Question about Pioneer GM-6300F Car Audio Amplifier
My pioneer 600w amplifier cuts at high volume...
My amplifier cuts off at high volume..i did everything possible told by the proffessional...also claimed warranty...they say its proper still same problem plz help me out>?
  • MLIFERM Apr 27, 2009
    i got the same problem with mine and i have had other problems with it over heating and such but mine was done professionally by me
This means that the enternal preamp is starting to fail eventualy it will make no sound at all if you would like you can use a 4 channel amplifier if you would like to keep this deck
Posted on Feb 06, 2009
Deh-x6500bt cuts out at high volumn
I have the same problem, it's only when the bass comes in, and it starts to cut at half volume.
My wiring is correct and every possible problem to do with the car and its wiring have been eliminated.
-Apart from plugging the unit into another vehicles loom.
Jun 29, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
Pioneer a-602r amplifier cuts out at high volumes
It is more than likely the final output transistors in one or more of your channels are beginning to short out or fail.
Sep 09, 2012 | Pioneer Audio Players & Recorders
Bass cut off when volume is too high
When an amplifier shuts the Bass off that means its going into protection mode otherwise it will burn out the outputs. One way is to turn your gains down, Pioneer amps are not the best amps for bass out there, they are more for car speakers, I personally wont use a pioneer amp to run my subwoofers especially if they are hard driven subs like JL , Kicker Solo's and MTX subs. But for now just turn the gains down to 3/4 and that should help u, you can also install a fan to keep your amp cooler, if this never happened before in 5 yrs and now it does then that means your amp is just tired and the inside components are overheating easily, thats common with Pioneer and Sony amps.
Good luck buddy.
Jun 12, 2010 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Are you sure it's not a problem with your head unit? When you mean cut off do you mean the whole amp loses power or power lights stay on but sound just cuts out? If you don't know have a friend turn up your radio if you don't have a remote and whatch the light, power light on the amp. If it goes out then it sounds like a bad ground or the main power wire is'nt large enough to supply proper power to amp. I would check those that I have described first because thats what it sounds like, bad ground or power wire not sending proper voltage. When you turn up the volume your amp needs more power well when you get to a point when you turn it up and amp cuts out or off then it's starving for power or bad ground. Let me know what you find. Also if this helps please rate my help so I can get out of this apprentice status. I have 15 years exp. and 2 degrees in electronics and my business is buying nonworking amps and repairing them then resale them. Thanks
Feb 05, 2009 | Pioneer Car Amplifier GM-6100F - 4 Channel...
My amp goes out and turns red when i get to a certain volume
get a 1.5 farad they have them at walmart for like 40 bucks
Dec 23, 2008 | JBL BP600.1 Car Audio Amplifier
Hits intemittently
ive had problems kinda like this ... normaly its a crossed or reversed speaker wire check the positive and negitive wire into the speakers "they move sometimes when there is more air moving around the speaker"
second make sure you have the impedence correct "possitive to positive negitive to negitive'
hope this helps
Dec 21, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
ZX700.5 cutting out at 60% volume
I figured out the problem, the front right tweeter wire was pinched behind the mounting bracket. everything is now working perfectly.
Sep 22, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
You need to check the DC voltage across the power and ground terminals of the amp. If the voltage drops below ~11v when the amp shuts off, you need to check the power/ground wiring and fuses.
If the voltage remains above 11 volts, you may have a problem with the load on the amp (incorrect ohm load, shorted speaker, shorted speaker wires...).
Jun 13, 2008 | Pioneer GM-X542 Car Audio Amplifier
Pioneer GM-6300F Car Audio Amplifier Logo
254 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
