Question about Toshiba 61HX70 61" Rear Projection Television
Where is the hard reset located
Tv is shutting down with three demensional wavey lines.
  • royism Feb 05, 2009
    I am a plumber by trade so yes I can solder. Please instruct further.
Hi i have a sony 61 inch rear projection tv when you turn it on there is no picture but three curvy lines at the top green red blue and sometimes if you wait it works pefectly
any ideas
Cheers Rich
Posted on Jul 19, 2009
  • 4,234 Answers
This is not a problem that a "reset" will resolve. There is a problem with the convergence circuit. It may be as simple as poor solder connections on the convergence ICs. If you can solder, you can fix this yourself. Please let me know if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
Posted on Feb 05, 2009
  • ABRsvcs Feb 06, 2009
    OK. First locate the convergence ICs. These are large black ICs attached to a heatsink and will be marked STKxxx. Resolder the pins on these ICs and see if that resolves the problem (often it does!). IF not, then replace the ICs with new ones. There may be low valued resistors in that area that are defective as well. Look for those as well as some fuses that are in-line with the pins of the STKs. Quite often when the ICs go bad, the surrounding fuses or resistors get smoked. Please note that the TV will have potentially dangerous high voltages present even when unplugged, so be careful.
    Keep me posted.
    Dan
HITACHI PROJECTION TV HAS WAVEY LINES ON IT THEN SCREAN GOES BLACK
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Feb 23, 2012 | Hitachi Televison & Video
I have a Mitsubishi WS-65869 65 in. Rear Projection Television and it has created a wavey line and has distorted the image. i have a picture of it i can send. Any help. i can send pictures of screen.
If you see separation of colors (red, green) in this wavey line most likely you have problem with convergence circuit. Two convergence amps have to be replaced. They located in a middle of the TV boards attached to big aluminum radiator and they part number starts with letters "STK".
I would recommend to let professional with this repair. Should cost you about $250-$300.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Blue and red wavey lines and distorted picture
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 20, 2010 | Toshiba 53H71 53 in. Rear Projection...
Will not start up. when you power up it looks ok but it sticks on the "wavey line" screen. the wavey line is continually moving but thats all that happens
Most likely your hard drive has failed. This is one of many signs. Replace your hard drive with one similar or even with a larger capacity. I recommend 120GB 5400RPM Seagate or Western Digital. Thanks and good luck!
Mar 31, 2010 | Sony Playstation 3 (PS3) Console
Component 1 has wavey lines all other conections
For component 1 on the tv I just changed from 1080i to 480i on the Verizon Fios set top box and that corrected the problem...
Aug 29, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Aug 27, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Horizontal wavey lines in projection TV picture
what brand? could be a ground problem or bad crt
Aug 22, 2009 | Televison & Video
Wavey lines in tv
sometimes wavey lines can come from your cable or satelite connections because the wrong size cable was used or there is just a bad connection in the cable somewhere..
Nov 15, 2008 | Proton MM2701VT 27" TV
My PS3 when switched on goes to the wavey lines (just before the menu screen) and then freezes? it also stops making a sound. i've switched off at the mains but the problem persists. any thoughts?
it looks like your system may be corrupt try hard resetting your system turn off the power in the back of the ps3. Turn it on while holding down the I/O utton until it beeps 3 times
Oct 20, 2008 | Video Game Consoles & Games
Toshiba 61HX70 61" Rear Projection Television Logo
196 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
