Question about RIM BlackBerry 8700c Cellular Phone
Locked phone so i have a touch screen phone thats locked and im unable to type #pwd# as all that displays is numbers...how can i reset the password???
  • 28 Answers
Try this website
You are going to need the computer cable and iTunes installed.
Posted on Feb 05, 2009
  • tvangstr0ye Feb 05, 2009
    Terribly sorry mate, I missed your phone model by a mile..
Ascend y330. Where can I get free SIM unlock code?
http://sim-unlock.net/simlock/Huawei/Y330
How to unlock Huawei Y330 by code?
Unlocking Huawei Y330 by code is very easy, it is also safest and non-invasive method of unlocking your phone. To get code for unlock Huawei Y330. You need to provide IMEI number of your Huawei. Type on keyboard *#06# or remove battery from your Huawei Y330 to check IMEI number.
To unlock Huawei phones you need to provide them with IMEI number and model of your phone.
Huawei Unlocking process is safe and easy.
Nov 21, 2015 | Huawei Cell Phones
How to work my touch screen on my jelly bean 4.1 10in
Android 4.1 (Jelly Bean) your device now has several different lock options available.
To access your lock options, touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> > > Security & Screen Lock.
Screen Lock Options
  • Slide - provides no protection, but lets you get to the Home screen quickly, or open Camera and start taking pictures immediately.
  • Face Unlock - lets you unlock your phone by looking at it. This is the least secure lock option.
  • Pattern - lets you draw a simple pattern with your finger to unlock the phone. This is slightly more secure than Face Unlock.
  • PIN - requires four or more numbers. Longer PINs tend to be more secure.
  • Password - requires four or more letters or numbers. This is the most secure option, as long as you create a strong password.
The Lock Screen on Android 4.1 (Jelly Bean) uses two timers. The first timer is the "Sleep" timer which turns off the device display to extend battery life. You can turn the display on and swipe to unlock. The second timer called the "Automatic lock" timer turns on security features like pin, pattern, password or face unlock and protects the device from unknown users. This"Automatic lock" timer begins after the "Sleep" timer expires and you will be asked to enter personally recognizable data like pin, pattern, password or the face unlock when the display is powered on.
Note: The Automatic lock option will only show after a screen lock option (other than Slide) has been set.
To adjust the "Automatically lock" timer go to Settings > Security & Screen Lock > Automatically lock > Select desired time frame.
To adjust the "Sleep" setting go to Settings > Display > Sleep > Select desired time frame
If you are using facial recognition and do not want the "slide to unlock" to appear, set the "Automatic lock" timer to "5 seconds".
Power button instantly locks
There is an option in Android 4.1 (Jelly Bean) which will automatically lock the device when the display is on and the power button is pressed. As soon as the power button is pressed your device will lock.
Note: The Power button instantly locks option will only show after a screen lock option (other than Slide) has been set.
To activate the "Power button instantly locks" setting, go to Settings > Security & Screen Lock > check the Power button instantly locks checkbox.
It is important to note your phone may contain security policies set by your IT administrator which may override any settings you attempt to set under screen security. For example, if you set your phone to automatically lock for 30 minutes and phone locks after 10 minutes, it may be due to security policies set by your IT Administrator. Please contact your IT Admin for more information.
For more information on using your new lock features select one of the quick links below:
Lock and unlock basics
Set screen lock
Respond to incoming calls
Face unlock is grayed out
To unlock the screen, press the Power key, then touch [img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics06.png">and flick to .
[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics01.png">
To add a message to the lock screen:
1. From the home screen, touch Menu [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/JB/razr-menu.png" width="34" height="23">>
2. Touch Security & Screen Lock > Owner info and type your message.
Set screen lock
Depending how you use your phone, you may want to set some form of automatic screen lock to prevent unauthorized access. If a screen lock has been set, the screen locks when your phone's display goes to sleep. It is important to note your phone may contain security policies set by your IT administrator which may override any setting you attempt to set under screen security
Before setting a screen lock it is important to note that you will need your Gmail / Google Account credentials to reset any security lock, so please do not set a security lock on your device without first setting up a valid Gmail/Google Account you can remember and access.
To adjust your phone's lock settings:
1. From the Home screen touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> >
2. Touch Security & Screen Lock > Screen lock.
3. Touch the type of lock you want and follow the onscreen instructions.
If you have previously set a lock, you must enter the pattern, PIN, or password to unlock the lock settings.
4. You can choose among these lock options, listed in approximate order of strength: Slide, Face Unlock, Pattern, Pin, and Password
After you set a lock here, a lock screen displays whenever your screen wakes up, requesting the pattern, PIN, or other specified key
Respond to incoming Calls
While the screen is locked, you can respond to incoming calls in three ways.
  1. To answer a call, touch[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/icsphoneicon.png">and flick to .
  2. and flick to .
  3. and flick to . Select a message to immediately send it.
    Tip: To silence an incoming call alert, press the Power key or the volume keys.
Face unlock may be grayed out due to security policies set by your IT administrator which may override any setting you attempt to set under screen security. Contact your IT admin for more information.
Was this answer helpful?
YesNo
Sep 13, 2013 | Computers & Internet
How to unlock karbonn K2 model mobile, pls help me. It is asking power on pwd...
karbonn k2 mobile set is locked pls tell suggetion is display input power on password(4-8)
Jan 08, 2012 | Cell Phones
Tell input power on pwd(4-8) password vs&me china mobile
sir i forgot my power on password of my cell phone vs&me v808c
Aug 23, 2011 | Cell Phones
Once I unlock the LG Touch phone and press the phone button. it automatically calls the last call displayed. It has returned calls unintentionally by dilaing on its own once the the first dial button is...
Try resetting the settings and see if it helps.
Steps to Reset Settings
Restoring default settings will reset Sound, Display, Phone and Call Settings to factory default specifications.
  1. From the main screen, touch Menu.
  2. Touch Settings & Tools.
  3. Select Phone Settings.
  4. Touch Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Touch Reset Default.
  7. Touch OK.
Mar 14, 2011 | LG enV Touch VX11000 Cell Phone
Lost phone password
*#7465625# = Check the locks *7465625*638*Code# = Enables Network lock #7465625*638*Code# = Disables Network lock *7465625*782*Code# = Enables Subset lock #7465625*782*Code# = Disables Subset lock *7465625*77*Code# = Enables SP lock #7465625*77*Code# = Disables SP lock *7465625*27*Code# = Enables CP lock #7465625*27*Code# = Disables CP lock *7465625*746*Code# = Enables SIM lock #7465625*746*Code# = Disables SIM lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network lock ON #7465625*28638# = Auto Network lock OFF *7465625*28782# = Auto subset lock ON #7465625*28782# = Auto subset lock OFF *7465625*2877# = Auto SP lock ON #7465625*2877# = Auto SP lock OFF *7465625*2827# = Auto CP lock ON #7465625*2827# = Auto CP lock OFF *7465625*28746# = Auto SIM lock ON #7465625*28746# = Auto SIM lock OFF
Jun 14, 2010 | Samsung SGH-A877 Impression Cell Phone
My account is locked out and it has been three days now. how can I unlock it.
Try breaking the password using pwd breaking CD(bootable) or using bootable OS CD also u can do the magic. Just reboot system using OS CD, take reapir option and when it reaches to 39 % remaining screen, using shift & F10 key u get login screen of cmd prompt,where u can type - compmgmt.msc and in user account change the pwd. and after repair option completion just do the magic using the new pwd.
May 20, 2010 | Computers & Internet
I forgot my password to my cellphone could you please hel me to change and the #pwd# how do you use that becaus i couldnt type the letters pwd plzzzz help
dial #793# and press send.
Then wait a few seconds and the call will reset your voicemail password. The voicemail password will then be the last 4 digits of your phone number. Be sure to change it once you've logged back into your voicemail.
Nov 28, 2009 | Samsung Highlight Cell Phone
I have a sim lock problem
Can't tell you if any of this will work..but it's worth a try until you find something better...good luck!
*#7465625# = Check the phone lock status
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
May 03, 2009 | Cell Phones
RIM BlackBerry 8700c Cellular Phone Logo
66 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
