Question about Lexmark X7170 All-In-One InkJet Printer
Carrier stall my lexmark x7170 is sho.ing that there is a carrrier stall. where is the carrier stall?
    Problem Solver:
  • 10 Answers
The carrier is the carriage tat holds the ink, it rides on a steel bar back aand forth open up unit t o see if it is stuck
Posted on Mar 17, 2009
Lexmark X7170 not working with Linux Mint
I regret to inform you that the Lexmark X7170 does not work on Linux Mint. Unfortunately, there is no driver available driver for this previous generation printer model for your Linux system.
If you want, you may contact Lexmark Technical Support Center to search for other Lexmark printers that can work on your Linux system and that meets your printing needs.
Nov 19, 2011 | Lexmark X7170 All-In-One InkJet Printer
Carrier jam lexmark x7170
It could be due to the cartridges or the encoder strip (transparent strip found behind the cartridge carrier) has gotten loose from its position. Please follow steps below to identify and fix the problem:
1. Open the printer cover and remove both the cartridges. Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.2. Check the encoder strip and make sure it is secured in its place.3. Close the printer cover.4. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.5. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.6. If no error appears, reinsert the other cartridge. Close the printer cover.7. Replace whichever cartridge is causing the error to appear with a new cartridge.8. If no error appears, try to print a document again to verify that the problem is fixed.
Let me know if this helps. Thanks.
Nov 01, 2011 | Lexmark X7170 All-In-One InkJet Printer
Lexmark printer x7170 cartridge error 1203
The 1203 error indicates either a communication problem between your cartridges and the printer or a short in one of your cartridges. Please follow the steps below to identify and fix this issue:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 19, 2011 | Lexmark X7170 All-In-One InkJet Printer
It does not copy or print it displays error 2200
The error indicates the has stalled or jammed. This article in the Lexmark website on 2200 Error on the Lexmark X7100 Series All-In-One might help fix the problem.
Mar 21, 2011 | Lexmark X7170 All-In-One InkJet Printer
What do you do when you get an error: 2200 for the Lexmark X7170 printer?
The error indicates the scanner has stalled. Please refer to this article from the Lexmark website on 2200 Error on the Lexmark X7100 Series All-In-One. Hope this helps. Thanks.
Jan 18, 2011 | Lexmark X7170 All-In-One InkJet Printer
I just purchased a lexmark 2600 series and carrier is missing
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source.
Jul 14, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Cartridge carrier on x7170 missing?
In some cases, the cartridge carrier doesn't move to the loading position even when the printer is on and the cover open. Try this. With the cover open, unplug the printer from the power source. You'll notice a solid white tape in the center of the printer. Hold that tape because the other end of it is connected to the cartridge carrier. Slowly slide the carrier to the center for easy access. Load the new cartridges. Close the lid, close the cover and power on the printer. Now, if there is really no cartridge carrier in the printer at all, unfortunately it's not sold separately. It comes with the printer as a whole. It's not available for part replacement.
Apr 18, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X7170
ahh..not too good..that's a sure sign that there's a jam inside of the unit..open it up, after powering down, and inspect it thoroughly
Apr 30, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error: 2200
Scanner stall....try rebrickin the power supply and also check for the scanner lock and unlock it if its locked..also clear NVRAM
Apr 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X7170 All-In-One InkJet Printer Logo
513 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
