Question about Creative Labs Zen Stone Plus MP3 Player
File system error
When I power up the creative logo comes on and then the message file error the player then tunrs off. Tried the reset but it made no difference :-(
  • pbird361 Mar 01, 2009
    Thanks Ethan
    Worked a treat after I'd formatted the player again.
    Problem Solver:
Go to the creative site and download the creative rescue tool
download it and follow the instructions i had the same problem you will lose all song on it but it works it is to fo with softwear
Posted on Feb 27, 2009
Hi im getting this error message whenever i try to tunr on my system "ALERT!PREVIOUS ATTEMPT AT BOOTING THIS SYSTEM HAS FAILED AT CHECKPOINT VINI - FOR HELP IN RESOLVING THIS PREOBLEM" cant get in to...
reinstall the operating system.It seems either a virus or someone has deleted an operating system file. But if its windows you can try a repair using the operating system CD.
Aug 02, 2010 | Computers & Internet
Zen Stone Plus show 'File System Error" after format
u can download the recovery tool from and easy...good luck...XD
Jun 24, 2009 | Creative Labs Zen Stone Plus MP3 Player
Creative zen m vision won't start up,
You tried these yet?
Reset, Format or Clean Up a Zen Vision:M
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
Press on the Menu/Back button on your player, and select System, and then Reset.
To Format or Clean Up Zen Vision:M
1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
If the battery is too low, charge the battery fully before continuing
2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
4. Release the Power switch when the Creative logo appears. The Recovery Mode appears:
* Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
* Format All (Formats the players hard disk - Note: all contents will be lost)
* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
* Reboot (Reboots the device).
5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.,Case=obj(14048),Kb=ww_english_add
pls rate it, thanks
Nov 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen wmv file problems
I would try to convert that file to AVI through a seperate open source program such as this If that doesn't work...i would try to put a file that is smaller...
Jun 07, 2008 | Creative Labs Zen Touch MP3 Player
Using the instructions below try Cleanup first, if that doesn't work... (if you have a backup of all your music on your computer), try the format option
This is from Creative's website:
Zen V Plus and Zen V
  1. Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Message Edited by Jason-CL on 09-11-2006 12:02 PM
Forum Administrator
Creative Labs
Jan 06, 2008 | Creative Labs ZEN V Plus MP3 Player
It says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error?? It says File system error when I turn it on and then it turns itself
it says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error??
Nov 26, 2007 | Creative Labs MuVo V200 MP3 Player
File System Error
Make sure the files you drag are mp3 and not audio files straight from a cd. If they are from a cd you need to put them in to the library of your music software first this should convert them to mp3 format
Sep 28, 2007 | Creative Labs Nomad MuVo TX MP3 Player
Creative Zen nano plus write file delayed
My creative zen nano plus 1GB bought 6 months back, when connected to the comp it hangs...then after long time it gives an error message that write file delayed in F:. I didn't even try to write any file...the right click also hangs the computer after long time
Aug 01, 2007 | Creative Labs Zen Nano Plus MP3 Player
Zen not working
You might just have to completely reformat and reset the OS/Firmware your player. Note: THIS WILL REMOVE ALL SONGS/VIDEOS/PICTURES FROM THE DEVICE! To reformat: 1. Hold the power switch in the ON position 2. Insert a paper clip into the RESET hole. 3. Continue holding the power switch ON until the Creative logo appears. 4. Select Format All from the Recovery Mode menu. 5. Select Reboot To reset the OS/Firmware: 1. Go to 2. Under Select Your Product select MP3 Players > ZEN > Zen Vision: M (either 30GB or 60GB model depending on what you have) 3. Select your operating system and Firmware from the File Type drop down box 4. Download the file from the next page to your Desktop 5. Agree to the stupid EULA and download the file 6. Connect the player to the computer 7. Once the player is recognized, run the .exe file 7. Follow the on-screen instructions If you are still having problems, or any of the above does not work as planned, let me know.
Feb 21, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Zen Stone Plus MP3 Player Logo
241 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
