It used to run for one month then later i got the problem of getting cut off at high volume...as i had warranty i send it to the company they said its proper and send it back..now still it has same problem with so much checkin n all...[plz help me out onthis>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Are you sure it's not a problem with your head unit? When you mean cut off do you mean the whole amp loses power or power lights stay on but sound just cuts out? If you don't know have a friend turn up your radio if you don't have a remote and whatch the light, power light on the amp. If it goes out then it sounds like a bad ground or the main power wire is'nt large enough to supply proper power to amp. I would check those that I have described first because thats what it sounds like, bad ground or power wire not sending proper voltage. When you turn up the volume your amp needs more power well when you get to a point when you turn it up and amp cuts out or off then it's starving for power or bad ground. Let me know what you find. Also if this helps please rate my help so I can get out of this apprentice status. I have 15 years exp. and 2 degrees in electronics and my business is buying nonworking amps and repairing them then resale them. Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
what are you running for subs? How are they wired? Let me know
