Question about Samsung SGH-L700 Cell Phone
Problem with Bluetooth Transfer
My phone is Samsung SGH-L700, everytime I receive files from another bluetooth device like cellphones, the files were always saved to the phone's internal memory. Is there any configuration that is needed to be set so that files will automatically be saved to phone's external memory?
  • Anonymous Feb 19, 2009
    when I take a photo using SAMSUNG SGH-L-700 ,it is storing that snap in Phone memory,i want to store that one directly in memory card .please tell me a solution
  • Anonymous Feb 23, 2009
    this set sux.
  • 4 Answers
There is one easy solution for the second question: You can set your SGH-L700 to store your photos and/or videos on your memory card. Just go to Settings -> Application Settings -> Camera Settings. Go to the rightmost section using arrow keys and change camera's default storing location as memory card, instead of phone.
The bluetooth problem is not that easy. There is one solution if you send the files from your PC. Just browse your "Bluetooth Devices" from your desktop - your SGH-L700 will appear as an independent device. Double click it's icon, you'll see the folders in it, just like you're browsing your computer's hard drive. Open "Memory Card" folder then drag and drop the files you want directly inside it. I almost always prefer this way when I use bluetooth transfer.
If you try right clicking on a file on your PC and choose "Send via Bluetooth" from the context menu, SGH-L700 receives it directly to the phone memory. So I recommend using "Bluetooth devices" option and placing the stuff directly in the memory card, just like you copy items in any place on your hard drive.
But there is not a standart solution for sending a file from another cell phone to SGH-L700. Some devices can browse SGH-L700's folders like your PC does, but some of them can't - and they just send the files to the phone memory.
Posted on Feb 21, 2009
How can i access net through samsung sgh-l700 connet to laptop using bluetooth
connect mobile with pc through pc sutidio through bluetooth their is a option in pc stuido that connect moblie through bluetooth and then u open netwrok wizard and then connect through internet
Apr 16, 2010 | Samsung SGH-L700 Cell Phone
Need to transfer files to mac
You can follow this steps for your concern: Via Memory Card 1. Remove the memory card slot cover, located on the right side of the unit. 2. Insert a microSD memory card into the memory card slot until it locks in place 2. On the SGH-i607, navigate to the folder that contains the image 3. Highlight the desired image 4. Press the right soft key for Menu 5. Select Edit (4) 6. Select Copy (2) 7. Navigate to the Storage Card using the up or down navigation keys. 8. Press the left soft key for Select.to copy the image to the memory card Via Bluetooth On the SGH-i607 1. While in standby mode, turn Bluetooth on 2. Switch the Bluetooth visibility to On On the PC 1. Connect the Bluetooth adaptor to the PC?s USB port 2. Search for Bluetooth devices 3. Select the device to pair with the PC 4. Exchange PIN code(s) on both the PC & handset to pair devices (default pass code is ?0000?) 5. Using My Bluetooth Places, select File Transfer or OBEX to view the phone?s contents 6. Copy the desired Photo file 7. Paste the file in a PC destination
Feb 02, 2010 | Samsung Blackjack SGH-I607 Smartphone
Samsung a177 bluetooth help??????/
I'm sorry buddy because there is no way for your phone to pair up with other BT capable phones because eventhough the phone has bluetooth, it is only capable of pairing up with a bluetooth carkit & bluetooth headset.
The SGH-A177 does not have a File transfer profile (FTP) under the bluetooth profiles that ur phone is supporting.
U need to have another higher model but call Samsung first to inquire if the other Samsung phone you want to buy has a file transfer profile.
check this bluetooth article.
that info is straight from Samsung....
Dec 16, 2009 | Samsung A177 Cell Phone
I cannot connect my cell a177 to another device via bluetooth
I'm sorry buddy because there is no way for your phhone to pair up with other BT capable phones because eventhough the
phone has bluetooth, it is only capable of pairing with a bluetooth carkit & bluetooth headset.
The SGH-A177 does not have a File transfer profile under the bluetooth profiles that ur phone is supporting.
Dec 14, 2009 | Samsung A177 Cell Phone
My samsung phone sgh L700 did not responce any . *JAR AND* JAD file
you have to install .jar with pc suite. samsung can't install .jar received from irda or bluetooth
Mar 23, 2009 | Samsung SGH-L700 Cell Phone
I want sumsung sgh l700 driver
If your problem is transferring files between PC and SGH-L700, you have 3 options: USB cable (which you don't have), bluetooth connection and memory card.
If your PC has a bluetooth adapter, it's very easy: Just open both devices' bluetooth visibility, set a passkey for communication between them, then transfer the files in your phone using bluetooth.
The last option is, saving the data on your phone to the memory card (MicroSD) then inserting it to your PC using a simple (and very cheap) card reader. You can then transfer files between your two devices.
Feb 18, 2009 | Samsung SGH-L700 Cell Phone
Direct mp4 recording by mobile & save file direct in memory card
how I save file direct memory card when I use Bluetooth ( From other mobile to mine)
Jan 21, 2009 | Samsung SGH-L700 Cell Phone
Mp4 vedio recording
recording has its own format...u cant change it to mp4.............u even cannot directly save d files received via. bluetooth to the mmc....it is prefixed to be stored in phone memory......
Receive Photos on Samsung E-900 Phone
you can receive photos via bluetooth or by USB via a computer.for bluetooth you need to switch it on and make your device discoverable by other bluetooth devices from which the photo has to be sent.be sure to switch off bluetooth once its done or you may get a virus!
the other way is to transfer via usb connection from a computer.samsung would have given you some software for synchonising with your mobile phone.
hope it helps!
all the best!
Oct 14, 2008 | Samsung SGH-E900 Cellular Phone
Bluetooth issues.
Have you sync'd the phone with the bluetooth device? If you have then before you can transfer files you need to right click on the bluetooth icon in the system tray and choose either send a file(from computer) or receive a file(from phone). Hope this helps.
Dec 11, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Samsung SGH-L700 Cell Phone Logo
732 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
