Question about HP Computers & Internet
No internet connection
I cant connect to the internet, my ip provider said this is because my mac address is not working properly and that i need to change it.
is this true, and if so does any one no how i go about it. would appriciate any help, my computer is a hi-grade. thankyou.
    Scholar:
  • 85 Answers
Bridges sometimes use mac cloning to clone the device that is attached to it. go into bridges config page and disable this feature and also make sure to select dhcp since bridges will also use a static ip as well. i just hope this helps alittle. i dont have your exact model of bridge here so if you can comment on it i can get back to you and try to help further
Posted on Feb 21, 2009
I cant get connected to the internet
Providing that modem is working fine and we can get online if we connect the computer directly to it and having cable providers:
Steps to follow:
> Make sure modem is connected to the internet port of the router and from the router to the laptop/desktop computer
> On the back panel of the router there is a reset button. Reset the router for about a minute.
> As soon as the router powerlight is solid. Please open a web browser and on the address bar where you type http. Let's make sure to clear it out, type there the default Ip address of the router 192.168.1.1 and press enter.
> Username and password appears. By default, leave the username blank and password is in a lower case admin
> After you enter the password, press enter. Linksys set up page will now appear.
> On the upper right where you see set up, underneath set up you have basic set up. In line with basic set up to the right there is mac address clone.
> Make sure to enable mac address and click clone my pc's mac. Save setting please.
> Check status to the upper right, on the status page scroll down the page, if we see internet IP address that is not 0.0.0.0 then basically we are already connected to the internet.
Dec 21, 2010 | Computers & Internet
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Router set up is very easy. You will need to access the router set up interface to make changes on the router.
If you are not able to go online using the router then you will need to check the settings of the router.
First make sure that your computer is able to go online when connected directly to the modem without the router.
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.find network key.
Router set up for Cable Internet service provider :
This connection type uses the MAC address of the main computer to identify your connection. They generally register the MAC address of the main computer. So the MAC address is everything in this connection type. Now we set up router using the MAC address of the main computer. Main computer is the computer which was able to go online through the modem. Use only the main computer to set uo the router.
Connect the modem and the computer to the router . Check the IP address on the computer.
According to the Default gateway value open the set up interface of the router. Once you open the set up interface, you will need to clone the MAC address of the computer. Then change the wireless settings on the router and your router is ready to go.
Router set up for DSL Internet service provider.
What is DSL connection?
DSL (Digital Subscriber Line) is a high-speed Internet service that competes with cable Internet to provide online access to local customers. DSL operates over standard copper telephone lines like dial-up service, but is many times faster than dial-up. In addition to being faster than dial-up, DSL does not tie up the phone line. Coexisting with telephone service in this way allows users to surf the Net and use the phone at the same time.
There are two types of DSL connection
1 ) PPPOE : In this connection type you will get user name and password from the Internet service provider. Your computer will not be able to go online when connected to the modem only. You can open the router set up and change the Internet connection type to pppoe and type the user name and password for the ISP. After that change the wireless settings of the router and it will be ready to go.
2) DHCP : In this connection type your computer will be able to go online when you connect it directly to the modem.
you don't require the user anme and password for the ISP.
In this connection your computer will get a private IP address from the router. According to this the IP address of your router will change. Change the wireless settings of the router and it will be ready to go online.
Click Here for more info
Dec 18, 2009 | Belkin Computers & Internet
I cant configure my mbr624gu router with usb 598 mobile 3g internet
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.ind network key.
Click here for step by step instructions
Dec 03, 2009 | Computers & Internet
Can't configure my router to my modem, i follwed the instruction already from the manual. it still didn't work. still can't connect to the internet
Nov 16, 2009 | Cnet CWR-854 Router
64 Bit Vista Internet connectivity issue
you have to install the proper driver for Lan card you are using ...probably at installing the windows installed a driver for the card but is not the driver that this card is using ...so ..if you have the driver on the cd ..just install it ..and redo the settings to connect ...the tcp ip protocol for lan t1 cable...or the automatic ip for dsl modem ...anyway
even with the wrong drivers it is showing conected and working ..but the packets are not sent ...you can wathc this in the window that pop up when you click on tray system icon ..
another issue is if you changes the LAN card recently ... or you changed the pc ...and u used to have a nother IP based ( static ip ...) you have to call the provider and comunicate the new MAC address on your computer ..
if yo can not get in touch with your provider ..but you know that you have an Ip ;subnet mask ;default gateway ; and servers ..that you set every time ...this means that your mac address have to be changed either on the provider or look on the net and download a patch named MadMac..or MAC make-up ..this will help you to cl;one the mac adress on your lan card in such way that the provider will see it like the old one ...all you have to know is the old card mac adress in order to clone it ..
http://www.softpedia.com/get/Network-Tools/Misc-Networking-Tools/Mac-Makeup.shtml
remember ..this with the mac address thing should be done just if you changed card or comnputer and you have a Mac-ip re;lation with your iSP
Nov 15, 2009 | Computers & Internet
My computer is saying connected to router but no internet and my cable light on the router is not lit. (yes the cable is active on my tv) Any suggestions on the problem and a solution
if its the first time you connected the router ...you have to make the wlan connection ..and clone the Mac address on the router to fit the old mac that u had on computer card..
this in case ia have a static ip address and you need to make the internet connection with the provider... after that select from your pc network setting to obtain an ip address automatically ...and you put the sub-net mask at 255 255 255 0 and the default gateway as the ip address of the router ...
do not forget the router is now your connection with the provider so there is where you set the provider 's settings ...
if you have a modem too just select at the wlan in the router .to obtain an auto ip ...and in the computer too ..you may also clone the mac adress cause the provider may have it ..and block the acces cause didnt recognize the new one (router's Mac)
Jul 30, 2009 | Linksys WCG200 Wireless Router
Hi I cant configure my router D-link DIR-300
Hi! I will be more than glad to assist u in this concern..Please dont use the setup cd or setup wizard. you can access the setup page of the router by typing at the url:192.168.0.1 then it will ask for the user name and password, by default the username is admin and the password, leave it blank.. here are the things u need to check before u setup u router.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 29, 2009 | D-Link DIR-300 Wireless Router
DIR-300 router and broadband ISP connection,is NAT possible?
With a cable broadband connection, the cable line comes into the cable modem. The cable modem does the work changing the cable signal to a network connection and sends an I.P. address to the computer. With some cable internet providers you can hook the network cable into the in port on a router, wireless or wired, then hook up computers to the router. At this point the router gets the IP from cable and uses it's own IP routing for your internal network. Some broadband providers control your access by the computers mac address which registers with the vendor. If this is the case then the easy way to make it work is to get a router which can clone a mac address so the vendor still sees the same mac address.
May 24, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Can the wii send spam emails from its ip address?
No this is not a function of the Wii.
If you are looking for a way to send spam from a different IP address you may be out of luck. All computers on your home network broadcast out from the same public IP. There are ways to change your public IP with certain internet providers. Your public IP comes from your internet providers system. It checks for the MAC address of the device connected to the modem to assign an IP address. If you go through the router settings you can find where the MAC address settings are and choose which MAC it will broadcast, it's own internal MAC or a MAC from 1 of the connected devices.
Apr 20, 2009 | Nintendo Wii Console
Computers & Internet Logo
101 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
