Question about Nikon D100 Digital Camera
Card light stays on
When i try and put a memory card into my d100 the green lamp stays illuminated and i cant take a picture any ideas anyone?
  • benzenees Feb 06, 2009
    Got it in one you guys rock! my pocket thanks you .
  • 3,422 Answers
Please do a reset by removing the battery and the mem.card for 10min.Next insert the batteries,mem. card and then hold the power button for 30sec. let me know if you still face the problem.
Posted on Feb 05, 2009
  • Priya darshan Feb 05, 2009
    Also try these steps:
    This is a fairly easy procedure which involves either going into your
    setup menu and choosing "reset" (or intialize), holding down the menu
    key for 10-15seconds.
    It may be that the firmware loading got corrupted and the camera just
    needs to be "rebooted," which is something that turning it on/off won't
    accomplish. But after which, you should have the camera reset to
    factory default settings. Another tip is to go to Nikon's website and
    look for firmware updates. Download and install them.
    Also try turning you camera on-off for 3-5 times to see if it clears the issue.
    Also if the lens doesn't retract with green light always on then your camera lens may be out of alignment.
    It's a common problem with point and shoot zoom cameras. In a nutshell,
    the error happens when the lens gets stuck while trying to extend. The
    camera will beep a few times and then shut down. The lens gets stuck in
    the extended position, and refuses to move either to focus the lens or
    to retract when powered off.
    If your camera is out of warranty, or if Nikon refuses to repair it for
    free, the one thing you can try is to If you gently, and I do mean GENTLY
    push against the lens with the PALM of your hand as you turn it on, it
    may cause it to depress back into the camera. If that doesn't work, and
    you can't reset it or turn it on/off several times, then the only solution is to send it in for a repair estimate anyway and there are no more home remedies.
Why is red light blinking
The red lamp you are referring to is called the Access Lamp. This lamp usually illuminates if the camera is reading or writing information to the memory card. If this is blinking erratically, this could indicate an issue with the memory card. It is recommended that you try using another memory card with the camera to isolate the issue
Jan 20, 2015 | Cameras
Camera does not come on
Make sure to remove the battery first ... make sur your camera has a full battery charge ... then select "MENU" scroll through options until you find "FORMAT". This will re-set all your settings back to factory settings ... you will lose any saved pictures on the internal memory only. ALSO when your camera light goes on try to hit the PREVIEW OR EDIT SElection. I* cant see how the memory card being removed would cause your display to permently be damaged. You can also try to connect your USB/AV port. Use your A/V cable with the two input connections to a TV to see if it is putting out an image. Hope all goes well
Sep 27, 2007 | BenQ DC C500 Digital Camera
Fault finding
The green LED is called the memory acces lamp. When you switch off the camera is will write back the last changes. when you switch the camera on and off, the light ususaly will stay off, because nothing has changed. When you remove the card en put in another the LED will flash again. At least my D7000 with 2 card slots will do so, because someting changed and the system will write that into the memory.
Aug 21, 2013 | Nikon D90 Digital Camera with 18-105mm...
Green tint on tv and picture randomly cuts out
Sounds like a Sony, if it uses a lamp the green cast is most likely the optical light engine in the set---major part.
Aug 28, 2012 | Televison & Video
I have a sony tv model kdf-50e2000,and it has a problem with the picture going blank,the only light that on or flashes is the green (POWER) light. when turning the set on the green light blinks as it...
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
Dec 28, 2010 | Sony KDF-50E2000 50" HDTV
Hi, i took a series of shots nothing on card
Maye they were accidentally saved to the internal memory and not the card?
approved cards follow:
The following is a brochure for your camera from the digital archives:
originally the camera had the following storage specifications: CompactFlash™ (CF) Card (Type I/II) and 512MB/1GB Microdrive™
If there is an internal memory, then sometimes the memory holds the pictures you took, and not the external memory card.
Jul 29, 2010 | Nikon D100 Digital Camera
Nikon d100 tok several pictures and they are not on card
It sounds like it may have reformatted itself and if thats the case, they are gone. Some camera's have the option built in, then again, your computer might have done it when plugged into the card reader. I hope this can help shed some light on what may have happened, but sorry to say, if the memory card is now empty, chances are slim on recovering the pics.
Dec 31, 2009 | Nikon D100 Digital Camera
FOR error message when inserting a memory card with photos
You should try some photo recovery software to rescue the files on your digital memory card, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
May 31, 2009 | Nikon D100 Digital Camera
I have a Zenith z52sz80 dlp lcd with a flashing green power light
Make sure you re-set your lamp, ( if you haven't already ), also...make sure you have closed the cover completely. There is a sensor on the side, that will make your light flash green, and not power up, if the cover isn't completely closed.
Oct 08, 2008 | Zenith D52WLCD Television
Nikon D100 Digital Camera Logo
20 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
