Ruud System not working
Hi I have a Ruud Achiever heat pump model number UBHC-17J11NFH We've been having problems with the system my wife and I and have had a company come out twice in the past week and paid for each visit first it was the t-stat that was bad now we have a Braeburn 3200 then after that we had the transformer replaced because it worked for 2 days then quit and after the transformer was replaced it was the same deal. Now I don't know what to do. I can hear it trying to kick on by the signature clicking sound as if being told to turn on but neither the heat as we desprately need or the air are kicking on and with the company having come out twice and not fixed a friggen thing I'm searching for something that I may be able to accomplish myself..Keep in mind I have not touched looked or messed around with a heating unit before. Please help.
Mike
  • 56 Answers
Sounds to me like you have an electrical problem (a short of some kind) If you are not familiar with the workings or wireing I would suggest calling another company out and see if they can fix it. Sorry those problems can be hard to diagnose without actually seeing the unit. I wish i could help more.
Posted on Feb 12, 2009
I have a Ruud Model UAFD-036JAS Air Achiever 9 split system, when i try to turn on the a/c, nothing happens. I've replaced the contactor, run cap., put in a starter cap for the compressor, replaced...
If you push the contactor and it runs why replace all that stuff??? You have to figure out where your 24 volts stops on its way to the condenser contactor. wire red green and yellow together at tstat, this should bring on indoor fan and condenser. if idf runs but cu does not you have an issue either going outside or a pressure switch is tripped. if nothing runs you have no 24, either a blown fuse, tripped float or bad transformer.
Oct 03, 2017 | Ruud UBHC Air Conditioner
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-21J18SHG. What size filter should I put in this system?
The Ruud UBHC-21J18SHG has a nominally 21" cabinet width. So the needed filter is 19.75" x 21" x 0.375" (502 mm x 533 mm x 9.525 mm). The Ruud part number for the filter is 54-23217-03 .
The specifications sheet for the Ruud UBHC series air handlers is available here: http://www.coburns.com/images/PDFs/h22-517rev1.pdf . The filter size information is on page 3 and page 12.
I've found the filter at one online vendor: http://www.patriot-supply.com/products/showitem.cfm/RHEEM_68_101807_03 . (This is a common filter that fits several manufacturer's air handlers.)
I hope this helps.
Sep 10, 2011 | Ruud UBHC Air Conditioner
Ruud Achiever 10 heat pump - outside fan won't shut off
Definately get this checked out. Some thing has shorted just enough to let voltage "Feed back" and keep the fan running. Could be capacitor, wires rubbed through each other, etc. A reset is a safety that is used when there is an overcurrent or over pressure situation. No reset set for this situation.
There is always an outside chance that if you touch the unit while standing on wet ground, you may get shocked. I firmly believe that something is allowing power to the fan in a feedback condition so don't let this go as it may cause damage to other parts.
Good Luck and let me know how you make out on this.
May 11, 2009 | Ruud UBHC Air Conditioner
Replacement of filter on Ruud Achiever series heat pump/AC
You must first remove the blower compartment panel. The filter should be in there. However, since this unit is in a crawl space you may have a return air filter grill. Look at your return grill. Does it have a filter? If not does it have latches so that you can open it? If so measure the opening and install a new filter there. I hope this helps. Please don't forget to give me a Fixya rating.
Feb 21, 2009 | Ruud UBHC Air Conditioner
How do I change the filter in my Ruud Achiever series
I'd look in one of 2 areas.
1. often there is a central return in the house. This is the place where the air gets pulled back to the unit and is likely very close to your thermostat. Check for a filtered louvered grill there and see if your filter is located here. If so, you can access the filter by opening the filter frame with a screwdriver or even a coin.
2. Otherwise I would expect that your filter is on the return-air side of your air handler (where the blower is) Older models have the filter actually inside the air handler in the blower compartment. Newer models may have a small separate filter door. I'd look in these areas.
hope this helps
ghoff
Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Feb 05, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Ruud achiever heat pump
the reversing valve needs power to switch to heat. more then likly the o wire is connected when it shouldnt be
Jun 15, 2008 | Ruud UBHC Air Conditioner
Ruud achiever 9
ubhc is not an achiever 9, your condenser maybe but that air handler is not.
Feb 08, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
137 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
