Question about Toshiba Satellite A205-S5804 Notebook
My TOUCHPAD is not working!?!?
Here are the details.. the PC once had a broken screen and i replaced the screen with a spare toshiba laptop i had sitting around. FYI i had opened up the whole PC searching for options to get A LAPTOP running. i.e (i tried switching power outlets off the motherboards) looking for solutions. ANYWAYS, once i swapped screens i was able put together a operating laptop but my touchpad does not work..
so far i have tried installing updates and downloading touchpad drivers and i still havent been able to get it working... ANY SUGGESTIONS!?
  • madxblunts Feb 05, 2009
    DAGEEZER... Thanks for the tip. i popped open the chassis after running BIOS and found my touchpad cable connector was not properly insterted. Thanks again. .
  • 3,940 Answers
OK, if you opened that chassis during troubleshooting, then the issue is most likely either the touchpad cable was disconnected in the troubleshooting process and not reconnected, or worse, the cable damaged during disassembly/reassembly and the inputs are not being received from the touchpad. So re-checking the cable connecitons from the palmrest to the motherboard are in order. (I've done it)
Also, check and ensure if there is an option in the BIOS to disable the touchpad, make sure it is enabled.
Posted on Feb 05, 2009
  • IQUIT Feb 06, 2009
    Great, could you do me a favor and give me a rating for my assistance. =)
Toshiba P205d-S7454 powers on but has amber battery light and the touchpad data port is broken off motherboard will till post ?
it will still post if your motherboard, led display, hardisk and memory is working? try used usb mouse if your touchpad is broken!!!
May 01, 2014 | IBM ThinkPad T40 2373 Notebook
Touchpad doesnt work
Try reinstalling the touchpad driver.
You can download the touchpad and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
May 03, 2013 | Toshiba Satellite A135-S4477 Notebook
How do you adjust the touchpad on the Satellite L505 Toshiba?
Hi, to adjust the touchpad settings for your Toshiba L505 kindly follow the Step by Step intruction guide on this link,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=Mouse+pointer+jumps+around+as+you+type
You will see several search results, just click the topmost result which says "Mouse pointer jumps around as you type". You will then see a detailed guide on how to adjust touchpad settings. Hope this works for you.
Oct 30, 2010 | Toshiba Satellite L505ES5018 Laptop
TouchPad NOT working at all
yes. there is a high probability that the problem is hardware. try different versions of synaptics, not necessarily from toshiba
Oct 08, 2009 | HP Pavilion dv4000 Notebook
Need to replace LCD screen toshiba p105-s6024. need instructions to remove screen
Hello
First of all, I assume that your new LCD screen is compatible with theold one. Different screens require different video cables. Make sureyou new screen is compatible with your laptop.
Use the link below for more details and instructions.
http://www.laptoprepair101.com/laptop/2008/09/18/you-replaced-broken-lcd-screen-but-the-new-screen-is-not-working/
Regards
PCmania
Sep 26, 2009 | Toshiba Satellite P105-S6024 Notebook
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Toshiba laptop touchpad not working properly
Boot Toshiba disk to your CD ram. If you are using Toshiba Satellite 2410 it will only work with CD marked with its own model or any model of it. Open CD drive and look for Toshiba touchpad driver and install this to your PC notebook.
Jun 21, 2009 | Acer Aspire 5610-4648 Notebook
Toshiba a300 synaptic touch pad scroller stopped working
Hi there.
The touchpad drivers could be corrupt, try reinstalling the touchpad drivers again.
Go here to Toshiba Support fill in the details of your model laptop and download the synaptics touchpad driver and reinstall it, see if that helps.
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | HP Pavilion dv4000 Notebook
Toshiba Satellite A205-S5804 Notebook Logo
189 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
