Question about Toshiba D-VR650
Channel Set- Auto Scan only yield a few channels
Toshiba Model DVR650KU, (want to use Set Channel feature so I can change channels with DVR remote): Have a "Setting Channel" problem, after Auto-SCAN (selecting CABLE) I only get three TV channels. Should get over a hundred. Wiring is as follows: cablebox RF-out to DVR UHF/RF-in, cableboc AV-out (yellow/white/red) to DVR AV-in (yellow/white/red) , cablebox HDMI-out to TV HDMI-#1in, DVR HDMI-out to TV HDMI-#2in
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
  • 73 Answers
SOURCE: We own a Toshiba MW20FP1 Television set/vcr/dvd
If you look in the back of your manual under troubleshooting you will see this particular question addressed. In the beginning of setup you must designate wether the incoming signal is from an antenna or from cable. If you have to have a cable converter box then your TV must be on channel 3 or 4.
Posted on Jan 02, 2008
SOURCE: Toshiba D-VR650KU can't "see" digital channels
On the Notification screen with Cable highlighted I found that left clicking on Cable gave a drop down menu with TV on it for selection. The manual says that while Cable is highlighted, use the up or down arrows to get TV to be an option and then select it and Yes and enter. Hope this helps. I have other problems with my monitor on Line Out, the screen oftens turns blue indicating low or no video using Line 1 or 2 inputs.
Posted on Mar 09, 2008
SOURCE: Tuner won't go above Channel # 99?
Most cable boxes that go past 99 are digital channels and require the cable box to tune them in. You can always set the cable box to the station you want and hookup the rca output to your DR4 rca input and record from that. Their is no other work around for this because the DR4 has an analog tuner inside of it and your cable box is a digital turner.
Posted on Jul 06, 2008
SOURCE: need comcast dvr remote code for toshiba 14dlv75 lcd/dvd
code TV/ 0156 or TV/ 1256 (or TV/ 10156 or TV/ 11256
Posted on Dec 04, 2008
Toshiba LCD TV/DVD 15LV505 lost channels. Rescan = fewer channels. Now in Setup, when I press the remote down-it skips the Channel option. What must I fix/change in Settings to get the Channel option?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Dec 08, 2016 | Toshiba Televison & Video
Can i run a channel scan on a toshiba model number 32HL66 without a remote
You should be able to access all features with the menu button on the TV itself. You make selections on the menu with either the Volume or the Channel buttons. On screen instructions should guide you.
Nov 29, 2015 | Toshiba Televison & Video
Why am I getting the message "Please scan channels" on my TV. How can this problem be fixed please?
tv may have detected new channels or radio authority may have changed the channel frequencies. go into the tv setup and auto scan dtv channels.
A make and model number may yield a more accurate answer than this .
Sep 24, 2015 | Televison & Video
Channel set scan
Does not scan or does not store? The auto program or scan feature is in the main menu in setup area and done with the original remote.
Nov 07, 2012 | Toshiba Televison & Video
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
SVA television. Have model # EV1703 Remote no
When you say the remote doesn't get the channels I have to assume the channel entry behavior changed. I am not to familiar with this brand but these are the basics for most tv's. If you have not removed the cable input to the tv or unhooked anything before the problem started here are a few thing you could try. Push the menu or setup button on the remote and under the channel or setup option on the tv make sure it is set to Cable and not Air or Antenna. Run the tv through the auto channel search to reprogram the cable channels. This process can take close to 1 hour on some tv's since it has to scan through the digital and analogue tuners. This will allow your tv to add the correct cable channels and remove the unwanted ones. You should be able to enter the channel number or move up and down with the channel buttons on your remote.
Dec 10, 2009 | SVA-USA EV-1703 17 in. LCD Television
Comcast Remote requires 3 digits be entered to change channels
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Nov 23, 2008 | Philips Tivo HDR812 80-Hours Video...
How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Jul 28, 2009 | Televison & Video
Toshiba D-VR650 Logo
57 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
