Question about PC Chips M848ALU Motherboard
M848alu i have a connection probl. regarding how to plug in pins for the audio on maniboard. it is a nine pins, an it is placed on back of m.b which nr on the pins are 1 and 2
  • michael170 Feb 05, 2009
    thankyou Rod
    best regards mike
  • 1,602 Answers
GO TO WWW.MOTHERBOARD.ORG,
WWW.TWINIGHT.ORG/CHIPDIR
WWW.TOMSHARDWARE.COM
WWW.PCGUIDE.COM
WWW.ATIPA.COM/INFOSHEETS/IRQS.SHTML
LOOK FOR A SYMBOL OF A SPEAKER AND #1 PIN OR JUMPER, SPEAKER MAYBE ABBREVATED CALL CONSTASTS NO VOLOWS, REALLY BAD SPELLER, FULL OF INFO
THE LAST WEB SITE IS FOR COM PORT PROBLEMS AND IRQ ERROR AND ISSUES DEALING WITH SOUND.
ROD
Posted on Feb 05, 2009
Hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
Sound cable connection
Look more closely at your motherboard, for a 4-pin "PC Speaker" label.
The "HD Audio" is _OUTPUT_ (left front, sub-woofer, right front, left back, right back) to Surround Sound speakers.
Dec 31, 2009 | Foxconn (945G7MA-8KS2) Motherboard
How to reset passwd in admin setup in gx280. i took the batery off but that did not help.
Before you begin,
http://tomcat.yc.edu/servman/desktops/GX280_UG/before.htm#1107075
Then;
1: Locate the password (PSWD) and CMOS (RTC_RST) jumpers on the system board.
2: Remove the password jumper plug from its pins.
3: Place the password jumper plug on the RTC_RST pins and wait approximately 5 seconds.
4: Remove the jumper plug from the RTC_RST pins and place it back on the password pins.
Just remember to take your time and don't get nervous working on the computer. Please report back to the thread the results of your work.
Regards;
Hassan
Jul 08, 2009 | Dell Optiplex GX280 (99301) Motherboard
I'm installing a card reader that has 5 wire connector tto the mb. The old card reader has a 7 wire connector that fits the mb. Its an Asus m2n68-vm. Thanks
These card readers normally fit the auxiliary USB socket on the motherboard. They usually take up all nine pins, four on one row and five on the other with a 10 socket plug. One pin missing on the end of a row.Such card readers have an additional external USB port as well as card reader slots. If it is just a straight five pin plug but with four wires it just fits over one side of the nine pin USB socket on the motherboard. The black wire goes at the end with the missing pin.
Mar 29, 2009 | ASUS P4P800SE Motherboard
Front panel connections
Hi sjcrofts,
The most common problem for most people is knowing what wire color is positive & which wire color is negative. The colors blue, red, green, light blue, light red & light green are normally positive. The color white & black are negative. Your board uses only 2-pin connectors. The 3-pin power connector can be turned into a 2-pin connector to work with the M848ALU pins.
(Page 13, PANEL1). How to? Take the three pin connector, on the back side of the connector you'll see a small tab that holds the wire into the connector. Use a needle & pull tab up while pulling the wire out at the same time. The wire should slide out. Insert the wire back into the connector next to the other wire. You do not need to hook up the SUS led which stands for suspend.
Pin 1 is positive & the manual shows this by adding the _P = positive.
Pin 3 which is to the right of pin 1, is negative for the hard drive led. Pins 9 & 10 are not used.
Good luck sjcrofts!
Mike
Nov 30, 2008 | PC Chips M848ALU Motherboard
ASUS A7n 266 VM Sound Problem
I think you are refering to the front audio pin that are dislodged. Refer to your user manual for the pinout diagram, If there is some other problem get back.Thanks
Sep 19, 2008 | ASUS A7N266-VM Motherboard
Connecting audio to front of computor box from motherboard
elecstar, do your self a favior & download this manual asap.
It will not be listed for much longer. Click the link below than click Manual.
http://www.jetway.com.tw/jw/downloadshow.asp?productid=V266B#
430fcb8.jpg Have more questions, feel free to ask.
Good Luck!
Mike
Mar 23, 2008 | Jetway V266B Motherboard
PC Chips M848ALU Motherboard Logo
107 people viewed this question
Top PC Chips Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Steven Burn
Steven Burn
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
