Question about Jura Capresso Impressa E9 Espresso Machine & Coffee Maker
Jura Impresso E9 not dripping through spouts but into drip tray
My Jura Impresso E9 does not dispense coffeee out through the spout.
Instead the water leaks internally into the drip tray at its left-rear side (at the left end of that bar that can be seen in the back of that opening.
Now, when attempting to make coffee, and rinsing, this happens as I said above, that the water does not come out the spout, but all of it comes leaks internally. However when I set it to cleaning itself all the water comes out through the spout.
Any tips, tricks and drawings?
    New Friend:
  • 13 Answers
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Posted on Jul 08, 2009
    Problem Solver:
  • 4 Answers
Use a paper clip or needle make sure spout is not clogged....pull out drawer wipe out grounds...then spray pam
Posted on Jun 15, 2013
Water is dripping slowly from one spout. How do I access and remove the spout assembly on a Jura Impressa F7?
Open the whole machine and you'll find the spout. Tighten up the nut there, the washer is like a tap thats dripping
Dec 10, 2014 | Jura Capresso Impressa F7 Espresso Machine
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Jura capresso e9 water not coming through spout
Use a pin or a needle on the spout to clean the nozzle head. Most of the time this is due to useing to fine a grind in the machine. You may have to clean the head this way more then one time to get it to start working again properly.If you have any further questions message me back.
Thank you
Nov 29, 2011 | Jura Capresso Impressa E9 Espresso Machine...
Jura-Capresso Impressa Z5 - left coffee spout is clogged the left spout only lets drips of coffee coming through yes we: 1. use only dry beans 2. have the water harshness setting below 10 (we only use...
As the coffee is dispensed, it is normal to have some residue left in the tubing and spouts. It is the reason that the machine will require cleaning on a regular basis using the Jura tablets that dissolves the coffee film. In the case the spouts get clogged, the best approach would be to dismantle the spout assembly. Since it may not always be possible, I found that filling a cup with a coffee cleaning solution such as Puly Cleaner ( and having the spout dip in the solution overnight can help. Probably that dissolving a Jura cleaning tablet in a cup of warm water would provide similar cleaning power.
Dismantling the spout is rather straightforward. You start with removing the front logo by rotating it counter-clockwise. Behind it you will find a T15 Torx screw. Removing it will allow removal of spout cover by pulling the top part lightly towards you and then sliding it down below the spouts. Grab the spouts by the sides and wiggle downwards until it comes loose. You can now clean the spouts but will most likely need to soak it. See the video showing removal of the spouts @
Jun 08, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
Lisbon monobloc kitchen taps just installed the
Put some cooking oil around the o-rings to sofen them up so they would seat around all fitting surfaces. Hope this helps.
Aug 12, 2010 | Home
Both spouts seem clogged
I have a Jura Impressa F7 that had the exact same issue. To solve it was pretty simple. Try and make a cup of coffee, and while the machine is trying to pump the coffee thru the spouts, grab the chrome handle on the spout and vigerously move it up and down rapidly. You should notice small grounds of coffee dislodge and follow the stream of coffee into your cup. If you do this a couple of times, you will be able to clear the trapped grounds within the spout. Hope it works for you as well as it worked for me.
Jun 23, 2009 | Jura Capresso Impressa F9 Espresso Machine
Water not coming out of dispensing area, goes to drip tray instead Water comming out in drip tray instead of regular way
Try this, if the machine has a pregrind door(usually on the top front) then use the button to tell it you are using pre grind coffee, if water comes out the spout this way then the grind on the grinder is too fine, if it goes out the drain then the coffee passage is blocked, remove the brew unit and check/clear tubes, also clean the spouts on the door of the unit.
May 30, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Jura Capressa E9 Leaking
Your spout is probly cracked (a common problem). It won't hurt the machine if you want to live with making one cup at a time to catch it all.
If you want to get it repaired go to Click on Jura Repair for shipping instructions. We can turn the job around in 24 hours. The repair will also include a free software update.
Aug 02, 2008 | Jura Capresso Impressa E9 Espresso Machine...
Jura Capresso Impressa E9 Espresso Machine & Coffee Maker Logo
2,908 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
