Question about Timex 1440 Nylon watch
Turn off beeps
My 12 year old son has gotten in trouble at school because his hourly beeps are distracting the class. how can i turn off?
    Problem Solver:
  • 6 Answers
Press the MODE button until you get to the AL (ALARM) screen. Press Start/Split (Stop/Reset) (upper right button) repeatedly to turn the alarm and chime are off. If that did not help the manual can be found at www.timex.com at the bottom of the page click on manuals/downloads, click on manual downloads go to Digital Chrono/Alarms/Timers and click on the manual. Hope this helps.
Posted on Feb 05, 2009
The manual on Timex's site isn't for the 1440 Sport, so I kept looking through the forum. I finally found a solution that worked: hold the Adjust button (bottom right) and press the Start/Stop button (upper right). That should turn the alarm off (or on if you'd like). Hope that helps!
Posted on Mar 08, 2009
    Problem Solver:
  • 6 Answers
Press and hold SET, then press START/STOP until desired setting appears.
Posted on Mar 09, 2009
Us9061 how to turn off alarm ?
Thank you, coffee_addct!!!!
Dec 15, 2013 | Watches
I have a shark leash 88 freestyle watch. I go to school and the hour chime beeps in the middle of class. I need instructions to my watch.
IT LOOKS SIMILAR TO OF MY WATCHES POSSIBLE REMEDY HOLD THE BOTTOM RIGHT BUTTON AND PRESS THE TOP RIGHT THIS SHOULD TURN OF THE HOUR CHIME.
Jan 11, 2013 | Watches
Does the Timex Men's T77862 Expedition Digital Compass Watch allow for military time usage? ie-24 hours, instead of 12 hours
Here is a link to the Timex support page with the download links for all the different instruction manuals:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
And here is the direct link to the manual for the Expedition Digital Compass model:
http://assets.timex.com/user_guides/W215_M179/W215_M179_NA_EN.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 1 of the manual for instructions which basically read as follows:
1. In TIME mode, press and hold SET/RECALL. Time zone will flash.
2. To set, push + or - to select first or second time zone.
3. Press NEXT. Hour digits flash.
4. Press + or - to change hour including AM/PM. (Scroll through 12 hours to get to AM/PM).
5. Press NEXT. Minute digits flash.
6. Press + or - to change minutes.
7. Press NEXT. Second digits flash.
8. Press + or - to set seconds to zero.
9. Press NEXT. Day of week flashes.
10. Press + to - to change day.
11. Continue pattern to set month, day of month, 12-hour or 24-hour time display, MM.DD or
DD.MM date format, turn hourly CHIME on/off, turn BEEP on/off. If you select BEEP on, a
beep will sound every time you push a button (except INDIGLO).
12. Press DONE to confirm and exit or NEXT to continue and set second time zone, if desired.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 25, 2011 | Timex T77862 Watch
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Unable to turn off alarm
You should have a symbol of a bell, which indicates he alarm is "on" and the letters "CH" which means "hourly chime".
Press button at 2 O'clock position to enter the alarm mode. Press the button again and the "bell" should disappear; press the button again and the "CH" should disappear.
Now press the button at the 7 O'clock position to return to the normal timekeeping mode.
Jan 04, 2010 | Armitron 40/8125BLK Digital Sport Watch
I have a Seiko stainless steel ladies watch, 3 years old, only one 'winder' no fancy buttons, analogue style. It has suddenly started beeping every hour - how do I turn it off?
mcdevito75 here, The beeping must be a signal that the battery is weak, have the battery changed. Look for a small watch repair shop in your area for the battery change.
Nov 05, 2009 | Pulsar by Seiko watch PEG665Ladies...
How do I trun of the change of hour chime on my son's tghk watch
Press the bottom right button and while holding it down press the bottom left. All the days will show and the hourly chime is off, if the days aren't lit the hourly chime is off.
Sep 11, 2009 | Watches
Beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
May 31, 2009 | Timex Watches
Please i need help i dont know how to set my timer and it wont st
See response to Turn off Beeps, its the same. Just click on the Mid Size Sports 1440 Black Nylon Strap Watch link and look for Turn Off Beeps solution.
Dec 29, 2008 | Timex 1440 Nylon watch
Timex 1440 Nylon watch Logo
934 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Geoff
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
