Question about HP Pavilion dv6000z Notebook
TOUCHPAD How do I disable the touch pad? I use a mouse and everytime my hand goes over the touchpad the cursor moves I have the same problem, but I want to use my mouse, I don't want to use an extra thing, I just want to disable the click function from it and use the the bottons under it. I have a HP pavillion dv6000. Macs have this function, how can I disable only the clicking from my touchpath?
  • 1 more comment
  • paohansen Feb 06, 2009
    Thanks for wanted to help, unfortunately I don't have anything called like that in my mouse menu. I went to control panel - mouse and the window "mouse properties" have 5 options, buttons, pointers, pointers Options, wheel, hardware. That's it, there is no touchpath. Do you know if it is because I don't have some of the drivers? Do I have to install something, and what? I have Ubuntu and it is sooooooo easy to disable the clicking from my touchpath!!!!
    If I click on pointers there is something called Scheme and Customize, but it is just to change the apearence of the pointer. And on the Pointer Options there are 5 options, selection of: the pointers speed, automatically move pointer to the default button in a dialog box, display pointer trails, hide pointer while typing and show location of pointer when I press the CTRL key.
    I thought about the drivers in order to find my touchpath and change its properties, but it is no where to be found.
    Now in the device manager there is another window with some other options for the mouse, like details, resources, power management, general, advance setting and driver. But I have tried and is not working. Any other idea?
  • paohansen Feb 07, 2009
    Sorry, I though you read the first message, I have a HP pavillion dv6000 and I have Windows XP. Again thanks for your help. I finally solve my problem. I did install the driver for the touchpad since I couldn't modify something that doesn't appear on my computer.
    So this is what you have to do if you can't find your touchpad:
    1, Go to google and search for: select software and drivers for hp pavilion dv6000 (or just write the name of your computer)
    2, Once you are in HP's page, look for the title: Driver - Keyboard, Mouse and Input Devices, click on "SYNAPTICS TOUCHPAD"
    3.On the next window, click on "DOWNLOAD ONLY"
    4. A small window will appear, click on save, and save the driver on your desktop (it's easier that way).
    5. Once the driver is on your desktop - clcik twice and just say next or accept to everything. The computer will restart and when you turn it on again...
    Click on start - control panel - mouse - the window called "Mouse properties" in my case doesn't have 5 options as before but has an extra one that is called "Device settings" So:
    1. Click on settings.
    2. A new window comes up and it is called "Properties for Synaptics TouchPad V6.3 on PS7" Port"
    3. Choose tapping.
    4. Click beside in "Enable Tapping"
    5. Apply and THAT'S IT.
    I hope this helps, I know it can be annoying when the cursor is sooo erratic :o)
Hey, keep in mind that sometimes when drivers are not loaded for the touchpad it lists as a mouse. if the driver is loaded you can usually goto it's icon and there is an option to disable touchpad. if the mfr's driver's arent loaded, then windows would've loaded some default drivers. you need to disable these by going into device manager, mouse and other pointing devices. then you must determine which one is your plugged in mouse (usually the usb) and which one is the touchpad mouse (it will often lists as 'ps2 mouse', 'standard mouse', or 'standard pointing device', or some other confusing description. locate it and right click and choose disable. this should do it.
if it doesn't allow you you then would need a more extensive workaround which involves installing the wrong drivers for the device leaving it in a malfunctioned state so that windows would allow you to disable it. read more here :
http://www.geekstogo.com/forum/how-do-i-disable-my-laptop-touchpad-t36025.html&st=15&gopid=1521435#entry1521435
-ljs063
Posted on Apr 27, 2009
  • 64 Answers
Go to control panel = mouse pointer = look for the pointing device, maybe its called synaptics pointing device on you too then you can unchecked the buttons and even the whole device itself from it.
Posted on Feb 05, 2009
  • Sacraty
    Sacraty Feb 06, 2009
    ic. because all i know when it comes to touchpads, you can always disable it through there. arent there any tab that says devices? i can disable mine through there under the devices tab. can you also try to tell me what laptop it is?
    and you dont install some drivers inorder to disable something.
  • Sacraty
    Sacraty Feb 07, 2009
    can you atleast tell me what laptop you are using?
How do I disbale the Lenova G550 touchpad Thank ou
To turn off the touchpad when an external mouse or other pointing device is present, you can go to the Control Panel and double click the Mouse properties icon.
a) Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting
Feb 22, 2011 | HP Computers & Internet
Orange light comes on occassionally on mouse pad and cursor freezes, how do i stop this
Tap the orange light quickly two times to enable the touchpad. Touch the same spot twice to disable the touchpad. To see the instructions from HP type "mouse" into the Search Programs and Files. Click on "Change mouse settings" and click Device Settings. Click on "Settings" and click "Touch pad disable zone". I was delighted to have found this as I had been restarting the computer manually to enable the touchpad. Shame on HP. The instructions for this simple problem are difficult to locate for the average user. They can do better.
Dec 08, 2010 | HP Compaq Presario F730US Notebook
How do you turn off the touch pad
Some notebook users find the touch pad annoying because at times, while typing fast, their thumbs accidentally brush up against the touchpad. This is frustrating because the mouse cursor jumps to a random location on the screen and can cause undesirable things.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Oct 24, 2010 | HP Pavilion dv4000 Notebook
My cursor jumps back to the beginning when i'm trying to type. i'm constantly having to backspace and correct and reset my cursor. any suggestions?
Disable your touchpad if you consistently have this problem.
When you are typing something, and you suddenly touch the touchpad (tapping this touchpad moves the cursor) then your cursor will suddenly change position which then mess up your typing.
If you don'r have an external mouse connected, better be careful not to touch the touchpad. If you have an external mouse, better disable this touchpad.
Mar 03, 2010 | Compaq Presario 700 470024-192 Notebook
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
Touch pad possessed.
For extra USB ports, purchase a USB hub($15 -$20). That way you can add at least 4 USB ports to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Toshiba Satellite A135-S4527 Notebook
I need to disable touch pad and use a usb mouse
Disabling touchpad for toshiba laptop is easy. Press FN and F9 simultaneously. Touchpad will stop working.
Sep 26, 2008 | Toshiba Satellite Pro 4600 Notebook
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Mouse cursor moving by itself
i have latitude c610 and same problem happens with me too. i think that happens when i finish my brakfat and without cleaning my hands start using the touch pad. what happens according to me is that small particles of food(eg bread/dust particles) stuck in the corners or the body wall where the touch pad ends and keeps pressing the touchpad, thus causing the mouse to move to one direction. when i clean the corners and sides of the touchpad, it starts working ok !!
thanks
Johal
Dec 12, 2007 | Dell Latitude C610 Notebook
TOUCHPAD
go to mouse setting under control panel.
You will find a place to turn it off.
Dec 01, 2007 | Compaq Presario M2000 Notebook
HP Pavilion dv6000z Notebook Logo
494 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
