Question about HP Pavilion F1703 17" LCD Monitor
17'' Packard Bell TFT monitor - power-led keep blinking continuous
I own a 17'' inch Packard Bell TFT monitor. Everything worked fine until now.
The problem is that when I plug in the power cord, the blue power on/off led keeps blinking continuously very fast. There is also nothing comming up on the screen. It keeps black all the time.
It's a defect in the monitor that I would like to fix maybe.
Does anyone has any suggestions for this problem?
Kind regards,
Danny van der Zee
El Duderino
  • 47 Answers
SOURCE: 17" Monitor keeps going black
Hi Rahni, It's a very common problem. LCD's use four small Cold Compact Fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Posted on Nov 18, 2006
SOURCE: HP mx705 17 in.CRT Conventional Monitor vertical goes bad
it seems that youre monitor has a dry solder problem, try tapping it if the picture resumes to normal for a while than get it resoldered from a technician. if it soesnot solve problem than look out for a burnt resistance.
Posted on Jun 26, 2007
bammbammfran
  • 159 Answers
SOURCE: Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Posted on Oct 18, 2008
  • 7 Answers
SOURCE: HP vs19e Computer turns on Monitor stays Black. blue light blinks
Easy step-by-step tutorial for replacing the caps in this monitor can be found at the link below:
http://boredprojects.blogspot.com/2009/09/hpvs19e-monitor-fix.html
Posted on Sep 28, 2009
  • 12 Answers
SOURCE: Monitor power light blinks, then goes out. PC screen goes black.
Unplugging the power cord repeatedly is not a good idea! I hope this helps: 1- After you get a picture, go to "Device manager" (Click on Start-Programs-settings-device manager) and make sure that there is not question or an exclamation mark next to Monitors. If that is the case you might need to reinstall the driver! 2- Make sure that your video card is not faulty by hooking up a different monitor and see if it is working ok. If you still have the same problem, then you need to replace the video card. 3- Check all cables and power cords and make sure that there's good connectivity on all ends (before powering up the machine) and that there are no nicks or cuts. If possible try replacing the monitor's data cable as well. Good luck
Posted on Apr 24, 2010
Packard bell one two m3700 wont turn on and no power light
Hello, sounds like the power supply or fuze is bad, needs to be serviced or replaced, you may have had lightning strike or power hit.
Nov 18, 2015 | Packard Bell Computers & Internet
How do I connect the pwer,reset,pwr led, hdd led on packard bell iextreme m5730 motherboard, serial number PTU300X0109251007D
They have a crappy website. I couldn't even find a motherboard diagram in the manual. You can determine which is the power pins by trying plugging the power connector in on each set of pins and pushing the power button until it starts. It needs to be plugged in when you try pushing the power button of course.There would be around 10 pins in two rows the power pins would be on the same row. they should be near the edge of the mother board and usually the power button pins are on the row furthest from the edge. I can't guarantee that though
Jun 20, 2014 | Packard Bell Computers & Internet
Hello sir, i hav LG CRT 15" monitor. After turning on, its LED continuous blinks and power button does not work and displays nothing. so plz suggest me what should be deffect?
Any 15-inch CRT-style monitor should be replaced by a 15-inch or 17-inch LCD-style monitor. You can find "previously-owned" monitors for $30 to $50, which is less than taking your CRT monitor to a TV/video repair-shop for an *attempt* to get it repaired.
Oct 04, 2010 | Computers & Internet
Screen is blank. Green LED power light is
Might be your graphics card, try swapping it out for a new one and see if that works
Oct 09, 2009 | Dell E173FPb 17" TFT LCD Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
LG 700E monitor's power LED blinking continueously, no display
LG 700E monitor's power LED blinking continueously, no displaySolution.............
Jan 23, 2009 | LG Studioworks 700S 17" CRT Monitor
LG Flatron ez t713sh 17" CRT Problem:
I already have the solution to that problem. It is a faulty capacitor that needs replacement. If you want you can copy and paste this link http://loversdelight-ididitmyself.blogspot.com.
Jun 30, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
No Power LED and Nothing on the screen
Check your power supply to your screen cause it should at least show a amber light at the screen to show that there is power but no proper signal from the computer.
So below are step to check the power supply to your monitor. Assuming if you use a different monitor on your pc it works
1. Check your fuse both internal and external
2. check if power is receipted by the LCD
Mar 24, 2008 | Dell 1704FPTt 17" TFT LCD Flat Panel...
HP Pavilion F1703 17" LCD Monitor Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
