Question about Craftsman 24 Hp 48" Deck Yard Tractor
24 HP Craftsman tractor turns over but will not start
I changed the plugs out then found out they were wrong so put the old ones back. Checked the air cleaner and washed out the foam cleaner. I was able to get it started when I primed it. But it won't start without first priming it. I see gas in the fuel filter. Okay I am not a mechanic I need some direction. Please?
Flutemaker sawdust is my specialty
  • flutemaker Feb 05, 2009
    I checked the choke and cable is working from choke pull to carb. Seems smooth and when It is running the choke did assist until warm. So without removing the entire housing to visually look at the choke I think it is okay. Thanks for the input. Once this is solved I have a part two. That will keep for now, just want my rider to start without priming.
Check the choke to see if it closes
Posted on Feb 05, 2009
  • timmie324 Feb 05, 2009
    did you you try to run some carb cleaner throuht it if it sat all winter long you might have some gunk in the jets
Craftsman 917.270514 not starting?
check to see if your getting power to the solenoid on the bottom of the carb a bad safety switch will shut it off they also stick closed from old fuel
Jun 04, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 2007, 6500 Craftsman tractor with 26 hp engine (kohler) that won't start. The tractor was running (old gas) when we got off it for a few minutes then went back to start it again but it would not...
First check fuel shutoff valve on bottom of carb . Disconnect and remove , clean witn carb cleaner and be sure there is power at wire when the key is on . Also clean carb jets and bowl .....
Jun 11, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
After mowing for about 20-30 minutes the engine speed dies then revs then dies until it eventually shuts down. It will restart later but will eventually do it again. I've changed the spark plugs, fuel...
I had this problem with my new Craftsman mower about a month ago. Sears came out to my house and said it was a problem with my gas lid. They said it was too air tight and didn't allow for air circulation. They drilled a very small hole in the top of the gas cap and it fixed the problem. They mailed me a new replacement gas lid and it fixed that problem. Hope this helps you.
Aug 09, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Hard to start
Have we had a tune up on this tractor lately. Like changing spark plug, air filter, oil and may be even the gas in the tractor.
Clogged air filter, Bad gas, fouled spark plug may be your problem. Like everything they need maintenance one in a while to keep them running well.
You just can't get on them and ride.
HTH
Good Day.
Oct 28, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
10 year old Craftsman Lawn Tractor won't start
That's really strange. The low-speed fuel adjustment screw may be set way too rich, but that doesn't seem likely. With the air filter off, look at the choke plate if possible as you advance the throttle and see at what point the choke closes. Back it off till the choke opens and then put the filter back on and try to start it at that setting. Another thing that could cause too much fuel is if the adjustment of the carburetor float is off, causing the fuel level to be too high in the carb bowl.
Aug 03, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Replace air filter on Craftsman 3000 garden tractor
the "baffle" that looks like half of a funnel goes on the stud with the open end up, the orange rubber hose goes on the stud to hold the baffle in place, the air filter then goes on and is supposed to be held on with a wing nut, then the outer air filter cover goes on
Apr 21, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Mower backfires and loss of power
i would also check fuel flow. pull the gas line from the carb and see if gas flows out at a good rate (into a metal can of course) or if it trickles out. if the latter, then gas tank either has junk at the bottom preventing the gas from flowing or the vent hole (usually on the gas cap) is plugged.
i have also had my carb float bowl rust out on me, but that took 10 years.
Jan 21, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Transmission won't engage
My Craftsman 24 hp twin 42in cut motor runs ok as well as the lawn mower. However will not move forward or backwards something is not connecting.
Sep 21, 2008 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 24 Hp 48" Deck Yard Tractor Logo
299 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
