Question about GE JVM1870 Microwave Oven
Fan doesn't run
I need a manual for this microwave convection Daewoo 1010cc. My fan doesn't run all the time. It gets all steamed up and begins to run on cool down mode. When it's done cooling I can then start it again. Maybe the manual would tell me how to activate the fan.
I'm sorry, but when I replaced this unit, I threw everything away. You can download a pdf of the manual here
It might not be the exact model, but should be close.
Sorry I'm no better help.
Posted on Feb 05, 2009
Why does my convection microwave ovens fan keep running long after it has finished cooking
There are 2 reasons :
01.Because the high temp. used to cooking must chill down.
02.To exhaust the remains of steam that could lead to premature rust of the oven
Dec 05, 2017 | Microwave Ovens
Why Auto fan seems to go on prematurely
The vent fan comes on if your steaming or creating heat unit it to protect the control unit. So I assume this was happening when the fan came on? I hope this answers your question. When this happens the unit will turn off when it cools down all by itself.
Aug 02, 2014 | GE Advantium 120 Convection/Microwave Oven
Dacor Microwave DCM24S cooling fan continues to run
follow this steps and fix it. God bless you
  1. Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#9#ixzz2aNH65mG4
Jul 27, 2013 | Dacor DCM24SS Convection Microwave Oven
My GE microwave convection oven JVM1790SK 01. It has started to make a load grinding noise, and is sparking above the cavity area, otherwise it operated properly. When I remove the fan assembly part...
The fan is for air circulation regulation, e.g. preventing steam (and smoke) from building up inside, and also stops air pressure from building up inside so you won't get a blast of steam coming out or worse. On the convection side it heats the food faster and more evenly. You will need to replace the fan assembly to keep the microwave safe. the noise and sparks are probably due to spent bearings and / or a dislodged fan scraping against another surface or something getting in the way of the fan
Nov 30, 2017 | GE JVM1790 Convection / Microwave Oven
After approx a minute a regular squeak begins, occasionally missing a beat.Heating is fine.
If the "frequency" of the squeaking is a low frequency, the I would suspect the turntable motor or stirrer motor (if so equipped).
If it is a higher frequency, I would suspect the cooling fan or hood fan motor.
Dec 11, 2012 | Neff H7871 Convection/Microwave Oven
Jenn-air micro convection - cooling fan comes on when door is opened, then goes off, intermintent problem
I have seen where one of the door switches becomes intermittent causing the symptoms you are describing, tough to nail down considering there are more than one door switches.
Jun 16, 2012 | Jenn-Air JMV9169B Convection/Microwave...
My Sharp Micro Convection Model R1870 fan behind the touch panel keeps running for 50 seconds after the microwave turns off,. this is not the vent fan. it also runs for 50 seconds when you turn the...
If the fan seems to run even after the microwave had completed the cycle, then it is possible that the drive to the fan is having a time delay. Also it has to be made sure that the magnetron has been cut OFF power or else it is not a good situation. You will have to remove the control panel and check on the board, check the drive to the fan, since the processor cuts off the fan and magnetron at the same time the fan circuit must be traced. Look to the circuit after identifying the fan wiring and back check using a multimter if you are able to trace. If not take help as this can be harmful in case the microwave works till the fan cuts off. A faulty capacitor on the board can create this time delay.
Oct 11, 2011 | Sharp R-1870 Convection/Microwave Oven
Microwave exaust fan starts on its own
There's a humidity sensor in this microwave oven that turns on the fan automatically if it senses an excess amount of humidity (steam from cooking for example) to possibly protect humidity or moisture from building up inside the unit.
Apr 01, 2010 | KitchenAid KHHS179LSS Convection /...
Sharp Microwave Oven over stove fan goes on by itself
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So please post a
NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
Which fan is it?
The
internal cooling fan, which comes on automatically whenever the unit is microwaving?
Or the hood vent exhaust fan which you can turn on and off manually?
Or the convection fan, if it is a convection model?
When is it coming on?
Is it coming on whenever you cook on the stove top?
Thanks!
Oct 09, 2009 | Sharp R-1870 Convection/Microwave Oven
Daewoo microwave problem
The Daewoo model # is WM 1010CC.
The unit blows a fuse every time I open the door to get food out.
Please suggest a fix!
Bart Gibbons
Nov 03, 2008 | Daewoo Microwave Ovens
GE JVM1870 Microwave Oven Logo
73 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
