Question about Siemens S75 Cellular Phone
Siemens s75 system freeze
I am having a siemems s75 but  it developed a seriouse problem which i cannot understand. when switched on it allow me to visit limited plces and when i try to do some other stuff, its whole system get freeze. i can't do absolutely any further thing even even the switch off button fail to operate.the only option left for me to do s to remove the battery and insert it back and start all over.the whole system seems to be corrupted and even if some one call me, i wont be able to answer it at first because would only hear the ringtone but wont see the caller id on the screen.i can't use most of its features because the phone get freeze when i try to. i can't use the t9,alarm clock,phonebook,infrared and even cant use my received items send by oda phones.unfortunately i don't have a usb cable.so wantd to know whether i can fix the problem by browsing in to it by another phone. wul gladly appreciate any form of help asap
This is due to moisture in between screen and chip to recover it open and use hot air to remove all the moisture and fit it and avoid using it in low temperature.(AC room etc)
Posted on Feb 05, 2009
SIEMEMS WASHING MACHINE ERROR CODE F:26?
F20-30 is drain or intake
and can be within a given time
so can be something inside the pump or drum skin
or a bad intake valve filter ...
try reading the user manual
look at the makers site i found it easy...
and it has the error code list
your lazy or not looked...
youll find the info you need
try this also from a similar issue
http://www.manualslib.com/manual/770034/Siemens-Wfxd8400uc.html?page=34
look at the ' water does not enter the machine'
cross reference with other machines that c=share the same controllers
here is the answer i found about F26
The error F26 does indicate a fault in the door switch . There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close.
This is most likely a problem with the door switch
interlock
or a loose connection at the switch but not likely
its more likely a burned connection
and has high resistance so you perhaps need to check out the wires plug.. etc make sure the contacts are very good
The door switch is part of the door lock assembly part number 8183270 {not sure this is right}
this info is from a maker that uses the same chassis
not the same parts number
its prob the door switch ....!!!
Aug 17, 2014 | Siemens Washing Machines
I have a Fujitsu Siemens M1450G and when I start it can not access the BIOS. When I switch ON the PC on the screen say (FUJITSU computers SIEMENS) and then this sign freeze and then noting happen. What...
Hi
It may be worth trying this
switch on and same time keep pressing the F8 key
hopefully it will take you to the options for repair
try last know good configuration or system restore back to when it was ok
or try to ask windows to repair
good luck
hope you can get sorted
Feb 25, 2011 | Fujitsu Siemens AMILO Pro V2010 Notebook
How can i open my siemens cell phone model AX72, it is in phone lock situation.
http://www.nikeexpert.com/
May 31, 2010 | Jabra Siemens af51 / ax72 / CF110 / CX75 /...
Fujitsu Siemens Amilo li 1705 freezes/reboots
This problem is common on this model, I have 3 with similar symptoms. The cause is bad soldering on the graphics chip as far as I know. I have been looking for someone who knows how to fix it. I think a reball is the answer.
Mar 27, 2010 | Fujitsu Siemens Computers & Internet
Can't viewing the main menu and hang
Press power and volume + button it will enter in recovery mode now you wipe factory data reset
Oct 26, 2017 | Siemens S75 Cellular Phone
Fujitsu Siemens AMILO D1845 keeps freezing
have you tried a fresh install of xp I do not understand?
Oct 24, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
BATTERY
You can get a replacement battery for the siemens s75 here - siemens s75 battery
Aug 21, 2008 | Siemens S75 Cellular Phone
Dsc-s75 capacity
The 85 and 717 were the first cams able to use a contigous 256Mb Pro stick as far as I know, the 707 and 75 are stuck with the originals or the Switchable ones which defeat the object as if you've gotta pull it to switch "halves" you may as well take 2 normal and cheaper sticks along..
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
Siemens S75 Cellular Phone Logo
380 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Yoav Shilon
Yoav Shilon
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
