Question about Dishwashers
Detergent falls out and doesn't melt
Our dishwasher is very new. We have to put the dishwashing soap in a hole and close the door to the hole. I didn't have any problems the first 2 weeks or so, but then I changed to Powerball detergent. This is a hard cube of detergent. It wasn't dissolving. So I changed to the gel pacs which I've never had a problem with, and they're doing the same thing. We run the dishwasher and when it's done and we open the dishwasher door the detergent door is open and the gel pac is sitting either on the door or at the bottom of the dishwasher undissolved.
  • Garth Jackson May 11, 2010
    Are you sure you are getting water in the machine and if so is it getting hot?(IE:are the dishes wet?)
  • 640 Answers
Check water temperture its not hot enough..onthejob
Posted on Feb 18, 2009
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Why is my dishwasher leaking soap foam from the lower left area of the door?
A leaking dishwasher can be caused by excessive soapsuds. Excessive soapsuds are the most common reason dishwashers leak. Excessive soapsuds will cause dishwashers to leak from the door. Good dishwasher detergent will have no more than half inch of suds on top of the water. So any time your dishwasher is leaking from the door open the door, if there is more than a half inch of suds your problem is in your soap. One drop of hand soap, hand dish washing soap, or any other soap will cause dishwashers to leak. Now, I am not suggesting that you intentionally put this soap in the dishwasher because if you did the soapsuds would be from top-to-bottom of your dishwasher. Now if there are a lot of suds you can fix it by pouring vinegar or cold water into the dishwasher and running it, this will kill the subs.
Jul 08, 2013 | Computers & Internet
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
The detergent compartment on our dishwasher will open during operation. We have run the dishwasher three times and the detergent capsule remains in the compartment and is only partially dissolved. It...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
Apr 18, 2011 | KitchenAid Dishwashers
The door of my dishwasher soap dispenser does not close anymore, where can i put the detergent?
put the detergent right into the open dishwasher on the floor. I recommend that you switch over to a tab or pouch form for ease of use. J.
Sep 26, 2010 | Dishwashers
Dishwasher soap lid is not latching. It's free of detergent.
We have the same problem, so I took the door of the dishwasher apart and cleaned it up, reassembled it, and it latched for about a week. Something is worn somewhere, and it's going to be a pain to figure out and replace, so we just bought some powdered dishwasher detergent, and fill the cup and close the door. The water spray will dissolve any that falls out when you close the door, and it does just fine, doesn't leave any residue or undissolved detergent on the dishes, at least with our dishwasher, hope you have the same luck.. If you choose to get it fixed, get an estimate first. Sometimes it's better to just replace, depending on the cost of repair. Hope this helps, good luck.
Mar 25, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher detergent door won't release soap
heatman101
l
Apr 06, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
KitchenAid dishwasher soap door won't open
I took the door apart and found the degertent door solinoid looking like it over heated and melted to the cover flap and the insulation. See picture. I can't post pic as the max is 150kb.
I applied power and it only got hot and wouldn't operate.
Next I go to Kitchenaid for a replacement - FREE it should be.
Oct 07, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher soap dispenser sticks
Your soap is clotting because there isn't enough water being sprayed around inside.  The water spray washes the soap out of the dish, if all is working well.  My machine had the same problem.  I had sufficient water level, but the spray head wasn't spinning very well.  I found the end-most hole in the spray bar to be plugged.  It is the end hole that provides a jet that makes the head spin.  I cleaned a bunch of debris out of the hole and the mchine started working and cleaning like it was new.  That was quite an axccomplishment since the machine is 15 years old.
Dec 28, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
502 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
