Box connected to it at pres , have sound, lamp on, fans running, no red led's just showing blue screen. Have checked remote, the buttons not working are, exit, menu, auto, pip and freeze. All the rest do, how can I get Menu or source?
  • ecoulton Feb 07, 2009
    It shows the benq warm up screen, then shows a blue screen only
    Good idea, how do I do that, with a blank blue screen? The menu does not show up using the button on the projector, or on the remote.
  • ecoulton Feb 09, 2009
    Thanks for tried connecting to a pc using the rgb socket but still no joy. How come the Benq warm up screen shows but not the picture?
    Tried hooking up to an xbox console, still no good. Is there a reset button? or could it be frozen?
    Stripped it down and cleaned all dust traps and given it a full service.
    Still the same i'm afraid!
    That sounds a bit more feasible.
    Is there a way to prove it's the board and
    where could I obtain a new board from?
    The lamp is lit and I have audio, just a blue screen
    How do I check to see if its frozen?
    Thanks for the links.
    I have emailed Benq
    Thanks for the comment about the lamp, but I don't understand how I get the Benq warm up screen though?
    I don't want to buy a lamp and then find out that's it's not the lamp.
    Thanks for the link, But I already have the manual, not that it much help.
    Thanks Dan
    Been the best solution provided so far, will see if I can locate a repair center.
    Genius:
  • 1,913 Answers
Can u try without your memory card .also reset all settigns .Refix your battery .
Posted on Feb 09, 2009
  • 4,234 Answers
Based upon the symptoms you describe, this is what is happening:
1) The default screen is the blue screen. This is displayed when there is no input. (First indication that the input is not being seen)
2) The menu screen is generated internally and is further along the video path than the inputs. (This means that the input board is probably OK)
3) If you continue to get only blue, than the video processing section is faulty. This is AFTER the character generator and menu sections. This section is not considered a user replaceable section as it resides on the main board.
The main board contains all of the particular information about your sepcific projector including all of the convergence and alighment information set at the factory. Convergence and alignment requires specialized equipment.
Unfortunately, this is not a problem that can be solved by the user. This unit must be sent to an authorized service center for repair.
Dan
  • 350 Answers
  • 15,935 Answers
The input board has failed.
The benQ logo and menu are loaded into prom, so there is no input signal necessary to show those items.
BenQ uses proprietary circutry, so you would need to call them for repair/replacement parts.
CLICK HERE for your user manual.
CLICK HERE to be directed to BenQUSA service.
Toll free number for BenQ tech support is free if projector is still under warranty - 1-866-600-2367
Thanks for using FixYa - a FixYa rating is appreciated!!
    Brigadier General:
  • 3,614 Answers
Related problem needs the unit clean once you have a "dust blobs"
better reassemble the unit and clean the lens,
this few steps gives you an idea on How to clean the unit;
  1. Underside of the projector. you can find the filter under the hatch on the left side, lamp is under the hatch on the right rear.de of the projector.
  2. Filter hatch opened and fan bracket removed. Filter is gray foam in lower left. Clean the filter with canned air or wash and dry thouroughly before replacing.
  3. Clean the projecter using a canned air.
  4. Hold the unit vertically to avoid any liquid get inside of the parts
  5. On the LCD and polarizer area. You've got to blow out all the crevices in this area, using care not to scratch or dislocate anything.
All done!
  • 495 Answers
Hi
Try using a different signal cable. If that doesnt work then
that means that your Projector's Ballast ( lamp's powersupply ) is faulty.
It is quite cheap to have replaced.
    Sergeant:
    Champion:
  • 289 Answers
Hi..make sure that u have connected the
input cables correctly,otherwise look
whether the lamp's bulb has got fused or
proper.These are the reasons which will
cause to this failure.
check it out..
thank u..
Posted on Feb 07, 2009
  • Hariharanath V Feb 09, 2009
    hi..At first check whether the bulb has
    got fused.
    try this out..
    thanks..
    hi..this error is due to the input wires that
    comes to the power cord.
    check this out..
    thanks..
  • BenQ Master
  • 19,396 Answers
Unplug the projector from power, and also the computer (or whatever device connected.
Now connect projector to computer with both units unplugged or not powered.
Restart computer first , with VGA cable connected to projector.
Start projector as second.
If computer is a laptop you will have to switch signal to external port.
Testing with a desktop is better, because you always have signal on VGA/HDMI port.
If the above does not work, do the opposite, power off both , then start first PC, then projector.
If it does not work both ways, then it is probably a defective signal board on projector.
  • Ginko
    Ginko Feb 09, 2009
    Beg your pardon, but if the "The menu does not show up" at all, then the problem is not with the input.
    The Menu is displayed by the projector even when no device is connected.
    The projector is defective, with an internal problem, this is not a repair that you can do at home, it may be a blown component on main board or something similar.
  • 129 Answers
Did you try to configure the Video mode appropriately ?
    Sniper:
  • 52 Answers
Did you say but will now show, or will not show.
Cheers
Simon
    Master:
  • 474 Answers
Hello, I work for a school district and have alot of Projector work orders that im not supposed to do ( not my department) But i do anyways.
I didt read everyones post so sorry if i repeat a few things.
Usually this issue is do to something being connected but not ouputting a signal to the projector.
On the remote ther should be a INPUT button that allows you to switch from say, RGB1 to RGB2 then maybe DIGITAL INPUT or some other external like A/V.
Be sure that the connectors are of course, connected right. Should go from the OUTPUT of whatvers hooks to the projector, and connect to the INPUT on the projector.
You probably did this already but im just going through the check list.
Now, Make sure ther isnt any sort setting thats got it on freez frame or something and its locked on a blue picture. Try resetting the projector, Just unplug it for about a minnute or 2.
Also, test the output device ( I.E. Camera, P.C.) on some thing like a T.V. to be sure it works and its all the Projectors fault that ts not working.
Does it have an AUTO detect? for the dignals or do you set it yourself/manually?
Is thee any red status lights blinking?
I found the manual online in case you need it. Its a PDF at the below link
http://www.aboutprojectors.com/pdf/benq-pb8220-manual.pdf
Hope that help some.
Posted on Feb 06, 2009
    Sergeant:
  • 285 Answers
Hello, lamps don't last forever. Sooner or later you will need to get one. You will need to buy a new lamp if the projector says it needs replacing. Thank You. I hope This Helps!
  • 1,800 Answers
I Think the firmware of the unit is corrupted.
check if u can find any upgrade utility in the CD.
i was seeking for it but its not available online.
firmware= the software of the unit shows source and menu nad outputs and options...etc.
thnx
  • 2 more comments
  • Jalal Sordo
    Jalal Sordo Feb 06, 2009
    it just be on i guess.
  • Jalal Sordo
    turn it on while upgaring the firmware.
  • Jalal Sordo
    Jalal Sordo Feb 09, 2009
    the audio got no deal with projector (video).
    ur Lamp might be defective, maybe its froze up ur unit and no leting it to start up as the usual.
  • Jalal Sordo
    as u see its not getting to the Menu!!
    the lamp is faulty 100 %
    replace it and u will see!
    President:
  • 1,902 Answers
• Check for the proper input source.
• Ensure all cables are connected properly.
• Adjust the brightness and contrast.
• Remove the lens cap.
  • 6,784 Answers
This sounds like a main board failure. unfortunately these malfunctions can only be repaired or rebuilt by the manufacture. the on board software could also have become corrupt as well.
  • Michael Masters
    Michael Masters Feb 06, 2009
    Your problem may be on one side of the board. im thinking its the input side. you may have breakage there. i would check the solder connections on the input side of this board. you could have a hairline crack not noticeable by the naked eye. hope that helps.
    Sergeant:
  • 250 Answers
Press EXIT button for five sec. you see counter hrs. then press AUTO button to reset .
you hit menu and then hold exit for 3 seconds to bring up the lamp hours used, then you push menu on either the remote or the console and then you hit < or > to reset it. You just have to hold exit for 3 seconds on the console and not the remote and it works just fine.
check out this link for the manual
http://service.benq.com.hk/HKUploadFile/Book/PRJ_PB6162_Manual_EN.pdf
    Sergeant:
  • 326 Answers
  • 2 more comments
  • moniter Feb 06, 2009
    http://www.projectorpeople.com/SLIS/down...
    just click the link and follow the instructions care fully.
    it should be on.
    Lamp Information
    Use and Replacement of the Lamp
    When the Lamp Indicator lights up red or a message appears suggesting the time of
    lamp replacement, please install a new lamp . An old lamp could
    cause a malfunction in the projector and in rare instances may even explode.
    Lamp LED Indicators
    Caution
    The LAMP indicator will light up if the lamp becomes too hot. Turn off the
    power and let the projector cool for 45 minutes. If the LAMP indicator is
    still red when turning the power on, please contact your dealer.
    Lamp Life Indicators When the LED lights up red, it is warning you that lamp
    uage has exceeded 2000 hours. Replace the projection
    lamp with a new one immediately.
    The Lamp is not
    properly attached
    LED lights up red.
    The temperature is too
    high
    When the projector’s internal temperature is too high
    for the projector to operate safely, the LED blinks
    orange and the lamp turns off automatically. The LED
    keeps blinking while the unit is off.
    If the LED light is off, the operation and temperature of
    the projector’s lamp are normal.
    NO PICTURE :-------• Check for the proper input source.
    LAMP WARNING -
    CHANGE LAMP AND
    RESET LAMP TIMER :-----------The lamp has been in operation for 1900 hours. Install a
    new lamp for optimal performance.
    User Logo
    Enables the user to define his/her own logo screen that will
    display during strat-up. Three modes are available: Default
    (BENQ logo), black screen and blue screen.
    Lamp Indicator
    The Lamp Indicator will light up only when
    when the lamp needs service,
    either it needs cooling or replacement.
NEC WT610 Projector powers up and acts like normal, but will not project an image or the usual blue screen with menu functions. Bulb is fine and lights up, no error lights showing. It's as if it's stuck on...
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Feb 05, 2015 | NEC Office Equipment & Supplies
I have a PB6200 BenQ projector. When the computer starts up it shows the BenQ and then shows the windows computer startup screen until it finally fully boots up. Then the projector does not show what is...
There's a display "toggle" sequence on your computer to send the signal to your external post (VGA?). Look at the Function keys (top row) for a screen icon. Hold Fn key down and press that Function key (on Dell, usually F8). You should get an indication on your screen of which outputs are active -- look for BOTH.
May 28, 2017 | BenQ PB6100 Multimedia Projector
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Aug 19, 2011 | BenQ PB6240 Multimedia Projector
I have not used my PB6100 for a little while and when I tried to run it I only had a plain screen. I could not even get the menu to show. The lamp had less than 300 hours at the previous showing.
George - I have a similar problem. Low light output, no blue screen, or BENQ power up - nothing but low light being projected. Did you solve your problem? Same as you we have not used the projector for a few months. TIA Jim
May 23, 2011 | BenQ MP610 Multimedia Projector
The monitor switches on and shows benq logo, then screen goes black.Tested on 2 computers and still not working. Have changed capacitors on board but still nothing.
After changing the caps, do you get steady 12~18vdc feeding the inverter circuits? Inverter fuse OK? It can be bad transformers, or lamps also. Pictures will be great help. See where I post my pictures: http://s807.photobucket.com/home/budm/allalbums
Mar 05, 2010 | BenQ FP222W LCD Monitor
Blue screen
Hi Guys,
I recently struck this issue with one of our PB6100's. To resolve I did the following:
  1. Enter service menu (found on AVForums): PRESS AND HOLD UP BUTTON UNTIL LAMP HOURS ARE DISPLAYED, PRESS THE POWER AND BLANK BUTTONS TOGETHER
  2. Under the Fan menu select "More Options". You should then be in the "Fac7 Submenu".
  3. Select "Hard Reset". Note that this will reset the lamp hours also!
  4. Power off & then on again. Test input.
The above worked for me. Hope it helps.
Jun 20, 2008 | BenQ PB6100 Multimedia Projector
Beng pb7100 projector
It might be caused by the logical board or a sensor of it; you have no other choice but taking it to the repair center.
Feb 29, 2008 | BenQ PB7100 Multimedia Projector
BenQ PB8220 Multimedia Projector Logo
322 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
