Question about Kingston flash memory card - 256 MB - MMCplus Graphic Card
Kingston Flash Memory not working
Hi:
I have a 32G Kingston flash memory. When I copy files to it, it works fine, but when I try to open those copied files, it shows error, file not supported, or it does not show the file, instead it shows some garbled characters. How to correct this?
  • Randall  Trahan
    Randall Trahan May 11, 2010
    The file extensions on the files must match up with the program you are opening up with. For example, if you open up Word, then only files with .doc will open. What is the file extensions of the files you are having problems with.
    Problem Solver:
  • 6 Answers
Could be a bad card or the card reader/writer does not support that high of a capacity memory card.
Posted on Feb 11, 2009
Files copied onto kingston dt1/16gb usb get garbled.
Many people don't realize this, but flash memory wearsout the more you delete and write files to it. How quickly it wears out willdepend on the specific flash drive. Like anything, there is a wide range ofquality in currently available flash memory-based drives. You can make a roughcorrelation with the cost/quality of the device (what you pay is what you get),but even that tends to change over time. Depending on usage and quality itcould be talking as short as months or as long as several years. In extremecases of misuse it could lasting as little as a few weeks.
Apr 18, 2012 | Computers & Internet
I have a kingston 2 g flash drive. I put a large number of files from my Dell computer with Vista and the flash works fine on ANOTHER of my computers, a Toshiba Laptop. I put some files on my kingston...
this could be due to the format. i would try different formats on your usb. vista normally reads both but your format may be fat32 which is hit n miss. you can try UDF or FAT. I would format on a vista machine. insert, right click on the drive and select format. you may have to do both with a single file to test reads on both boxes. good luck.
Jun 13, 2011 | Kingston 2GB Secure Digital Memory Card
I have a kingston 2gb microsd memory card in my digital camer which says "locked"... im not able to unlock it now... pls tell me a soluton
1.Insert card into your phone but don't access it through phone. 2.Run FExplorer and Open the path C:\system. 3.You will find a file called mmcstore ,rename the file mmcstore.txt 4.Copy that file(mmcstore.txt) to your pc and open that file in notepad. 5.You will find your password in that file.
You can find the FExplorer from the internet..
Jan 08, 2011 | Kingston 2GB Secure Digital Memory Card
I forgot password for Kingston 1GB memory card
Dec 28, 2010 | Kingston 1GB Secure Digital Memory Card
Files in my kingston pendrive does not open up
Hi manoj_clc,
The "other PC" needs to have the same application installed that created the files. It sounds likely that is the problem for the other PC. If the files are failing to open using the PC that originally copied the files, then try formatting the USB drive (formatting deletes all data). Before you copy the file again, make sure the same file opens from your computer prior to copying it. Now copy the file to it the USB drive again.
Kingston Tech Support
May 03, 2009 | Kingston 4GB Secure Digital High Capacity...
Not able to copy more than 1GB into 2GB Kingston SD card
Hi 1123sun,
Copy your files off the card. Then Format the card and select FAT32 file system. After the format is done try the card again and see if you can copy more files to it.
Feb 18, 2009 | Kingston 2GB Secure Digital Memory Card
I have a kingston 2gb and i dont know how to get my pics on it
Hi shenicamangr,
From inside My Computer, open the DT then from the menus at the top click on File, New and Folder. Type a name for the folder. Now go an find the picture files you want to copy. Right click on a file to copy (or press Ctrl-A to highlight all files) then select Copy from the menu. Go back to the DT and open it. Right-Click on the new folder you created and select Paste from the menu. All of the files should now be in the new folder.
For more information on how to use the DT go here: http://www.kingston.com/support/howtodt/default.asp
Jan 02, 2009 | Kingston 2GB Secure Digital Memory Card
FLASH MEMORY (PEN DRIVE)
I would venture that your pen drive has a problem with its File Allocation Table. Being a 256 leads me to think that it has been in service for quite some time. Perhaps a full format is necessary. May I recommend that you use HP Drive Key Boot Utility available here. Of course formatting would erase all and everything inside the pen drive.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 25, 2008 | Kingston flash memory card - 256 MB -...
Computers & Internet Logo
94 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
