Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Why does my freezer work but my refrigerator doesn't?
I lost power with the ice storm and when it returned 5 days later my refrigerator doesn't work but the freezer does. The compressor is still kicking on but it doesn't cool
  • 6 more comments
  • m22souders Feb 05, 2009
    Thanks for the help I will check it out tonight.
  • Anonymous Feb 13, 2009
    freezer works fridge dosnt
  • Anonymous Mar 07, 2009
    my fridge is running but the freezer is.
    any clue?
  • Anonymous Apr 08, 2009
    i can't fix the temprature on the refrigator.
  • Anonymous May 17, 2009
    freezer works but the fridge doesnt.
  • anthonypolet May 19, 2009
    freezer works refer does not
  • annettesanch May 21, 2009
    freezer works, refrigerator doesnt. numbers wont move up or down. help!
  • brub May 24, 2009
    My fridge is not working but the freezer does. I can see the fan moving. what is a poor new father to do?
    Problem Solver:
My westinghouse fridge
the freezer is working but not the fridge
Posted on Jun 21, 2009
1.Check to see if the T-stat is closing the circuit to the circulating fan that blows the air into the refrigerator.
2. Chek the fan motor for proper operation.
Posted on Feb 05, 2009
My ice maker is working but fridge is not hot inside
Posted on Jul 15, 2009
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
Freezer too warm
First off, how old is the unit? Without knowing, my advice, and what has worked many times, is to unplug the unit, and turn it upside down. Thats right. Upside down. May take a couple or few people, depending on the weight. What this does, is to have the refrigerant begin running back to the top of the unit. Sometimes it settles in the bottom, and has to have extra help to start moving properly again. If, after about 6 to 24 hours it doesn't seem to have helped, it could be that you have lost the fluid, but that doesn't seem very likely. If you had, it would run consistently at the same warm temperature. If it helps, you may want to repeat the procedure to insure that it is completely free flowing. Cheap fix, if it fixes things. Good luck.
Nov 15, 2012 | GE Monogram ZFSB23DRSS 36" Monogram...
I have a side by side GE Profile refrigerator with ice and water in door which is about 10 years old. I just noticed a thin layer of ice in the bottom of the freezer. I removed it but it returned a few...
hi look to the back of inside of freezer lower part just above where you saw ice you will see a gap that the freezer drain there a hole in the middle may be cover with ice take hair dryer and melt ice and blow out drain that should do it jim
Oct 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
E had a power outage due to a storm blowing trees down on power lines. When the power returned, about 4 hour later, the refrigerator/freezer (side by side) was making a loud buzzing noise. The ice maker is...
This sounds to me like a busted compressor, nothing more you can do to it. You must call a repairman to test it and replace it, a very delicate procedure that requires specialized equipment.
Jun 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Ice Maker not working
Hi!!! your ice maker might have frozen over and gears are stuck..remove your ice maker and unplugg from the frig clean it and all is resolved..
Jan 04, 2009 | Refrigerators
No water from water dispenser
wat temp are you runninr in the refrigerator side? it should be at 38 degrees because now days the are using an averaging sensor inside and also if tis any colder yoou will possibly freeze you produce
Dec 25, 2008 | Refrigerators
Whirlpool Gold Ice Maker Quit Working
IF THE FRIDGE IS COOLING AND FREEZING WITHOUT AND HASSLE THEN YOU DONT HAVE A PROBLEM WITH YOUR CONTROL BOARDS.ALSO IF THE WATER IS STILL COMING OUT THE WATER SIDE OF IT.YOU NEED TO LOCATE THE WATER VALVE AND CHECK IF THE VALVE TO THE ICE MAKER IS NOT BLOWN THAT MIGHT BE THE CAUSE OF THE FRIDGE NOT MAKING ICE.
GOOD LUCK.
MOHAMED
Sep 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
5,586 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Richard Roth
Richard Roth
deton8 von Splosion
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
