Question about Fuji Rod Repair Kit
My A330 will not take photos.
The camera switches on. I can look at previous photos, but when I pull back the shutter to take a picture, it refuses to click and work, and the screen shows no image. The shutter is reluctant to return to the closed position and I have to ease it back and forward to get to close and the lense to retract. I have read through the trouble shooting pages in the manual and nothing seems to cover the problem. I have tried new batteries. I have tried to clean as well as I can. I don't know what else to do.
from John Darrall
johndarrall@googlemail.com
01572 812443
Thank you
  • 7 more comments
  • johndarrall Feb 09, 2009
    the camera problem continues as before. No photo. No click. Retraction reluctant. The memory card provides for 128 exposures and there are only 15 to 20 pictures to view.
    I have just tried your latest suggestion but there is response from the camera and no copying of the pictures onto the PC
    I'm afraid I am getting nowhere, and closer examination of the shutter is beyond my technical ability (which is non-existent). Please may I have my money back!
    you don't mention the money I have just given my visa card details for (9 dollars 99)
    I give up
    only helpful in showing that the problem cannot be solved in this way, I'm afraid
    No, I don't think you can help any further, sad to say. I shall take the alternative route and buy a new camera on part exchange. Please cancel my visa card payment.
    it is no solution
    No thanks - too late
  • 15,935 Answers
There is nothing in the user manual because there is no end-user fix.
Your camera has a bad limit switch that is not relaying correct information to the PLC.
Please take it to an authorized Fuji repair center.
There is nothing more you can do yourself.
Thank you for using FixYa - A FixYa rating is appreciated!!
Posted on Feb 09, 2009
  • Fuji Master
  • 19,396 Answers
Hi John
Wehn you have a jammed lens problem of this kind, that is usually because of dirt jamming the lens mechanics, or because the lens assembly had been damaged, usually after a shock.
In some case weak batteries, or oxide on battery contacts can give you same problem.
Ensure this is not a battery problem first, clean contacts with isopropyl alcohol and cotton tips.
The most likely is that this is a lens problem, in that case the lens must be disassembled at a repair shop, if you do not risk to damage the camera.
  • Ginko
    Ginko Feb 09, 2009
    If you have not been able to fix the problem with regular maintainance, that means that the camera is faulty, and must be repaired.
    Rather then disassembling it yourself, you should buy an extended warranty, and have it repaired and covered for three extra years.
    Here is a warranty contract for $55: Blue Nook - 3 Year Extended Warranty
    There are extended warranties for different countries available online.
    This is cheaper but your camera must be still under warranty: FUJIFILM FinePix A330 3 Year Extended Warranty ...$29.95
    The first thing to do is contact Fuji and see if your warranty is valid, or if this can considered a factory defect and replaced by manufacturer, you never know.
    If Fuji does not cover you, purchase a warrant extension and repair the camera.
  • Ginko
    Ginko Feb 09, 2009
    Well, I have done my best.
    If you want refund email to premium support from home page
    Also please as soon as possible remove negative ratings given, that would be nice, we all have done our best.
    Goodbye
  • 10,594 Answers
I think shutter mechanism is stuck due to any foreign partical in its way to slide back and forth.
Need to apart camera to give close look in shutter mechanism.
    Master:
  • 848 Answers
Hi
connect your camera to pc and try copying all your pictures into it......then format the memory card and insert it into your camera......use new batteries and press the click button firmly.....problem still exists take to service center to repair hardware problem........
  • 1 more comment
  • gopinath pasupathy Feb 09, 2009
    perform reset to set your camera to factory settings ......problem still there you need to disassemble your camera and inspect the connection between the board and click button ....but this repair has to be done by technican .....
    you need to contact experts@fixya.com for refunding the money .....
    the solution to your problem is you need to disassemble the camera and check all the connection from battery terminal to board and from board to all buttons..........if you are willing to take risk .......i can help you out.....first you need special tool kits to open camera........check the continuity of connections......i once again tell you its bit risk to perform this action ......take to repair shop to repair it ........this is the only solution to your problem......
  • 679 Answers
Seems there is some alignment problem in leans.
  • rockfixya
    rockfixya Feb 09, 2009
    Try a reset--
    Reset: Resets all camera settings to their defaults.
    and also format the memory card using a format option.
    Note: you loose your data in both of case(reset or format).
    Thanks
  • rockfixya
    Yes, try to reset your camera as factory default.
    Brigadier General:
  • 3,614 Answers
Make sure that there was still a space to save picture.
try to use it without using a memory card
  • 1 more comment
  • micromaster
    micromaster Feb 09, 2009
    the lucky one is always on the right spot always,eh?
  • micromaster
    hi again,
    is there any incident that your camera has been dropped or any like case.?
  • micromaster
    for double checking, if you dont mind to do this again..
    DO fully charge the battery.
    make sure that the battery was a new rechargeable batt.
    better clean the battery contacts.
I have a Fine Pix S 3000 camera takes Fuji film is digital how do I upload my pictures from my camera to my computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Sep 02, 2010 | Fuji Rod Repair Kit
My SD card (FujiFilm - 2GB) has decided to make itself 'write-protected' after I transfered all of the photos to my pc & then deleted them from the card. Now it wont let me use it in my camera like it...
SD (and SDHC) cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 17, 2010 | Fuji Rod Repair Kit
Unable to read camera on laptop to load pics
Consider NOT connecting your camera to your computer.
Jun 06, 2010 | Fuji Rod Repair Kit
I have a Finepix F60 fd camera. I have installed the CD that came with the camera but I cannot download the pictures to my computer. Finepix viewer is installed on my computer but when I connect the camera...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
May 17, 2010 | Fuji Rod Repair Kit
Fujifilm z20 zoom error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Nov 28, 2009 | Fuji Rod Repair Kit
Ways on how do i download photos from camera to computer?
Nov 20, 2009 | Fuji Rod Repair Kit
Hi I have a fujifilm f470 finepix camera. One
Is it just the live view from the lens that you can't see ( totally blank screen), or are the icons visible?
If it still shows the icons but no live view then I suspect the shutter mechanism is stuck over the lens inside the camera.
Have a look at the lens and see if you can see the inner lens? You may have to adjust the zoom to bring the inner lens up to the end of the lens barrel.
If it is stuck then it will require removing and inspecting / cleaning.
Aug 26, 2009 | Fuji Rod Repair Kit
Dropped camera
Hello
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Jun 13, 2009 | Fuji Rod Repair Kit
I receive a 'write error' message after I take a photo
There should be a little switch on your memory card when you pull it out. Slide the switch the opposite direction. The switch is very small and usually on one of the edges/sides. This is similar to how floppy disks had a write protection on them.
Jan 12, 2009 | Fuji Rod Repair Kit
Fuji Rod Repair Kit Logo
20 people viewed this question
Top Fuji Sport & Outdoor - Others Experts
Are you a Fuji Sport and Outdoor - Other Expert? Answer questions, earn points and help others
