Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Transfer roller assy is wearing out drums on rear side
Getting 7k to 10k out of a drum before the white plastic spacers on the transfer roller assembly cut into the drum surface
  • 210 Answers
You need to replace the two collars that lays on the left and right of the magnetic roller.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
In the middle copy is coming white
Dear
It is due to the consumable problem check the following
1- check the drum life> if possible clean the PCR roller with isopropyle alcohol, clean the drum blade.
2- detach the developer assy. and turn the mag roller to check the even flowing of toner, if you are experience clen the doc. blade and roller bushes of the developer assy.
3- check the transfer roller and its contact points clean it with soft anti static brush.
Thanks.
Jan 15, 2015 | Canon IR1018J Black and White Copier
Where is the primary transfer on the drum
The primary transfer is not on the drum it is located across from the drum as the paper goes between the drum and the primary transfer assy. and or roller (sponge looking roller), then reinstall the transfer assy..
Aug 26, 2014 | Sharp AL-1655CS Laser Printer
Error code c0210 on minolta 6001
The Transfer separation assy. Located below the drum has two fine wires in side of it that apply several thousand volts to the paper as it goes above the wires and below the drum to transfer image on to paper the second wire prevents the paper from sticking to the drum. Remove assy. see if they are broken or then the end blocks (white) need to be replaced because after a while the plastic breaks down an the High Voltage go thru the plastic to ground. Clean the wire very, very carefully with pencil earser if never been replace go to the web site below for corona wires don't lose those small springs at one end.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 11, 2012 | Minolta Office Equipment & Supplies
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I have GE profile Model DPSR473EW with loud squeak when drum turns ? I also need to learn how to access the drum etc...
I have experienced two problems with "loud squeeks" with the DPSR473EW. First, if you take the top off (open door, remove two screws under top door lip releasing the top), then.., remove two small screws (inside up high - one on each side) holding the front panel/door assembly on. Pull the front panel/door assy away from the main unit - can't seperate due to some wires near the blower. On the door/front panel assy..., you will see four "teflon slides" that fit into a plastic semi-circular assy (the drum rides on those four teflon slides). Most of the time, this is where the squeeks come from - I've seen them worn thru..., and the drum riding on the plastic (just order the teflon slides - qty 4 - WE1M333). If the plastic piece that the slides fit into is worn, replace it - WE2M26 (top bearing). This should do it. If the slides look OK (so the squeek hasn't been fixed), the other place for a squeek is...., the back bearing. This bearing is basically a male rotating plastic sleeve running in a metal female hole. I have seen those wear thru the plastic bushing..., causing lots of noise. To inspect that bearing, you will need to a) remove the belt (plenty of instructions on the internet), then b)remove the drum..., then..., you can inspect that back bearing (two pieces - one piece on the back of the drum, the female piece mounted on the heater shroud.. If you need to replace that bearing, or one half of it - you can order pn WE25M40 - it will have both pieces. Good Luck
Nov 15, 2009 | GE Profile DPSR473EW Dryer
The dryer squeals (metallic sound) while drying clothes.
check wear pads around front of drum or rear depending on brand. Ge's are particularly prone to scraping sounds, but still one of my preferred brands. IF a ge, did it get any dents around the sides or back? The drum is close to the sides and a dent in right place will do it. Also the rear panel can push the drum forward rubbing in front.
Ge - wear strips in front, plastic bearing in rear center, replace both, inexpensive.
Whirlpool- felt pad and wear strip in front, felt seal in rear with roller support. check rear seal lube rollers
Maytag -roller in front and rear with front and rear felt seals. some designs have front drum support posts with wear pads. ck these.
Frigidaire (include some sold under GE name) rear bearing cup (plastic)-lube, front feltpad with wear plates if plates gone get new pad/wearplate asm.
Maytag and ge nomenclature tags are in rear .
Jul 19, 2009 | Dryers
Black stains sticking to white clothes on washing
Rollers
Rear seal
Front glides
Front seal
Jun 08, 2009 | Washing Machines
Drum spins off center and clothes get stuck between drum and casing
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Rear Drum Support Roller Kit Installation
The spacers are not important , And the rollers are not self lubricating , just add a couple drops of any weight of oil on the shafts before sliding the wheels on. You can add a few drops on the idler arm/belt tentioner as well while your in there.
Lube and clean dryer every year and it will last a long time.
Hope this helps.
Phil
Apr 10, 2009 | Dryers
Black carbon/soot on the door and lint filter of my dryer
I have the same problem with a Maytag Performa gas dryer. My husband took our dryer apart and found that the burner tube which leads from the burner to the back of the dryer was full of soot (which was getting blown back into the dryer drum with the hot air.) We are cleaning it out now but would like to know how to prevent this from recurring in the future.
Dec 16, 2008 | Kenmore 62602 Electric Dryer
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
125 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
