Not agitating the agitator is not moving during the loads
  • zenredhead Feb 19, 2009
    The washer has 4 different wash cycles (hand wash, knits..) it will only agitate on the knit cycle now. No other cycles. And not all the time, it's very random
  • Washing Mach... Master
  • 1,525 Answers
Could be brushes on the motor
Posted on Feb 05, 2009
The agitator is barely moving - I am not sure if is fully engaging during the wash cycle? How can I check it out?
If the agitator is working it will move slightly, then back - over and over again and cause the water to, well, agitate.
If you have the machine set to delicates it might not come on full force.
Usually you can check it out by opening the lid during a wash cycle.
If it's barely moving then you might have drive/belt issue.
Dec 07, 2009 | Whirlpool LSQ8000 Top Load Washer
Agitator stops while in spin cycle
Assuming that this is a basic Whirlpool top load, direct drive, neutral drain washer, the agitator is supposed to stop during the spin cycle.
Please see the following Whirlpool installation and service manual for top load machines.
If you look at the description of how the transmission works, there is an "Agitate Cam" that lifts the "Agitate Gear" out of contact with the main "Agitate Rack" when the machine goes into spin mode
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I have found though that because of the friction between the agitate gear and main drive shaft, including the oil itself, the agitator may move while in spin mode.
Oct 14, 2009 | Whirlpool Washing Machines
Kemore 90 Serieswashing machine fills and spins but won't agitate
Remove the agitator and see if the agitator shaft moves during agitate. If it moves then the agitator spline is worn or the agitator dogs are worn and the top half of the agitator will not work. If no results then the gearcase would have to be replaced
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Agitator not agitating!
It sounds like your agitator dogs are worn and need replacing. Yes...there is such a thing. They are small teflon (I believe) plastic pieces that help the agitator grip properly. There are 4 of them under your agitiator cap and costs about $6.00 for a package of them. It only takes minutes to replace. If you can give me your EXACT model number, I can determine a part number for you, and give you advice on how to change out the dogs. Post back with your comments and let me know.
Feb 11, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
Whirlpool top load washing machine - agitator
There are gears inside the agitator that are very cheap and relatively easy to change they are called agitator dogs. Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Sep 30, 2007 | Washing Machines
Wheezing sound
The inside tub moves on the spin stage only and cause the water, by a centrifugal force, to be forced out of the clothes. During the wash cycle,the tub is stationary and the agitator moves forth and back. If you would like to remove the agitator - Remove the inner agitator cap (inside the top of the agitator) and then open the screw (be aware not to lose parts !) Good luck !
Jun 11, 2006 | Whirlpool LSQ7533JT Top Load Washer
Washing Machines Logo
149 people viewed this question
Top Washing Machines Experts
