Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
No water comming onto the cxarpet
I have Bissel proheat x2. It works for cleaning using the hand haeld nossel. But for carpet cleaning, there is no water or solution comming out. So at the moment I can't use it clean carpets.
Remove the water tank and pull up those two red tabs unhook them and push something small thru them they are clogged up that is where your water releases it works I just did it and my bissell works great now!
Posted on Feb 11, 2009
My bissel proheat will work fine with the attachment hose but water will not come out of the bottom for carpet cleaning!
Hey Christy. I'm sorry you're having difficulty with the spray. I know how frustrating this must be.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1065&cid=ccsocial
Apr 14, 2013 | Bissell 1699 ProHeat Clear View Upright...
New bex bissel wont release water onto carpet
Hey Margart! I understand how frustrating it is to have no spray when trying to use a machine.
We have a terrific list of FAQ's on our website to assist you. Here's a quick link: http://www.bissell.com/faqs/?cid=ccsocial
Feb 09, 2013 | Vacuums
Since the last use of my new ProHeat X2 carpet
Check the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool mode). On the underside of this section is a small (about 1 inch square) red plastic piece with a little door on it. Flip open the door and you will probably find it is clogged. Clean it out and you should have full suction again.
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Instruction manual for a bissel proheat model
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Jun 04, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Using Bissel proheat carpet shampooer. Have used
No, you don't dilute it. And yes, it does use a lot of formula!
Apr 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel Proheat Carpet cleaner
My Bissell had the same problem. The hand attachment does not use heated water. So I Found a clog of calcium and dirt in the heater portion of the unit. The heater is in the handle behind the red heater light on the front. Remove the upper portion of the handle. Remove the lower two screws in the lower portion and the parts will split apart. Remove the hoses and remove the heater. (mark where the wires go) The bottom of the heater can be removed with a screwdriver. The tubes leading into the heater is where the clog was but there was a lot of debris inside Make sure to clear it all and the hoses as well. I put it together and it works great.
Nov 23, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
202 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
