Question about Digital Audio DA8012 12" Subwoofer Car Speaker
Negative and Positive markings missing on car stereo speakers one connector requires a larger clip than the other, can this make it possible to tell if one or the other is a pos or neg connection. If so tell me which one is what. With Kind regards from James.
    Sergeant:
  • 227 Answers
The speakers have to be polorized. If you take a small battery and put the negative to one terminal and the positive to the other you will see the speaker push out or pull in. Just tap the battery connection to the speaker. The one you see the positive of the battery push the speaker out will be your positive side or terminal. Make sure you mark a + sign on all the speakers to get uniform polarization.
Posted on Feb 05, 2009
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
May 25, 2011 | Clarion Car Audio & Video
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
The radio in my jeep isn't connected right. Some of the wires have come apart. i bought new **** connectors but how do i know which wires go together?
1994 Jeep Grand Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Green/Red
Left Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue/Red
Left Rear Speaker Negative Wire (-): Brown/Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
Thank you for using Fixya and good luck
Mar 22, 2010 | 1994 Jeep Grand Cherokee
Which connections is the negative on these
most car stereo speakers have two connectors, one thinner and one wider. the wider one is typically the positive connection. to verify this, take a small 1.5v battery, and hold a wire to the negative and positive sides (it's easiest to use a battery case available at many electronic stores), connect the negative wire to the smaller connector, and tap the positive wire to the wider connector. if the speaker pops outward, then the thinner connector is the negative connector.
Jan 17, 2010 | Alpine SPS-609 Car Subwoofer
I have a 1997 s10 4x4, and my memory wire is missing, i need to know what fuse, or wire i can run the wire to so i wont have to keep reseting my radio?
1997 Chevrolet S10 Pickup Truck Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
Jan 14, 2010 | 1997 Chevrolet S-10 Pickup
Im changing factory radio to jvc and cut wires which ones are power source
here is a wiring color break down.
1987 Lincoln Mark VII Car Radio Wire Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red
Car Radio Illumination Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Pink/Blue
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Blue/Orange
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
please rate my help.
Jul 26, 2009 | 1987 Lincoln Mark VII
Dont know how to hook my sony explode radio up to my 1998 chevy malibu
here is a diagram of the radsio connector wire colors in your car, just match them up to your Sony.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size: 4′ x 6′
Apr 22, 2009 | 1998 Chevrolet Malibu
Wiring harness 1996 baretta radio
1996 Chevrolet Beretta Car Radio Wiring Diagram By Wire Color
Car Stereo Dimmer Wire: Light Brown
Car Audio Front Speakers Location: Kick Panels
Mar 22, 2009 | 1996 Chevrolet Beretta
I`M REPLACING THE ORIGINAL RADIO ON A 1996 GMC JIMMY, I NEED TO KNOW WICH WIRES ARE WICH, (ALL THE POWER ONES) OLD RADIO NOT AVAILABLE
PLEASE RATE MY SOLUTION, THANKS.
1996 GMC Truck Factory
Stereo Wiring Chart
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Mar 08, 2009 | 1996 GMC Jimmy
Color diagram for speakers
1995 Ford Windstar Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 24, 2008 | 1995 Ford Windstar
Car Audio & Video Logo
1,859 people viewed this question
Top Digital Audio Car Audio & Video Experts
Joe Ankney
Level 1 Expert
Tom Chichester
Are you a Digital Audio Car Audio and Video Expert? Answer questions, earn points and help others
